Commit 3dcd8b4d authored by PRUVOST Florent's avatar PRUVOST Florent
improve pkg-config files:
  - no need to have both chameleon-quark.pc.in and chameleon-starpu.pc.in
    - new file is chameleon.pc.in
  - create coreblas.pc.in and cudablas.pc.in
    - chameleon depends on coreblas and cudablas pkg-config files
  - re-write a little bit how libraries lists are converted into pkg-config style
parent afc24160
......@@ -1113,15 +1113,7 @@ endif()
# Create file morse_starpu.pc
if(CHAMELEON_SCHED_STARPU)
generate_pkgconfig_file("${CMAKE_CURRENT_SOURCE_DIR}/lib/pkgconfig/chameleon-starpu.pc.in")
endif()
# # Create file morse_quark.pc
if(CHAMELEON_SCHED_QUARK)
generate_pkgconfig_file("${CMAKE_CURRENT_SOURCE_DIR}/lib/pkgconfig/chameleon-quark.pc.in")
endif()
generate_pkgconfig_file()
......@@ -3,7 +3,7 @@
# @copyright (c) 2009-2014 The University of Tennessee and The University
# of Tennessee Research Foundation.
# All rights reserved.
# @copyright (c) 2012-2014 Inria. All rights reserved.
# @copyright (c) 2012-2017 Inria. All rights reserved.
# @copyright (c) 2012-2014 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
......@@ -18,7 +18,7 @@
# Univ. of California Berkeley,
# Univ. of Colorado Denver.
# @version 0.9.0
# @version 0.9.1
# @author Cedric Castagnede
# @author Emmanuel Agullo
# @author Mathieu Faverge
......@@ -29,105 +29,156 @@
# GENERATE_PKGCONFIG_FILE: generate a file .pc according to the options
# CONVERT_LIBSTYLE_TO_PKGCONFIG: convert a libraries list to follow the pkg-config style
# used in CLEAN_LIB_LIST
MACRO(GENERATE_PKGCONFIG_FILE _file)
MACRO(CONVERT_LIBSTYLE_TO_PKGCONFIG _liblist)
set(${_liblist}_CPY "${${_liblist}}")
set(${_liblist} "")
foreach(_dep ${${_liblist}_CPY})
if (${_dep} MATCHES "^/")
get_filename_component(dep_libname ${_dep} NAME)
get_filename_component(dep_libdir ${_dep} DIRECTORY)
STRING(REPLACE "lib" "" dep_libname "${dep_libname}")
STRING(REPLACE ".so" "" dep_libname "${dep_libname}")
STRING(REPLACE ".a" "" dep_libname "${dep_libname}")
STRING(REPLACE ".dylib" "" dep_libname "${dep_libname}")
STRING(REPLACE ".dll" "" dep_libname "${dep_libname}")
list(APPEND ${_liblist} -L${dep_libdir} -l${dep_libname})
elseif(NOT ${_dep} MATCHES "^-")
list(APPEND ${_liblist} "-l${_dep}")
else()
list(APPEND ${_liblist} ${_dep})
endif()
endforeach()
ENDMACRO(CONVERT_LIBSTYLE_TO_PKGCONFIG)
# CLEAN_LIB_LIST: clean libraries lists to follow the pkg-config style
# used in GENERATE_PKGCONFIG_FILE
MACRO(CLEAN_LIB_LIST _package)
list(REMOVE_DUPLICATES ${_package}_PKGCONFIG_LIBS)
list(REMOVE_DUPLICATES ${_package}_PKGCONFIG_LIBS_PRIVATE)
list(REMOVE_DUPLICATES ${_package}_PKGCONFIG_REQUIRED)
list(REMOVE_DUPLICATES ${_package}_PKGCONFIG_REQUIRED_PRIVATE)
CONVERT_LIBSTYLE_TO_PKGCONFIG(${_package}_PKGCONFIG_LIBS)
CONVERT_LIBSTYLE_TO_PKGCONFIG(${_package}_PKGCONFIG_LIBS_PRIVATE)
STRING(REPLACE ";" " " ${_package}_PKGCONFIG_LIBS "${${_package}_PKGCONFIG_LIBS}")
STRING(REPLACE ";" " " ${_package}_PKGCONFIG_LIBS_PRIVATE "${${_package}_PKGCONFIG_LIBS_PRIVATE}")
STRING(REPLACE ";" " " ${_package}_PKGCONFIG_REQUIRED "${${_package}_PKGCONFIG_REQUIRED}")
STRING(REPLACE ";" " " ${_package}_PKGCONFIG_REQUIRED_PRIVATE "${${_package}_PKGCONFIG_REQUIRED_PRIVATE}")
ENDMACRO(CLEAN_LIB_LIST)
# GENERATE_PKGCONFIG_FILE: generate files chameleon.pc, coreblas.pc and cudablas.pc
MACRO(GENERATE_PKGCONFIG_FILE)
# The link flags specific to this package and any required libraries
# that don't support PkgConfig
set(CHAMELEON_PKGCONFIG_LIBS "")
set(CHAMELEON_PKGCONFIG_LIBS "-lchameleon")
set(COREBLAS_PKGCONFIG_LIBS "-lcoreblas")
set(CUDABLAS_PKGCONFIG_LIBS "-lcudablas")
# The link flags for private libraries required by this package but not
# exposed to applications
set(CHAMELEON_PKGCONFIG_LIBS_PRIVATE "")
set(COREBLAS_PKGCONFIG_LIBS_PRIVATE "")
set(CUDABLAS_PKGCONFIG_LIBS_PRIVATE "")
# A list of packages required by this package
set(CHAMELEON_PKGCONFIG_REQUIRED "")
set(COREBLAS_PKGCONFIG_REQUIRED "")
set(CUDABLAS_PKGCONFIG_REQUIRED "")
# A list of private packages required by this package but not exposed to
# applications
set(CHAMELEON_PKGCONFIG_REQUIRED_PRIVATE "")
set(COREBLAS_PKGCONFIG_REQUIRED_PRIVATE "")
set(CUDABLAS_PKGCONFIG_REQUIRED_PRIVATE "")
list(APPEND CHAMELEON_PKGCONFIG_LIBS -lchameleon)
list(APPEND CHAMELEON_PKGCONFIG_LIBS -lchameleon_starpu)
if ( CHAMELEON_USE_MPI )
list(APPEND CHAMELEON_PKGCONFIG_REQUIRED libstarpumpi)
list(APPEND CHAMELEON_PKGCONFIG_REQUIRED_PRIVATE libstarpumpi)
else()
list(APPEND CHAMELEON_PKGCONFIG_REQUIRED libstarpu)
list(APPEND CHAMELEON_PKGCONFIG_REQUIRED_PRIVATE libstarpu)
endif()
elseif(CHAMELEON_SCHED_QUARK)
list(APPEND CHAMELEON_PKGCONFIG_LIBS -lchameleon_quark)
list(APPEND CHAMELEON_PKGCONFIG_LIBS "-l${QUARK_quark_LIBRARY}")
list(APPEND CHAMELEON_PKGCONFIG_LIBS_PRIVATE "${QUARK_LIBRARIES_DEP}")
endif()
if(NOT CHAMELEON_SIMULATION)
if(CHAMELEON_USE_CUDA)
list(APPEND CHAMELEON_PKGCONFIG_LIBS ${CUDA_LIBRARIES})
endif()
if(CHAMELEON_USE_MAGMA)
list(APPEND CHAMELEON_PKGCONFIG_REQUIRED magma)
endif()
-lcoreblas
${LAPACKE_LIBRARIES}
${CBLAS_LIBRARIES}
list(APPEND COREBLAS_PKGCONFIG_LIBS_PRIVATE
${LAPACKE_LIBRARIES_DEP}
${CBLAS_LIBRARIES_DEP}
${EXTRA_LIBRARIES}
list(APPEND CHAMELEON_PKGCONFIG_REQUIRED "coreblas")
list(APPEND CUDABLAS_PKGCONFIG_REQUIRED_PRIVATE magma)
list(APPEND CHAMELEON_PKGCONFIG_REQUIRED_PRIVATE magma)
else()
list(APPEND CHAMELEON_PKGCONFIG_REQUIRED hwloc)
endif()
list(APPEND CUDABLAS_PKGCONFIG_LIBS_PRIVATE ${CUDA_LIBRARIES})
list(APPEND CHAMELEON_PKGCONFIG_REQUIRED "cudablas")
endif()
else(NOT CHAMELEON_SIMULATION)
list(APPEND CHAMELEON_PKGCONFIG_LIBS -lcudablas)
endif()
-lcoreblas
${EXTRA_LIBRARIES}
endif(NOT CHAMELEON_SIMULATION)
list(APPEND CHAMELEON_PKGCONFIG_REQUIRED_PRIVATE hwloc)
# Define required package
set(CHAMELEON_PKGCONFIG_LIBS_CPY "${CHAMELEON_PKGCONFIG_LIBS}")
foreach(_dep ${CHAMELEON_PKGCONFIG_LIBS_CPY})
if (NOT ${_dep} MATCHES "^-L")
get_filename_component(dep_we ${_dep} NAME)
message(STATUS "dep_we : ${dep_we}")
STRING(REPLACE "lib" "-l" dep_we "${dep_we}")
STRING(REPLACE ".so" "" dep_we "${dep_we}")
STRING(REPLACE ".a" "" dep_we "${dep_we}")
STRING(REPLACE ".dylib" "" dep_we "${dep_we}")
STRING(REPLACE ".dll" "" dep_we "${dep_we}")
list(APPEND CHAMELEON_PKGCONFIG_LIBS ${dep_we})
else()
list(APPEND CHAMELEON_PKGCONFIG_LIBS ${_dep})
CLEAN_LIB_LIST(CHAMELEON)
CLEAN_LIB_LIST(COREBLAS)
CLEAN_LIB_LIST(CUDABLAS)
endif()
endforeach()
list(REMOVE_DUPLICATES CHAMELEON_PKGCONFIG_LIBS)
list(REMOVE_DUPLICATES CHAMELEON_PKGCONFIG_LIBS_PRIVATE)
list(REMOVE_DUPLICATES CHAMELEON_PKGCONFIG_REQUIRED)
list(REMOVE_DUPLICATES CHAMELEON_PKGCONFIG_REQUIRED_PRIVATE)
STRING(REPLACE ";" " " CHAMELEON_PKGCONFIG_LIBS "${CHAMELEON_PKGCONFIG_LIBS}")
STRING(REPLACE ";" " " CHAMELEON_PKGCONFIG_LIBS_PRIVATE "${CHAMELEON_PKGCONFIG_LIBS_PRIVATE}")
STRING(REPLACE ";" " " CHAMELEON_PKGCONFIG_REQUIRED "${CHAMELEON_PKGCONFIG_REQUIRED}")
STRING(REPLACE ";" " " CHAMELEON_PKGCONFIG_REQUIRED_PRIVATE "${CHAMELEON_PKGCONFIG_REQUIRED_PRIVATE}")
# Create .pc file
SET(_output_file "${CMAKE_BINARY_DIR}/chameleon.pc")
SET(_output_chameleon_file "${CMAKE_BINARY_DIR}/chameleon.pc")
SET(_output_coreblas_file "${CMAKE_BINARY_DIR}/coreblas.pc")
SET(_output_cudablas_file "${CMAKE_BINARY_DIR}/cudablas.pc")
endif()
# TODO: add url of MORSE releases in .pc file
CONFIGURE_FILE("${_file}" "${_output_file}" @ONLY)
CONFIGURE_FILE("${CMAKE_CURRENT_SOURCE_DIR}/lib/pkgconfig/chameleon.pc.in" "${_output_chameleon_file}" @ONLY)
CONFIGURE_FILE("${CMAKE_CURRENT_SOURCE_DIR}/lib/pkgconfig/coreblas.pc.in" "${_output_coreblas_file}" @ONLY)
CONFIGURE_FILE("${CMAKE_CURRENT_SOURCE_DIR}/lib/pkgconfig/cudablas.pc.in" "${_output_cudablas_file}" @ONLY)
endif()
# installation
INSTALL(FILES ${_output_file} DESTINATION lib/pkgconfig)
INSTALL(FILES ${_output_chameleon_file} DESTINATION lib/pkgconfig)
INSTALL(FILES ${_output_coreblas_file} DESTINATION lib/pkgconfig)
INSTALL(FILES ${_output_cudablas_file} DESTINATION lib/pkgconfig)
ENDMACRO(GENERATE_PKGCONFIG_FILE)
prefix=@CMAKE_INSTALL_PREFIX@
exec_prefix=${prefix}
libdir=${exec_prefix}/lib
includedir=${exec_prefix}/include/chameleon
Description: Dense Linear Algebra for Scalable Multi-core Architectures and GPGPUs
Version: @CHAMELEON_VERSION_MAJOR@.@CHAMELEON_VERSION_MINOR@.@CHAMELEON_VERSION_PATCH@
Cflags: -I${includedir} -I${includedir}/coreblas/include
Libs: -L${libdir} @CHAMELEON_PKGCONFIG_LIBS@
Libs.private: @CHAMELEON_PKGCONFIG_LIBS_PRIVATE@
Requires: @CHAMELEON_PKGCONFIG_REQUIRED@
Requires.private: @CHAMELEON_PKGCONFIG_REQUIRED_PRIVATE@
......@@ -5,7 +5,7 @@ includedir=${exec_prefix}/include/chameleon
Version: @CHAMELEON_VERSION_MAJOR@.@CHAMELEON_VERSION_MINOR@.@CHAMELEON_VERSION_MICRO@
includedir=${exec_prefix}/include/chameleon/coreblas/include
Description: Interface to CBLAS/LAPACKE routines + some other auxiliary routines
Libs: -L${libdir} @COREBLAS_PKGCONFIG_LIBS@
Libs.private: @COREBLAS_PKGCONFIG_LIBS_PRIVATE@
Requires: @COREBLAS_PKGCONFIG_REQUIRED@
Requires.private: @COREBLAS_PKGCONFIG_REQUIRED_PRIVATE@
includedir=${exec_prefix}/include/chameleon/cudablas/include
Description: Interface to cuBLAS/MAGMA routines + some other auxiliary routines
Libs: -L${libdir} @CUDABLAS_PKGCONFIG_LIBS@
Libs.private: @CUDABLAS_PKGCONFIG_LIBS_PRIVATE@
Requires: @CUDABLAS_PKGCONFIG_REQUIRED@
Requires.private: @CUDABLAS_PKGCONFIG_REQUIRED_PRIVATE@
