Commit 836a9a41 authored by PRUVOST Florent's avatar PRUVOST Florent
using intel mkl sequential by default if intel compilers
parent 7b99eaf9
...@@ -248,6 +248,11 @@ endif() ...@@ -248,6 +248,11 @@ endif()
#option(CHAMELEON_GEN_PREC "Generate source files precisions" ON) #option(CHAMELEON_GEN_PREC "Generate source files precisions" ON)
# If Intel compiler force using Intel MKL Sequential if BLA_VENDOR not set
if (CMAKE_C_COMPILER_ID MATCHES "Intel" AND (NOT BLA_VENDOR OR BLA_VENDOR STREQUAL "All"))
set (BLA_VENDOR "Intel10_64lp_seq")
endif()
# Build dependency HQR library # # Build dependency HQR library #
