Commit 34558c7a authored by THIBAULT Samuel's avatar THIBAULT Samuel
Introduce MORSE_Distributed_start, MORSE_Distributed_stop,
MORSE_Distributed_size, MORSE_Distributed_rank so that applications do not
hardcode the use of MPI.
Introduce RUNTIME_distributed_rank, RUNTIME_distributed_size,
RUNTIME_distributed_barrier, so that MORSE does not hardcode the use of MPI
either.
This allows to use simgrid-mpi.
parent 21c2c538
...@@ -625,6 +625,17 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/cmake_modules/") ...@@ -625,6 +625,17 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/cmake_modules/")
" - starpu_mpi_data_register() test fails in StarPU${ColourReset}") " - starpu_mpi_data_register() test fails in StarPU${ColourReset}")
message("-- ${Red}Check in CMakeFiles/CMakeError.log to figure out why it fails${ColourReset}") message("-- ${Red}Check in CMakeFiles/CMakeError.log to figure out why it fails${ColourReset}")
endif() endif()
unset(STARPU_MPI_COMM_RANK_FOUND CACHE)
check_function_exists(starpu_mpi_comm_rank STARPU_MPI_COMM_RANK_FOUND)
if ( STARPU_MPI_COMM_RANK_FOUND )
message("-- ${Blue}Add definition HAVE_STARPU_MPI_COMM_RANK - Activate"
"use of starpu_mpi_comm_rank() in Chameleon with StarPU${ColourReset}")
add_definitions(-DHAVE_STARPU_MPI_COMM_RANK)
else()
message("-- ${Red}Looking for starpu with starpu_mpi_data_register"
" - starpu_mpi_comm_rank() test fails in StarPU${ColourReset}")
endif()
endif() endif()
if(HWLOC_FOUND AND HWLOC_LIBRARY_DIRS) if(HWLOC_FOUND AND HWLOC_LIBRARY_DIRS)
# the RPATH to be used when installing # the RPATH to be used when installing
...@@ -4,7 +4,7 @@ ...@@ -4,7 +4,7 @@
* of Tennessee Research Foundation. * of Tennessee Research Foundation.
* All rights reserved. * All rights reserved.
* @copyright (c) 2012-2014 Inria. All rights reserved. * @copyright (c) 2012-2014 Inria. All rights reserved.
* @copyright (c) 2012-2014 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved. * @copyright (c) 2012-2015 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
...@@ -138,8 +138,8 @@ int MORSE_Finalize(void) ...@@ -138,8 +138,8 @@ int MORSE_Finalize(void)
magma_finalize(); magma_finalize();
#endif #endif
morse_context_destroy(); morse_context_destroy();
RUNTIME_distributed_barrier();
#if defined(CHAMELEON_USE_MPI) #if defined(CHAMELEON_USE_MPI)
MPI_Barrier(MPI_COMM_WORLD);
if (!morse->mpi_outer_init) if (!morse->mpi_outer_init)
MPI_Finalize(); MPI_Finalize();
#endif #endif
...@@ -193,3 +193,75 @@ int MORSE_Resume(void) ...@@ -193,3 +193,75 @@ int MORSE_Resume(void)
RUNTIME_resume(morse); RUNTIME_resume(morse);
return MORSE_SUCCESS; return MORSE_SUCCESS;
* @ingroup Control
* MORSE_Distributed_start - Prepare the distributed processes for computation
* @return
* \retval MORSE_SUCCESS successful exit
int MORSE_Distributed_start(void)
RUNTIME_distributed_barrier ();
* @ingroup Control
* MORSE_Distributed_stop - Clean the distributed processes after computation
* @return
int MORSE_Distributed_stop(void)
* @ingroup Control
* MORSE_Distributed_size - Return the size of the distributed computation
* @return
int MORSE_Distributed_size( int *size )
RUNTIME_distributed_size (size);
* @ingroup Control
* MORSE_Distributed_rank - Return the rank of the distributed computation
* @return
int MORSE_Distributed_rank( int *rank )
RUNTIME_distributed_rank (rank);
...@@ -77,11 +77,7 @@ MORSE_desc_t morse_desc_init(MORSE_enum dtyp, int mb, int nb, int bsiz, ...@@ -77,11 +77,7 @@ MORSE_desc_t morse_desc_init(MORSE_enum dtyp, int mb, int nb, int bsiz,
desc.alloc_mat = 1; desc.alloc_mat = 1;
desc.register_mat = 1; desc.register_mat = 1;
#if defined(CHAMELEON_USE_MPI) RUNTIME_distributed_rank( &(desc.myrank) );
MPI_Comm_rank( MPI_COMM_WORLD, &(desc.myrank) );
#else
desc.myrank = 0;
#endif
// Grid size // Grid size
desc.p = p; desc.p = p;
...@@ -166,11 +162,7 @@ MORSE_desc_t morse_desc_init_diag(MORSE_enum dtyp, int mb, int nb, int bsiz, ...@@ -166,11 +162,7 @@ MORSE_desc_t morse_desc_init_diag(MORSE_enum dtyp, int mb, int nb, int bsiz,
#else
desc.myrank = 0;
#endif
...@@ -258,11 +250,7 @@ MORSE_desc_t morse_desc_init_user(MORSE_enum dtyp, int mb, int nb, int bsiz, ...@@ -258,11 +250,7 @@ MORSE_desc_t morse_desc_init_user(MORSE_enum dtyp, int mb, int nb, int bsiz,
#else
desc.myrank = 0;
#endif
...@@ -418,7 +406,7 @@ int morse_desc_mat_free( MORSE_desc_t *desc ) ...@@ -418,7 +406,7 @@ int morse_desc_mat_free( MORSE_desc_t *desc )
if (desc->mat != NULL && if (desc->mat != NULL &&
desc->use_mat == 1 && desc->use_mat == 1 &&
desc->alloc_mat == 1) { desc->alloc_mat == 1) {
#ifndef CHAMELEON_SIMULATION #if !defined(CHAMELEON_SIMULATION) || defined(CHAMELEON_USE_MPI)
free(desc->mat); free(desc->mat);
#endif #endif
desc->mat = NULL; desc->mat = NULL;
...@@ -508,7 +496,7 @@ int MORSE_Desc_Create(MORSE_desc_t **desc, void *mat, MORSE_enum dtyp, int mb, i ...@@ -508,7 +496,7 @@ int MORSE_Desc_Create(MORSE_desc_t **desc, void *mat, MORSE_enum dtyp, int mb, i
if (mat == NULL) { if (mat == NULL) {
#ifdef CHAMELEON_SIMULATION #if defined(CHAMELEON_SIMULATION) && !defined(CHAMELEON_USE_MPI)
(**desc).mat = (void*) 1; (**desc).mat = (void*) 1;
#else #else
/* TODO: a call to morse_desc_mat_alloc should be made, but require to /* TODO: a call to morse_desc_mat_alloc should be made, but require to
...@@ -81,6 +81,10 @@ int MORSE_Pause (void); ...@@ -81,6 +81,10 @@ int MORSE_Pause (void);
int MORSE_Resume (void); int MORSE_Resume (void);
int MORSE_Lapack_to_Tile (void *Af77, int LDA, MORSE_desc_t *A); int MORSE_Lapack_to_Tile (void *Af77, int LDA, MORSE_desc_t *A);
int MORSE_Tile_to_Lapack (MORSE_desc_t *A, void *Af77, int LDA); int MORSE_Tile_to_Lapack (MORSE_desc_t *A, void *Af77, int LDA);
int MORSE_Distributed_start(void);
int MORSE_Distributed_stop (void);
int MORSE_Distributed_size (int*size);
int MORSE_Distributed_rank (int*rank);
/* Descriptor */ /* Descriptor */
int MORSE_Desc_Create (MORSE_desc_t **desc, void *mat, MORSE_enum dtyp, int MORSE_Desc_Create (MORSE_desc_t **desc, void *mat, MORSE_enum dtyp,
...@@ -54,6 +54,9 @@ void RUNTIME_finalize_scheduler (MORSE_context_t*); ...@@ -54,6 +54,9 @@ void RUNTIME_finalize_scheduler (MORSE_context_t*);
void RUNTIME_barrier (MORSE_context_t*); void RUNTIME_barrier (MORSE_context_t*);
void RUNTIME_pause (MORSE_context_t*); void RUNTIME_pause (MORSE_context_t*);
void RUNTIME_resume (MORSE_context_t*); void RUNTIME_resume (MORSE_context_t*);
void RUNTIME_distributed_rank (int*);
void RUNTIME_distributed_size (int*);
void RUNTIME_distributed_barrier(void);
* RUNTIME Descriptor * RUNTIME Descriptor
...@@ -86,3 +86,29 @@ void RUNTIME_resume( MORSE_context_t *morse ) ...@@ -86,3 +86,29 @@ void RUNTIME_resume( MORSE_context_t *morse )
(void)morse; (void)morse;
return; return;
* This returns the rank of this process
void RUNTIME_distributed_rank( int *rank )
*rank = 0;
return;
* This returns the size of the distributed computation
void RUNTIME_distributed_size( int *size )
*size = 1;
return;
* Barrier between processes of the distributed computation
void RUNTIME_distributed_barrier( void )
return;
...@@ -107,8 +107,8 @@ int RUNTIME_init_scheduler( MORSE_context_t *morse, int ncpus, int ncudas, int n ...@@ -107,8 +107,8 @@ int RUNTIME_init_scheduler( MORSE_context_t *morse, int ncpus, int ncudas, int n
int flag = 0; int flag = 0;
MPI_Initialized( &flag ); MPI_Initialized( &flag );
starpu_mpi_init(NULL, NULL, !flag); starpu_mpi_init(NULL, NULL, !flag);
MPI_Comm_rank(MPI_COMM_WORLD, &(morse->my_mpi_rank)); starpu_mpi_comm_rank(MPI_COMM_WORLD, &(morse->my_mpi_rank));
MPI_Comm_size(MPI_COMM_WORLD, &(morse->mpi_comm_size)); starpu_mpi_comm_size(MPI_COMM_WORLD, &(morse->mpi_comm_size));
#endif #endif
...@@ -178,3 +178,48 @@ void RUNTIME_resume( MORSE_context_t *morse ) ...@@ -178,3 +178,48 @@ void RUNTIME_resume( MORSE_context_t *morse )
starpu_resume(); starpu_resume();
return; return;
# if defined(HAVE_STARPU_MPI_RANK)
starpu_mpi_comm_rank(MPI_COMM_WORLD, rank);
# else
MPI_Comm_rank(MPI_COMM_WORLD, rank);
# endif
#else
*rank = 0;
#endif
return;
starpu_mpi_comm_size(MPI_COMM_WORLD, size);
# else
MPI_Comm_size(MPI_COMM_WORLD, size);
# endif
#else
*size = 1;
#endif
return;
starpu_mpi_barrier(MPI_COMM_WORLD);
#endif
return;
...@@ -622,7 +622,7 @@ main(int argc, char *argv[]) { ...@@ -622,7 +622,7 @@ main(int argc, char *argv[]) {
MORSE_Enable(MORSE_ERRORS); MORSE_Enable(MORSE_ERRORS);
MPI_Comm_size( MPI_COMM_WORLD, &nbnode ); MORSE_Distributed_size( &nbnode );
iparam[IPARAM_NMPI] = nbnode; iparam[IPARAM_NMPI] = nbnode;
/* Check P */ /* Check P */
if ( (iparam[IPARAM_P] > 1) && if ( (iparam[IPARAM_P] > 1) &&
...@@ -185,8 +185,8 @@ enum dparam_timing { ...@@ -185,8 +185,8 @@ enum dparam_timing {
#define START_DISTRIBUTED() MPI_Barrier(MPI_COMM_WORLD); #define START_DISTRIBUTED() MORSE_Distributed_start();
#define STOP_DISTRIBUTED() MPI_Barrier(MPI_COMM_WORLD); #define STOP_DISTRIBUTED() MORSE_Distributed_stop();
#else #else
#define START_DISTRIBUTED() do {} while(0); #define START_DISTRIBUTED() do {} while(0);
#define STOP_DISTRIBUTED() do {} while(0); #define STOP_DISTRIBUTED() do {} while(0);
