Commit 9abc1b22 authored by Mathieu Faverge's avatar Mathieu Faverge
Put back the checks
parent 9288bb2c
...@@ -68,7 +68,7 @@ if (NOT CHAMELEON_SIMULATION) ...@@ -68,7 +68,7 @@ if (NOT CHAMELEON_SIMULATION)
string(TOUPPER ${prec} PREC) string(TOUPPER ${prec} PREC)
if (CHAMELEON_PREC_${PREC}) if (CHAMELEON_PREC_${PREC})
foreach(test ${TESTLIST}) foreach(test ${TESTLIST})
add_test(time_ooc_${cat}_${prec}${test} ${MPI_CMD_${cat}} ./time_${prec}${test}_tile ${TEST_CMD_${cat}} --ooc )#--check) add_test(time_ooc_${cat}_${prec}${test} ${MPI_CMD_${cat}} ./time_${prec}${test}_tile ${TEST_CMD_${cat}} --ooc --check)
set_tests_properties(time_ooc_${cat}_${prec}${test} PROPERTIES set_tests_properties(time_ooc_${cat}_${prec}${test} PROPERTIES
ENVIRONMENT "STARPU_DISK_SWAP=/tmp;STARPU_LIMIT_CPU_MEM=1" ENVIRONMENT "STARPU_DISK_SWAP=/tmp;STARPU_LIMIT_CPU_MEM=1"
...@@ -79,7 +79,7 @@ if (NOT CHAMELEON_SIMULATION) ...@@ -79,7 +79,7 @@ if (NOT CHAMELEON_SIMULATION)
foreach(test ${TESTLIST_ZC}) foreach(test ${TESTLIST_ZC})
