Une nouvelle version du portail de gestion des comptes externes sera mise en production lundi 09 août. Elle permettra d'allonger la validité d'un compte externe jusqu'à 3 ans. Pour plus de détails sur cette version consulter : https://doc-si.inria.fr/x/FCeS
Commit 5971bde2 authored by PRUVOST Florent's avatar PRUVOST Florent
magma_ztsqrt_gpu is now defined in magma-1.6.0: change the name of our magma...
magma_ztsqrt_gpu is now defined in magma-1.6.0: change the name of our magma routine in magma_ztsqrt2_gpu
parent c3509e34
...@@ -163,18 +163,18 @@ static void cl_ztsqrt_cpu_func(void *descr[], void *cl_arg) ...@@ -163,18 +163,18 @@ static void cl_ztsqrt_cpu_func(void *descr[], void *cl_arg)
#if defined(CHAMELEON_USE_MAGMA) #if defined(CHAMELEON_USE_MAGMA)
magma_int_t magma_int_t
magma_ztsqrt_gpu( magma_int_t m, magma_int_t n, magma_int_t nb, magma_ztsqrt2_gpu( magma_int_t m, magma_int_t n, magma_int_t nb,
magmaDoubleComplex *da1, magma_int_t ldda1, magmaDoubleComplex *da1, magma_int_t ldda1,
magmaDoubleComplex *da2, magma_int_t ldda2, magmaDoubleComplex *da2, magma_int_t ldda2,
magmaDoubleComplex *a2, magma_int_t lda2, magmaDoubleComplex *a2, magma_int_t lda2,
magmaDoubleComplex *dt, magma_int_t lddt, magmaDoubleComplex *dt, magma_int_t lddt,
magmaDoubleComplex *t, magma_int_t ldt, magmaDoubleComplex *t, magma_int_t ldt,
magmaDoubleComplex *dd, magmaDoubleComplex *dd,
magmaDoubleComplex *d, magma_int_t ldd, magmaDoubleComplex *d, magma_int_t ldd,
magmaDoubleComplex *tau, magmaDoubleComplex *tau,
magmaDoubleComplex *hwork, magmaDoubleComplex *hwork,
magmaDoubleComplex *dwork, magmaDoubleComplex *dwork,
CUstream stream) CUstream stream)
#define da1_ref(a_1,a_2) ( da1+(a_2)*ldda1 + (a_1)) #define da1_ref(a_1,a_2) ( da1+(a_2)*ldda1 + (a_1))
#define da2_ref(a_1,a_2) ( da2+(a_2)*ldda2 + (a_1)) #define da2_ref(a_1,a_2) ( da2+(a_2)*ldda2 + (a_1))
...@@ -343,12 +343,12 @@ static void cl_ztsqrt_cuda_func(void *descr[], void *cl_arg) ...@@ -343,12 +343,12 @@ static void cl_ztsqrt_cuda_func(void *descr[], void *cl_arg)
h_D = h_W + ib*n; h_D = h_W + ib*n;
CUstream stream = starpu_cuda_get_local_stream(); CUstream stream = starpu_cuda_get_local_stream();
magma_ztsqrt_gpu( m, n, ib, magma_ztsqrt2_gpu( m, n, ib,
d_A1, lda1, d_A2, lda2, d_A1, lda1, d_A2, lda2,
h_A2, lda2, h_A2, lda2,
d_T, ldt, h_T, ib, d_T, ldt, h_T, ib,
d_D, h_D, ib, h_TAU, d_D, h_D, ib, h_TAU,
h_W, d_W, stream); h_W, d_W, stream);
cudaThreadSynchronize(); cudaThreadSynchronize();
