GitLab
Support
Community forum
Keyboard shortcuts
Chameleon
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Analytics
Analytics
Value Stream
AGULLO Emmanuel
Chameleon
5e2da7ea
5e2da7ea
PRUVOST Florent
check that starpu_mpi_data_migrate exists to enable CHAMELEON_USE_MIGRATE
ee9f0ad1
2
2 changed files
9 additions
+9
CMakeLists.txt
CMakeLists.txt
+8
runtime/starpu/include/chameleon_starpu.h.in
+1
CMakeLists.txt
5e2da7ea
@@ -685,6 +685,14 @@ if( CHAMELEON_SCHED_STARPU )
set
HAVE_STARPU_MALLOC_ON_NODE_SET_DEFAULT_FLAGS 1
message
Blue
Add definition HAVE_STARPU_MALLOC_ON_NODE_SET_DEFAULT_FLAGS
ColourReset
endif
check_function_exists
starpu_mpi_data_migrate STARPU_MPI_DATA_MIGRATE_FOUND
if
set
HAVE_STARPU_MPI_DATA_MIGRATE 1
message
Blue
Add definition HAVE_STARPU_MPI_DATA_MIGRATE
ColourReset
elseif
set
"OFF"
message
"-- CHAMELEON_USE_MIGRATE is turned OFF because starpu_mpi_data_migrate not found"
endif
if
CHAMELEON_ENABLE_TRACING
# check if fxt profiling is accessible in starpu and activate it in chameleon
unset
STARPU_FXT_START_PROFILING_FOUND CACHE
5e2da7ea
@@ -30,6 +30,7 @@
#cmakedefine HAVE_STARPU_DATA_WONT_USE
#cmakedefine HAVE_STARPU_DATA_SET_COORDINATES
#cmakedefine HAVE_STARPU_MALLOC_ON_NODE_SET_DEFAULT_FLAGS
#cmakedefine HAVE_STARPU_MPI_DATA_MIGRATE
#cmakedefine HAVE_STARPU_MPI_DATA_REGISTER
#cmakedefine HAVE_STARPU_MPI_COMM_RANK
#cmakedefine HAVE_STARPU_MPI_CACHED_RECEIVE
