Commit 7ff33aba authored by PRUVOST Florent's avatar PRUVOST Florent
update the list of build log files
parent be1d39ce
...@@ -35,7 +35,7 @@ sonar.sourceEncoding=UTF-8 ...@@ -35,7 +35,7 @@ sonar.sourceEncoding=UTF-8
sonar.cxx.compiler.charset=UTF-8 sonar.cxx.compiler.charset=UTF-8
sonar.cxx.compiler.parser=GCC sonar.cxx.compiler.parser=GCC
sonar.cxx.compiler.regex=^(.*):(\\d+):\\d+: warning: (.*)\\[(.*)\\]$ sonar.cxx.compiler.regex=^(.*):(\\d+):\\d+: warning: (.*)\\[(.*)\\]$
sonar.cxx.compiler.reportPath=chameleon-build-starpu-mpi.log, chameleon-build-starpu-cuda.log, chameleon-build-starpu-simgrid.log, chameleon-build-quark.log sonar.cxx.compiler.reportPath=chameleon-build-starpu-mpi.log, chameleon-build-starpu-simgrid.log, chameleon-build-quark.log
sonar.cxx.coverage.reportPath=chameleon-coverage.xml sonar.cxx.coverage.reportPath=chameleon-coverage.xml
sonar.cxx.cppcheck.reportPath=chameleon-cppcheck.xml sonar.cxx.cppcheck.reportPath=chameleon-cppcheck.xml
sonar.cxx.rats.reportPath=chameleon-rats.xml sonar.cxx.rats.reportPath=chameleon-rats.xml
Supports Markdown
