Commit 54816087 authored by PRUVOST Florent's avatar PRUVOST Florent
add eztrace chameleon_cuda module - not checked yet
parent ca3d1e6f
# @copyright (c) 2009-2014 The University of Tennessee and The University
# of Tennessee Research Foundation.
# All rights reserved.
# @copyright (c) 2012-2015 Inria. All rights reserved.
# @copyright (c) 2012-2014 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
# @file CMakeLists.txt
# @project MORSE
# MORSE is a software package provided by:
# Inria Bordeaux - Sud-Ouest,
# Univ. of Tennessee,
# King Abdullah Univesity of Science and Technology
# Univ. of California Berkeley,
# Univ. of Colorado Denver.
# @version 0.9.0
# @author Florent Pruvost
# @date 16-09-2015
if (NOT EZTRACE_FOUND)
find_package(EZTRACE)
endif()
if (EZTRACE_FOUND AND EZTRACE_DIR_FOUND)
set(EZTRACE_eztrace_create_plugin_DIR "EZTRACE_eztrace_create_plugin_DIR-NOTFOUND")
find_path(EZTRACE_eztrace_create_plugin_DIR
NAMES eztrace_create_plugin
HINTS ${EZTRACE_DIR_FOUND}/bin)
if (EZTRACE_eztrace_create_plugin_DIR)
set(EZTRACE_CREATE_PLUGIN "${EZTRACE_eztrace_create_plugin_DIR}/eztrace_create_plugin")
add_custom_command(
OUTPUT ${CMAKE_CURRENT_BINARY_DIR}/output
COMMAND ${EZTRACE_CREATE_PLUGIN}
ARGS ${CMAKE_CURRENT_SOURCE_DIR}/cudablas_eztrace_module
DEPENDS ${CMAKE_CURRENT_SOURCE_DIR}/cudablas_eztrace_module
add_custom_target(
eztrace-module-chameleon_cuda-dir ALL
DEPENDS ${CMAKE_CURRENT_BINARY_DIR}/output
add_custom_command(
OUTPUT libeztrace-convert-chameleon_cuda.so
COMMAND make
WORKING_DIRECTORY ${CMAKE_CURRENT_BINARY_DIR}/output
add_custom_target(
eztrace-module-chameleon_cuda-libs ALL
DEPENDS libeztrace-convert-chameleon_cuda.so
# installation
install(
FILES
${CMAKE_CURRENT_BINARY_DIR}/output/libeztrace-autostart-chameleon_cuda.so
${CMAKE_CURRENT_BINARY_DIR}/output/libeztrace-chameleon_cuda.so
${CMAKE_CURRENT_BINARY_DIR}/output/libeztrace-convert-chameleon_cuda.so
DESTINATION ${EZTRACE_LIBRARY_DIRS}
endif (EZTRACE_eztrace_create_plugin_DIR)
endif (EZTRACE_FOUND AND EZTRACE_DIR_FOUND)
### END CMakeLists.txt
This diff is collapsed.
