Commit a4a509da authored by Mathieu Faverge's avatar Mathieu Faverge
Merge branch 'feature/sched_sselection' into 'master'
Simplify the choice of the runtime system before integrating the new ones
See merge request solverstack/chameleon!131
parents c0c86d69 faffa860
...@@ -78,7 +78,7 @@ build_quark: ...@@ -78,7 +78,7 @@ build_quark:
- build - build
- chameleon_quark.log - chameleon_quark.log
variables: variables:
BUILD_OPTIONS: "-DCHAMELEON_SCHED_QUARK=ON" BUILD_OPTIONS: "-DCHAMELEON_SCHED=QUARK"
VERSION: quark VERSION: quark
build_parsec: build_parsec:
...@@ -90,7 +90,7 @@ build_parsec: ...@@ -90,7 +90,7 @@ build_parsec:
- build - build
- chameleon_parsec.log - chameleon_parsec.log
BUILD_OPTIONS: "-DCHAMELEON_SCHED_PARSEC=ON" BUILD_OPTIONS: "-DCHAMELEON_SCHED=PARSEC"
VERSION: parsec VERSION: parsec
test_starpu_branches: test_starpu_branches:
...@@ -25,7 +25,7 @@ ...@@ -25,7 +25,7 @@
# @date 2012-07-13 # @date 2012-07-13
cmake_minimum_required(VERSION 2.8) cmake_minimum_required(VERSION 3.3)
project(CHAMELEON Fortran C CXX) project(CHAMELEON Fortran C CXX)
# directly make an error if in-source build # directly make an error if in-source build
...@@ -108,50 +108,31 @@ option(CHAMELEON_USE_MIGRATE ...@@ -108,50 +108,31 @@ option(CHAMELEON_USE_MIGRATE
# Create a list of possible runtime # Create a list of possible runtime
set(CHAMELEON_SCHED_list "PARSEC" "STARPU" "QUARK") set(CHAMELEON_SCHED_list PARSEC STARPU QUARK
CACHE INTERNAL "List of available runtimes" )
# Initially PaRSEC runtime is enabled set( CHAMELEON_SCHED_PARSEC OFF CACHE INTERNAL
option(CHAMELEON_SCHED_PARSEC "Enable PaRSEC scheduler as the default runtime
"Enable PaRSEC scheduler as the default runtime (Conflict with other CHAMELEON_SCHED_* options)")
(Conflict with other CHAMELEON_SCHED_* options)" OFF) set(CHAMELEON_SCHED_STARPU OFF CACHE INTERNAL
option(CHAMELEON_SCHED_STARPU
"Enable StarPU scheduler as the default runtime "Enable StarPU scheduler as the default runtime
(Conflict with other CHAMELEON_SCHED_* options)" OFF) (Conflict with other CHAMELEON_SCHED_* options)")
option(CHAMELEON_SCHED_QUARK set(CHAMELEON_SCHED_QUARK OFF CACHE INTERNAL
"Enable Quark scheduler as the default runtime "Enable Quark scheduler as the default runtime
# For now, we are able to compile only one runtime at a time, so we disable combinations of runtimes set( CHAMELEON_SCHED STARPU
if (CHAMELEON_SCHED_QUARK) CACHE STRING "Choose the chameleon internal runtime from ${CHAMELEON_SCHED_list}")
set(CHAMELEON_SCHED_STARPU OFF) set_property(CACHE CHAMELEON_SCHED PROPERTY STRINGS ${CHAMELEON_SCHED_list})
set(CHAMELEON_SCHED_PARSEC OFF)
elseif (CHAMELEON_SCHED_STARPU) if ( NOT ${CHAMELEON_SCHED} IN_LIST CHAMELEON_SCHED_list )
set(CHAMELEON_SCHED_QUARK OFF) message(FATAL_ERROR "CHAMELEON_SCHED must be one of ${CHAMELEON_SCHED_list} (${CHAMELEON_SCHED} is incorrect)" )
elseif (CHAMELEON_SCHED_PARSEC)
endif() endif()
set( CHAMELEON_SCHED_${CHAMELEON_SCHED} ON )
# Set default to StarPU if nothing specific is required by the user # Set default to StarPU if nothing specific is required by the user
if ( NOT CHAMELEON_SCHED_STARPU AND NOT CHAMELEON_SCHED_PARSEC AND NOT CHAMELEON_SCHED_QUARK ) message("-- ${BoldGreen}CHAMELEON_SCHED is set to use ${CHAMELEON_SCHED} runtime" )
set(CHAMELEON_SCHED_STARPU ON)
endif()
message("-- ${BoldGreen}CHAMELEON_SCHED_STARPU is set to ON: CHAMELEON uses StarPU runtime\n"
" To use CHAMELEON with Quark runtime: set CHAMELEON_SCHED_QUARK to ON\n"
" To use CHAMELEON with PaRSEC runtime: set CHAMELEON_SCHED_PARSEC to ON\n"
" (CHAMELEON_SCHED_STARPU will be disabled)${ColourReset}")
elseif(CHAMELEON_SCHED_QUARK)
message("-- ${BoldGreen}CHAMELEON_SCHED_QUARK is set to ON: CHAMELEON uses Quark runtime\n"
" To use CHAMELEON with StarPU runtime: set CHAMELEON_SCHED_STARPU to ON\n"
" (CHAMELEON_SCHED_QUARK will be disabled)${ColourReset}")
elseif(CHAMELEON_SCHED_PARSEC)
message("-- ${BoldGreen}CHAMELEON_SCHED_PARSEC is set to ON: CHAMELEON uses PaRSEC runtime\n"
" (CHAMELEON_SCHED_PARSEC will be disabled)${ColourReset}")
endif()
# Check that one, and only one, SCHED option is set to ON # Check that one, and only one, SCHED option is set to ON
# count number of runtime sets to ON # count number of runtime sets to ON
...@@ -359,12 +359,8 @@ we encourage users to use [[sec:spack][Spack]]. ...@@ -359,12 +359,8 @@ we encourage users to use [[sec:spack][Spack]].
LAPACKE - QUARK - SIMGRID - STARPU - TMG. LAPACKE - QUARK - SIMGRID - STARPU - TMG.
**** Chameleon specific options **** Chameleon specific options
* *CHAMELEON_SCHED_STARPU=ON|OFF* (default ON): to link with * *CHAMELEON_SCHED=STARPU|PARSEC|QUARK* (default STARPU): to link
StarPU library (runtime system) respectively with StarPU, PaRSEC, or Quark library (runtime system)
* *CHAMELEON_SCHED_PARSEC=ON|OFF* (default OFF): to link with
PARSEC library (runtime system)
* *CHAMELEON_SCHED_QUARK=ON|OFF* (default OFF): to link with QUARK
* *CHAMELEON_USE_MPI=ON|OFF* (default OFF): to link with MPI * *CHAMELEON_USE_MPI=ON|OFF* (default OFF): to link with MPI
library (message passing implementation for use of multiple library (message passing implementation for use of multiple
nodes with distributed memory), can only be used with StarPU nodes with distributed memory), can only be used with StarPU
