Commit b269b119 authored by Guillaume Sylvand's avatar Guillaume Sylvand
timing: add option --bigmat to choose if we allocate one big 'mat' array or if...
timing: add option --bigmat to choose if we allocate one big 'mat' array or if the runtime allocates the tile one by one
parent 015362fd
...@@ -62,6 +62,10 @@ ...@@ -62,6 +62,10 @@
#endif #endif
static int RunTest(int *iparam, _PREC *dparam, double *t_); static int RunTest(int *iparam, _PREC *dparam, double *t_);
static void* morse_getaddr_null(const MORSE_desc_t *A, int m, int n)
return (void*)( NULL );
int ISEED[4] = {0,0,0,1}; /* initial seed for zlarnv() */ int ISEED[4] = {0,0,0,1}; /* initial seed for zlarnv() */
...@@ -347,6 +351,7 @@ show_help(char *prog_name) { ...@@ -347,6 +351,7 @@ show_help(char *prog_name) {
" --gpus=X Number of GPU workers (default: 0)\n" " --gpus=X Number of GPU workers (default: 0)\n"
"\n" "\n"
" --[a]sync Enable/Disable synchronous calls in wrapper function such as POTRI. (default: async)\n" " --[a]sync Enable/Disable synchronous calls in wrapper function such as POTRI. (default: async)\n"
" --[no]bigmat Allocating one big mat or plenty of small (default: bigmat)\n"
" --[no]check Check result (default: nocheck)\n" " --[no]check Check result (default: nocheck)\n"
" --[no]progress Display progress indicator (default: noprogress)\n" " --[no]progress Display progress indicator (default: noprogress)\n"
" --[no]gemm3m Use gemm3m complex method (default: nogemm3m)\n" " --[no]gemm3m Use gemm3m complex method (default: nogemm3m)\n"
...@@ -468,6 +473,7 @@ main(int argc, char *argv[]) { ...@@ -468,6 +473,7 @@ main(int argc, char *argv[]) {
iparam[IPARAM_NITER ] = 1; iparam[IPARAM_NITER ] = 1;
iparam[IPARAM_WARMUP ] = 1; iparam[IPARAM_WARMUP ] = 1;
iparam[IPARAM_CHECK ] = 0; iparam[IPARAM_CHECK ] = 0;
iparam[IPARAM_BIGMAT ] = 1;
iparam[IPARAM_VERBOSE ] = 0; iparam[IPARAM_VERBOSE ] = 0;
iparam[IPARAM_AUTOTUNING ] = 0; iparam[IPARAM_AUTOTUNING ] = 0;
iparam[IPARAM_INPUTFMT ] = 0; iparam[IPARAM_INPUTFMT ] = 0;
...@@ -512,6 +518,10 @@ main(int argc, char *argv[]) { ...@@ -512,6 +518,10 @@ main(int argc, char *argv[]) {
iparam[IPARAM_CHECK] = 1; iparam[IPARAM_CHECK] = 1;
} else if (startswith( argv[i], "--nocheck" )) { } else if (startswith( argv[i], "--nocheck" )) {
iparam[IPARAM_CHECK] = 0; iparam[IPARAM_CHECK] = 0;
} else if (startswith( argv[i], "--bigmat" )) {
iparam[IPARAM_BIGMAT] = 1;
} else if (startswith( argv[i], "--nobigmat" )) {
iparam[IPARAM_BIGMAT] = 0;
} else if (startswith( argv[i], "--inv" )) { } else if (startswith( argv[i], "--inv" )) {
iparam[IPARAM_INVERSE] = 1; iparam[IPARAM_INVERSE] = 1;
} else if (startswith( argv[i], "--noinv" )) { } else if (startswith( argv[i], "--noinv" )) {
...@@ -12,6 +12,7 @@ ...@@ -12,6 +12,7 @@
#define TIMING_H #define TIMING_H
typedef double morse_time_t; typedef double morse_time_t;
static void* morse_getaddr_null(const MORSE_desc_t *A, int m, int n);
enum iparam_timing { enum iparam_timing {
IPARAM_THRDNBR, /* Number of cores */ IPARAM_THRDNBR, /* Number of cores */
...@@ -28,6 +29,7 @@ enum iparam_timing { ...@@ -28,6 +29,7 @@ enum iparam_timing {
IPARAM_MB, /* Number of rows in a tile */ IPARAM_MB, /* Number of rows in a tile */
IPARAM_NITER, /* Number of iteration of each test */ IPARAM_NITER, /* Number of iteration of each test */
IPARAM_WARMUP, /* Run one test to load dynamic libraries */ IPARAM_WARMUP, /* Run one test to load dynamic libraries */
IPARAM_BIGMAT, /* Allocating one big mat or plenty of small */
IPARAM_CHECK, /* Checking activated or not */ IPARAM_CHECK, /* Checking activated or not */
IPARAM_VERBOSE, /* How much noise do we want? */ IPARAM_VERBOSE, /* How much noise do we want? */
IPARAM_AUTOTUNING, /* Disable/enable autotuning */ IPARAM_AUTOTUNING, /* Disable/enable autotuning */
...@@ -93,6 +95,7 @@ enum dparam_timing { ...@@ -93,6 +95,7 @@ enum dparam_timing {
int64_t Q = iparam[IPARAM_Q]; \ int64_t Q = iparam[IPARAM_Q]; \
int64_t MT = (M%MB==0) ? (M/MB) : (M/MB+1); \ int64_t MT = (M%MB==0) ? (M/MB) : (M/MB+1); \
int64_t NT = (N%NB==0) ? (N/NB) : (N/NB+1); \ int64_t NT = (N%NB==0) ? (N/NB) : (N/NB+1); \
int bigmat = iparam[IPARAM_BIGMAT]; \
int check = iparam[IPARAM_CHECK]; \ int check = iparam[IPARAM_CHECK]; \
int loud = iparam[IPARAM_VERBOSE]; \ int loud = iparam[IPARAM_VERBOSE]; \
(void)M;(void)N;(void)K;(void)NRHS; \ (void)M;(void)N;(void)K;(void)NRHS; \
...@@ -104,8 +107,12 @@ enum dparam_timing { ...@@ -104,8 +107,12 @@ enum dparam_timing {
#define PASTE_CODE_ALLOCATE_MATRIX_TILE(_desc_, _cond_, _type_, _type2_, _lda_, _m_, _n_) \ #define PASTE_CODE_ALLOCATE_MATRIX_TILE(_desc_, _cond_, _type_, _type2_, _lda_, _m_, _n_) \
MORSE_desc_t *_desc_ = NULL; \ MORSE_desc_t *_desc_ = NULL; \
if( _cond_ ) { \ if( _cond_ ) { \
MORSE_Desc_Create(&(_desc_), NULL, _type2_, MB, NB, MB*NB, _lda_, _n_, 0, 0, _m_, _n_, \ if (!bigmat) \
P, Q); \ MORSE_Desc_Create_User(&(_desc_), NULL, _type2_, MB, NB, MB*NB, _lda_, _n_, 0, 0, _m_, _n_, \
P, Q, morse_getaddr_null, NULL, NULL);\
else \
P, Q);\
#define PASTE_CODE_FREE_MATRIX(_desc_) \ #define PASTE_CODE_FREE_MATRIX(_desc_) \
