Commit af31ebaf authored by Mathieu Faverge's avatar Mathieu Faverge
Get rid of old Piotr functions for norms
parent 1549b342
......@@ -34,170 +34,6 @@
#include <coreblas.h>
#include "testing_zauxiliary.h"
enum blas_order_type {
blas_rowmajor = 101,
blas_colmajor = 102 };
enum blas_uplo_type {
blas_upper = 121,
blas_lower = 122 };
enum blas_cmach_type {
blas_base = 151,
blas_t = 152,
blas_rnd = 153,
blas_ieee = 154,
blas_emin = 155,
blas_emax = 156,
blas_eps = 157,
blas_prec = 158,
blas_underflow = 159,
blas_overflow = 160,
blas_sfmin = 161};
enum blas_norm_type {
blas_one_norm = 171,
blas_real_one_norm = 172,
blas_two_norm = 173,
blas_frobenius_norm = 174,
blas_inf_norm = 175,
blas_real_inf_norm = 176,
blas_max_norm = 177,
blas_real_max_norm = 178 };
static void
BLAS_error(char *rname, int err, int val, int x) {
fprintf( stderr, "%s %d %d %d\n", rname, err, val, x );
abort();
static
void
BLAS_zsy_norm(enum blas_order_type order, enum blas_norm_type norm,
enum blas_uplo_type uplo, int n, const MORSE_Complex64_t *a, int lda, double *res) {
int i, j; double anorm, v;
char rname[] = "BLAS_zsy_norm";
if (order != blas_colmajor) BLAS_error( rname, -1, order, 0 );
if (norm == blas_inf_norm) {
anorm = 0.0;
if (blas_upper == uplo) {
for (i = 0; i < n; ++i) {
v = 0.0;
for (j = 0; j < i; ++j) {
v += cabs( a[j + i * lda] );
for (j = i; j < n; ++j) {
v += cabs( a[i + j * lda] );
if (v > anorm)
anorm = v;
} else {
BLAS_error( rname, -3, norm, 0 );
return;
} else {
BLAS_error( rname, -2, norm, 0 );
return;
if (res) *res = anorm;
static
void
BLAS_zge_norm(enum blas_order_type order, enum blas_norm_type norm,
int m, int n, const MORSE_Complex64_t *a, int lda, double *res) {
int i, j; float anorm, v;
char rname[] = "BLAS_zge_norm";
if (norm == blas_frobenius_norm) {
anorm = 0.0f;
for (j = n; j; --j) {
for (i = m; i; --i) {
v = a[0];
anorm += v * v;
a++;
a += lda - m;
anorm = sqrt( anorm );
} else if (norm == blas_inf_norm) {
anorm = 0.0f;
for (i = 0; i < m; ++i) {
v = 0.0f;
for (j = 0; j < n; ++j) {
if (v > anorm)
anorm = v;
} else {
return;
static
double
BLAS_dpow_di(double x, int n) {
double rv = 1.0;
if (n < 0) {
n = -n;
x = 1.0 / x;
for (; n; n >>= 1, x *= x) {
if (n & 1)
rv *= x;
return rv;
static
double
BLAS_dfpinfo(enum blas_cmach_type cmach) {
double eps = 1.0, r = 1.0, o = 1.0, b = 2.0;
int t = 53, l = 1024, m = -1021;
char rname[] = "BLAS_dfpinfo";
if ((sizeof eps) == sizeof(float)) {
t = 24;
l = 128;
m = -125;
} else {
t = 53;
l = 1024;
m = -1021;
/* for (i = 0; i < t; ++i) eps *= half; */
eps = BLAS_dpow_di( b, -t );
/* for (i = 0; i >= m; --i) r *= half; */
r = BLAS_dpow_di( b, m-1 );
o -= eps;
/* for (i = 0; i < l; ++i) o *= b; */
o = (o * BLAS_dpow_di( b, l-1 )) * b;
switch (cmach) {
case blas_eps: return eps;
case blas_sfmin: return r;
default:
BLAS_error( rname, -1, cmach, 0 );
break;
return 0.0;
static int check_orthogonality(int, int, int, MORSE_Complex64_t*, double);
static int check_factorization(int, int, MORSE_Complex64_t*, MORSE_Complex64_t*, int, MORSE_Complex64_t*, double);
static int check_solution(int, int, int, MORSE_Complex64_t*, int, MORSE_Complex64_t*, MORSE_Complex64_t*, int, double);
......@@ -268,7 +104,7 @@ int testing_zgels(int argc, char **argv)
MORSE_Alloc_Workspace_zgels(M, N, &T, 1, 1);
memset(T->mat, 0, (T->llm*T->lln)*sizeof(MORSE_Complex64_t));
eps = BLAS_dfpinfo( blas_eps );
eps = LAPACKE_dlamch_work('e');
* TESTING ZGELS
......@@ -508,16 +344,18 @@ static int check_orthogonality(int M, int N, int LDQ, MORSE_Complex64_t *Q, doub
/* Build the idendity matrix USE DLASET?*/
MORSE_Complex64_t *Id = (MORSE_Complex64_t *) malloc(minMN*minMN*sizeof(MORSE_Complex64_t));
memset((void*)Id, 0, minMN*minMN*sizeof(MORSE_Complex64_t));
for (i = 0; i < minMN; i++)
for (i = 0; i < minMN; i++) {
Id[i*minMN+i] = (MORSE_Complex64_t)1.0;
/* Perform Id - Q'Q */
if (M >= N)
if (M >= N) {
cblas_zherk(CblasColMajor, CblasUpper, CblasConjTrans, N, M, alpha, Q, LDQ, beta, Id, N);
else
else {
cblas_zherk(CblasColMajor, CblasUpper, CblasNoTrans, M, N, alpha, Q, LDQ, beta, Id, M);
BLAS_zsy_norm( blas_colmajor, blas_inf_norm, blas_upper, minMN, Id, minMN, &normQ );
normQ = LAPACKE_zlansy_work( LAPACK_COL_MAJOR, 'i', 'u', minMN, Id, minMN, work );
printf("============\n");
printf("Checking the orthogonality of Q \n");
......@@ -583,8 +421,8 @@ static int check_factorization(int M, int N, MORSE_Complex64_t *A1, MORSE_Comple
for (j = 0 ; j < N; j++)
Residual[j*M+i] = A1[j*LDA+i]-Ql[j*M+i];
BLAS_zge_norm( blas_colmajor, blas_inf_norm, M, N, Residual, M, &Rnorm );
BLAS_zge_norm( blas_colmajor, blas_inf_norm, M, N, A2, LDA, &Anorm );
Rnorm = LAPACKE_zlange_work( LAPACK_COL_MAJOR, 'i', M, N, Residual, M, work );
Anorm = LAPACKE_zlange_work( LAPACK_COL_MAJOR, 'i', M, N, A2, LDA, work );
if (M >= N) {
......@@ -626,9 +464,9 @@ static int check_solution(int M, int N, int NRHS, MORSE_Complex64_t *A, int LDA,
alpha = 1.0;
beta = -1.0;
BLAS_zge_norm( blas_colmajor, blas_inf_norm, M, N, A, LDA, &Anorm );
BLAS_zge_norm( blas_colmajor, blas_inf_norm, N, NRHS, B, LDB, &Bnorm );
BLAS_zge_norm( blas_colmajor, blas_inf_norm, M, NRHS, X, LDB, &Xnorm );
Anorm = LAPACKE_zlange_work( LAPACK_COL_MAJOR, 'i', M, N, A, LDA, work );
Bnorm = LAPACKE_zlange_work( LAPACK_COL_MAJOR, 'i', N, NRHS, B, LDB, work );
Xnorm = LAPACKE_zlange_work( LAPACK_COL_MAJOR, 'i', M, NRHS, X, LDB, work );
cblas_zgemm(CblasColMajor, CblasNoTrans, CblasNoTrans, M, NRHS, N, CBLAS_SADDR(alpha), A, LDA, X, LDB, CBLAS_SADDR(beta), B, LDB);
......@@ -636,14 +474,14 @@ static int check_solution(int M, int N, int NRHS, MORSE_Complex64_t *A, int LDA,
MORSE_Complex64_t *Residual = (MORSE_Complex64_t *)malloc(M*NRHS*sizeof(MORSE_Complex64_t));
memset((void*)Residual, 0, M*NRHS*sizeof(MORSE_Complex64_t));
cblas_zgemm(CblasColMajor, CblasConjTrans, CblasNoTrans, N, NRHS, M, CBLAS_SADDR(alpha), A, LDA, B, LDB, CBLAS_SADDR(beta), Residual, M);
BLAS_zge_norm( blas_colmajor, blas_inf_norm, M, NRHS, Residual, M, &Rnorm );
Rnorm = LAPACKE_zlange_work( LAPACK_COL_MAJOR, 'i', M, NRHS, Residual, M, work );
free(Residual);
else {
MORSE_Complex64_t *Residual = (MORSE_Complex64_t *)malloc(N*NRHS*sizeof(MORSE_Complex64_t));
memset((void*)Residual, 0, N*NRHS*sizeof(MORSE_Complex64_t));
cblas_zgemm(CblasColMajor, CblasConjTrans, CblasNoTrans, N, NRHS, M, CBLAS_SADDR(alpha), A, LDA, B, LDB, CBLAS_SADDR(beta), Residual, N);
BLAS_zge_norm( blas_colmajor, blas_inf_norm, N, NRHS, Residual, N, &Rnorm );
Rnorm = LAPACKE_zlange_work( LAPACK_COL_MAJOR, 'i', N, NRHS, Residual, N, work );
free(Residual);
......@@ -33,131 +33,6 @@
blas_base = 151,
blas_t = 152,
blas_rnd = 153,
blas_ieee = 154,
blas_emin = 155,
blas_emax = 156,
blas_eps = 157,
blas_prec = 158,
blas_sfmin = 161};
static void
abort();
static
void
anorm = 0.0f;
v = a[0];
anorm += v * v;
a++;
a += lda - m;
anorm = 0.0f;
v = 0.0f;
if (v > anorm)
anorm = v;
} else {
return;
static
double
double rv = 1.0;
if (n < 0) {
n = -n;
x = 1.0 / x;
if (n & 1)
rv *= x;
return rv;
static
double
t = 24;
l = 128;
m = -125;
} else {
t = 53;
l = 1024;
m = -1021;
o -= eps;
switch (cmach) {
default:
break;
return 0.0;
static int check_solution(int, int , MORSE_Complex64_t *, int, MORSE_Complex64_t *, MORSE_Complex64_t *, int, double);
int testing_zgesv_incpiv(int argc, char **argv)
......@@ -199,7 +74,7 @@ int testing_zgesv_incpiv(int argc, char **argv)
return -2;
eps = BLAS_dfpinfo(blas_eps);
eps = LAPACKE_dlamch_work( 'e' );
* TESTING ZGESV
......@@ -352,12 +227,12 @@ static int check_solution(int N, int NRHS, MORSE_Complex64_t *A1, int LDA, MORSE
alpha = 1.0;
beta = -1.0;
BLAS_zge_norm( blas_colmajor, blas_inf_norm, N, NRHS, B2, LDB, &Xnorm );
BLAS_zge_norm( blas_colmajor, blas_inf_norm, N, N, A1, LDA, &Anorm );
BLAS_zge_norm( blas_colmajor, blas_inf_norm, N, NRHS, B1, LDB, &Bnorm );
Xnorm = LAPACKE_zlange( LAPACK_COL_MAJOR, 'i', N, NRHS, B2, LDB );
Anorm = LAPACKE_zlange( LAPACK_COL_MAJOR, 'i', N, N, A1, LDA );
Bnorm = LAPACKE_zlange( LAPACK_COL_MAJOR, 'i', N, NRHS, B1, LDB );
cblas_zgemm(CblasColMajor, CblasNoTrans, CblasNoTrans, N, NRHS, N, CBLAS_SADDR(alpha), A1, LDA, B2, LDB, CBLAS_SADDR(beta), B1, LDB);
BLAS_zge_norm( blas_colmajor, blas_inf_norm, N, NRHS, B1, LDB, &Rnorm );
Rnorm = LAPACKE_zlange( LAPACK_COL_MAJOR, 'i', N, NRHS, B1, LDB );
if (getenv("MORSE_TESTING_VERBOSE"))
printf( "||A||_oo=%f\n||X||_oo=%f\n||B||_oo=%f\n||A X - B||_oo=%e\n", Anorm, Xnorm, Bnorm, Rnorm );
blas_base = 151,
blas_t = 152,
blas_rnd = 153,
blas_ieee = 154,
blas_emin = 155,
blas_emax = 156,
blas_eps = 157,
blas_prec = 158,
blas_sfmin = 161};
static void
abort();
static
void
anorm = 0.0f;
v = a[0];
anorm += v * v;
a++;
a += lda - m;
anorm = 0.0f;
v = 0.0f;
if (v > anorm)
anorm = v;
} else {
return;
static
double
double rv = 1.0;
if (n < 0) {
n = -n;
x = 1.0 / x;
if (n & 1)
rv *= x;
return rv;
static
double
t = 24;
l = 128;
m = -125;
} else {
t = 53;
l = 1024;
m = -1021;
o -= eps;
switch (cmach) {
default:
break;
return 0.0;
static int check_factorization(int, MORSE_Complex64_t*, MORSE_Complex64_t*, int, int , double);
static int check_solution(int, int, MORSE_Complex64_t*, int, MORSE_Complex64_t*, MORSE_Complex64_t*, int, double);
......@@ -198,7 +73,7 @@ int testing_zposv(int argc, char **argv)
return -2;
uplo = MorseUpper;
trans1 = uplo == MorseUpper ? MorseConjTrans : MorseNoTrans;
......@@ -371,8 +246,8 @@ static int check_factorization(int N, MORSE_Complex64_t *A1, MORSE_Complex64_t *
for (j = 0; j < N; j++)
Residual[j*N+i] = L2[j*N+i] - Residual[j*N+i];
BLAS_zge_norm( blas_colmajor, blas_inf_norm, N, N, Residual, N, &Rnorm );
Rnorm = LAPACKE_zlange( LAPACK_COL_MAJOR, 'i', N, N, Residual, N );
printf("Checking the Cholesky Factorization \n");
......@@ -407,12 +282,12 @@ static int check_solution(int N, int NRHS, MORSE_Complex64_t *A1, int LDA, MORSE
alpha = 1.0;
beta = -1.0;
......@@ -33,141 +33,6 @@
blas_base = 151,
blas_t = 152,
blas_rnd = 153,
blas_ieee = 154,
blas_emin = 155,
blas_emax = 156,
blas_eps = 157,
blas_prec = 158,
blas_sfmin = 161};
