Commit 5971bde2 authored by PRUVOST Florent's avatar PRUVOST Florent
magma_ztsqrt_gpu is now defined in magma-1.6.0: change the name of our magma...
magma_ztsqrt_gpu is now defined in magma-1.6.0: change the name of our magma routine in magma_ztsqrt2_gpu
parent c3509e34
...@@ -163,7 +163,7 @@ static void cl_ztsqrt_cpu_func(void *descr[], void *cl_arg) ...@@ -163,7 +163,7 @@ static void cl_ztsqrt_cpu_func(void *descr[], void *cl_arg)
#if defined(CHAMELEON_USE_MAGMA) #if defined(CHAMELEON_USE_MAGMA)
magma_int_t magma_int_t
magma_ztsqrt_gpu( magma_int_t m, magma_int_t n, magma_int_t nb, magma_ztsqrt2_gpu( magma_int_t m, magma_int_t n, magma_int_t nb,
magmaDoubleComplex *da1, magma_int_t ldda1, magmaDoubleComplex *da1, magma_int_t ldda1,
magmaDoubleComplex *da2, magma_int_t ldda2, magmaDoubleComplex *da2, magma_int_t ldda2,
magmaDoubleComplex *a2, magma_int_t lda2, magmaDoubleComplex *a2, magma_int_t lda2,
...@@ -343,7 +343,7 @@ static void cl_ztsqrt_cuda_func(void *descr[], void *cl_arg) ...@@ -343,7 +343,7 @@ static void cl_ztsqrt_cuda_func(void *descr[], void *cl_arg)
h_D = h_W + ib*n; h_D = h_W + ib*n;
CUstream stream = starpu_cuda_get_local_stream(); CUstream stream = starpu_cuda_get_local_stream();
magma_ztsqrt_gpu( m, n, ib, magma_ztsqrt2_gpu( m, n, ib,
d_A1, lda1, d_A2, lda2, d_A1, lda1, d_A2, lda2,
h_A2, lda2, h_A2, lda2,
d_T, ldt, h_T, ib, d_T, ldt, h_T, ib,
