Commit 657f29b3 authored by BOUCHERIE Raphael's avatar BOUCHERIE Raphael
fixed compilation bug
parent 38b89ecf
...@@ -38,7 +38,7 @@ ...@@ -38,7 +38,7 @@
#include <stdio.h> #include <stdio.h>
#include <stdlib.h> #include <stdlib.h>
#include <string.h> #include <string.h>
#include <assert.h> #include <limits.h>
#if defined( _WIN32 ) || defined( _WIN64 ) #if defined( _WIN32 ) || defined( _WIN64 )
#include <windows.h> #include <windows.h>
...@@ -549,7 +549,7 @@ set_iparam_default(int *iparam){ ...@@ -549,7 +549,7 @@ set_iparam_default(int *iparam){
static inline int static inline int
read_integer_from_options(int long_index) read_integer_from_options(int long_index, int opt_char)
char *endptr; char *endptr;
long int value; long int value;
...@@ -560,10 +560,10 @@ read_integer_from_options(int long_index) ...@@ -560,10 +560,10 @@ read_integer_from_options(int long_index)
#ifdef CHAMELEON_HAVE_GETOPT_LONG #ifdef CHAMELEON_HAVE_GETOPT_LONG
if ( long_index < 0 ) { if ( long_index < 0 ) {
#endif #endif
fprintf(stderr, "Invalid numeric value for '-%c' parameter\n", optopt); fprintf(stderr, "Invalid numeric value '%s' for '-%c' parameter\n", optarg, opt_char);
} else { } else {
fprintf(stderr, "Invalid numeric value for '--%s' parameter\n", long_options[long_index].name); fprintf(stderr, "Invalid numeric value '%s' for '--%s' parameter\n", optarg, long_options[long_index].name);
#endif #endif
exit(EXIT_FAILURE); exit(EXIT_FAILURE);
...@@ -596,24 +596,24 @@ parse_arguments(int *_argc, char ***_argv, int *iparam, int *start, int *stop, i ...@@ -596,24 +596,24 @@ parse_arguments(int *_argc, char ***_argv, int *iparam, int *start, int *stop, i
switch(c) switch(c)
// Configuration // Configuration
case 't' : iparam[IPARAM_THRDNBR ] = read_integer_from_options(atoi(optarg)); break; case 't' : iparam[IPARAM_THRDNBR ] = read_integer_from_options(opt, c); break;
case 'g' : iparam[IPARAM_NCUDAS ] = read_integer_from_options(atoi(optarg)); break; case 'g' : iparam[IPARAM_NCUDAS ] = read_integer_from_options(opt, c); break;
case 'P' : iparam[IPARAM_P ] = read_integer_from_options(atoi(optarg)); break; case 'P' : iparam[IPARAM_P ] = read_integer_from_options(opt, c); break;
case '8' : iparam[IPARAM_NO_CPU ] = 1; break; case '8' : iparam[IPARAM_NO_CPU ] = 1; break;
// Matrix parameters // Matrix parameters
case 'M' : case 'M' :
case 'm' : iparam[IPARAM_M ] = read_integer_from_options(atoi(optarg)); break; case 'm' : iparam[IPARAM_M ] = read_integer_from_options(opt, c); break;
case 'n' : iparam[IPARAM_N ] = read_integer_from_options(atoi(optarg)); break; case 'n' : iparam[IPARAM_N ] = read_integer_from_options(opt, c); break;
case 'N' : get_range(optarg, start, stop, step); break; case 'N' : get_range(optarg, start, stop, step); break;
case 'K' : case 'K' :
case 'k' : iparam[IPARAM_K ] = read_integer_from_options(atoi(optarg)); break; case 'k' : iparam[IPARAM_K ] = read_integer_from_options(opt, c); break;
case 'b' : iparam[IPARAM_NB ] = read_integer_from_options(atoi(optarg)); case 'b' : iparam[IPARAM_NB ] = read_integer_from_options(opt, c);
iparam[IPARAM_MB ] = read_integer_from_options(atoi(optarg)); break; iparam[IPARAM_MB ] = read_integer_from_options(opt, c); break;
case 'i' : iparam[IPARAM_IB ] = read_integer_from_options(atoi(optarg)); break; case 'i' : iparam[IPARAM_IB ] = read_integer_from_options(opt, c); break;
case 'x' : iparam[IPARAM_MX ] = read_integer_from_options(atoi(optarg)); break; case 'x' : iparam[IPARAM_MX ] = read_integer_from_options(opt, c); break;
case 'X' : iparam[IPARAM_NX ] = read_integer_from_options(atoi(optarg)); break; case 'X' : iparam[IPARAM_NX ] = read_integer_from_options(opt, c); break;
// Check/prints // Check/prints
case '1' : iparam[IPARAM_NITER ] = read_integer_from_options(atoi(optarg)); break; case '1' : iparam[IPARAM_NITER ] = read_integer_from_options(opt, c); break;
case 'W' : iparam[IPARAM_PRINT_WARNINGS] = 0; break; case 'W' : iparam[IPARAM_PRINT_WARNINGS] = 0; break;
case 'w' : iparam[IPARAM_WARMUP ] = 0; break; case 'w' : iparam[IPARAM_WARMUP ] = 0; break;
case 'c' : iparam[IPARAM_CHECK ] = 1; break; case 'c' : iparam[IPARAM_CHECK ] = 1; break;
...@@ -624,12 +624,12 @@ parse_arguments(int *_argc, char ***_argv, int *iparam, int *start, int *stop, i ...@@ -624,12 +624,12 @@ parse_arguments(int *_argc, char ***_argv, int *iparam, int *start, int *stop, i
case 'd' : iparam[IPARAM_DAG ] = 1; break; case 'd' : iparam[IPARAM_DAG ] = 1; break;
case 'p' : iparam[IPARAM_PROFILE ] = 1; break; case 'p' : iparam[IPARAM_PROFILE ] = 1; break;
// HQR options // HQR options
case 'a' : iparam[IPARAM_RHBLK ] = read_integer_from_options(atoi(optarg)); break; case 'a' : iparam[IPARAM_RHBLK ] = read_integer_from_options(opt, c); break;
case 'l' : iparam[IPARAM_LOWLVL_TREE ] = read_integer_from_options(atoi(optarg)); break; case 'l' : iparam[IPARAM_LOWLVL_TREE ] = read_integer_from_options(opt, c); break;
case 'L' : iparam[IPARAM_HIGHLVL_TREE ] = read_integer_from_options(atoi(optarg)); break; case 'L' : iparam[IPARAM_HIGHLVL_TREE ] = read_integer_from_options(opt, c); break;
case 'D' : iparam[IPARAM_QR_DOMINO ] = 1; break; case 'D' : iparam[IPARAM_QR_DOMINO ] = 1; break;
//Other //Other
case '9' : iparam[IPARAM_MODE ] = read_integer_from_options(atoi(optarg)); break; case '9' : iparam[IPARAM_MODE ] = read_integer_from_options(opt, c); break;
case '3' : iparam[IPARAM_BIGMAT ] = 0; break; case '3' : iparam[IPARAM_BIGMAT ] = 0; break;
case 's' : iparam[IPARAM_ASYNC ] = 0; break; case 's' : iparam[IPARAM_ASYNC ] = 0; break;
case 'o' : iparam[IPARAM_OOC ] = 1; break; case 'o' : iparam[IPARAM_OOC ] = 1; break;
