Commit 29ed46b7 authored by PRUVOST Florent's avatar PRUVOST Florent Committed by Mathieu Faverge
Doc
    improve user's doc style
    add some explanation about the code structure in the main doxygen
    fix coverage in analysis sonarqube
    add a release job to automatize release publication
    change the cdash server to my.cdash.org which is more recent and reactive than cdash.inria.fr
    fix the version number, dates and authors in headers to prepare the release 0.9.2
parent 75528e23
This diff is collapsed.
......@@ -4,7 +4,7 @@
# @copyright 2009-2014 The University of Tennessee and The University of
# Tennessee Research Foundation. All rights reserved.
# @copyright 2012-2018 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
# @copyright 2012-2019 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
# Univ. Bordeaux. All rights reserved.
......@@ -17,12 +17,12 @@
# Univ. of California Berkeley,
# Univ. of Colorado Denver.
# @version 1.0.0
# @version 0.9.2
# @author Cedric Castagnede
# @author Emmanuel Agullo
# @author Mathieu Faverge
# @author Florent Pruvost
# @date 2012-07-13
# @date 2014-11-16
cmake_minimum_required(VERSION 3.3)
......@@ -36,9 +36,9 @@ if("${PROJECT_SOURCE_DIR}" STREQUAL "${PROJECT_BINARY_DIR}")
endif()
# set project version number
set(CHAMELEON_VERSION_MAJOR 1)
set(CHAMELEON_VERSION_MINOR 0)
set(CHAMELEON_VERSION_MICRO 0)
set(CHAMELEON_VERSION_MAJOR 0)
set(CHAMELEON_VERSION_MINOR 9)
set(CHAMELEON_VERSION_MICRO 2)
set(CHAMELEON_CMAKE_DIR "" CACHE PATH "Directory of CHAMELEON CMake modules, can be external to the project")
......@@ -916,6 +916,7 @@ if( CHAMELEON_SCHED_OPENMP )
endif( CHAMELEON_SCHED_OPENMP )
# getopt
unset(CMAKE_REQUIRED_LIBRARIES)
check_include_files(getopt.h CHAMELEON_HAVE_GETOPT_H)
if (CHAMELEON_HAVE_GETOPT_H)
check_function_exists(getopt_long CHAMELEON_HAVE_GETOPT_LONG)
......@@ -1019,7 +1020,7 @@ include(CTest)
if(${CMAKE_Fortran_COMPILER_ID} STREQUAL "Intel")
message(STATUS "Add -nofor_main to the Fortran linker (Intel compiler)")
set(CMAKE_Fortran_FLAGS "${CMAKE_Fortran_FLAGS} -nofor_main")
endif(_match_ifort)
endif()
# Testing executables
if(CHAMELEON_ENABLE_EXAMPLE AND NOT CHAMELEON_SIMULATION)
......@@ -1091,7 +1092,7 @@ set(CPACK_PACKAGE_VENDOR "Inria")
set(CPACK_PACKAGE_CONTACT "morse-devel@lists.gforge.inria.fr")
set(CPACK_RESOURCE_FILE_README ${CMAKE_CURRENT_SOURCE_DIR}/README.org)
set(CPACK_RESOURCE_FILE_LICENSE ${CMAKE_CURRENT_SOURCE_DIR}/LICENCE.txt)
set(CPACK_SOURCE_IGNORE_FILES "plasma-conversion;build;.cproject;.settings;.dir-locals.el;.project;.pydevproject;.svn;.git;.gitmodules;.gitlab-ci.yml")
set(CPACK_SOURCE_IGNORE_FILES "/plasma-conversion/;/build*;.cproject;.settings;.dir-locals.el;.project;.pydevproject;/.git*")
include(CPack)
......@@ -7,9 +7,9 @@
set(CTEST_PROJECT_NAME "Chameleon")
set(CTEST_NIGHTLY_START_TIME "00:00:00 GMT")
set(CTEST_DROP_METHOD "http")
set(CTEST_DROP_SITE "cdash.inria.fr")
set(CTEST_DROP_LOCATION "/CDash/submit.php?project=chameleon")
set(CTEST_DROP_METHOD "https")
set(CTEST_DROP_SITE "my.cdash.org")
set(CTEST_DROP_LOCATION "/submit.php?project=Chameleon")
set(CTEST_DROP_SITE_CDASH TRUE)
chameleon-1.0.0
chameleon-0.9.2
- chameleon is now hosted on gitlab: https://gitlab.inria.fr/solverstack/chameleon
- MAGMA kernels are no longer supported in Chameleon
- Add SVD/EVD drivers based on parallel first stage, and sequential LAPACK second stage and solve
- Add First stage algorithm fo r the SVD/EVD solvers
# @copyright 2016-2018 KAUST. All rights reserved.
......@@ -6,8 +6,8 @@
# gitlab-ci pipeline badge
#+HTML:<a href="https://gitlab.inria.fr/solverstack/chameleon/commits/master"><img alt="pipeline status"src="https://gitlab.inria.fr/solverstack/chameleon/badges/master/pipeline.svg"/></a>
# Coverity badge
#+HTML:<a href="https://scan.coverity.com/projects/chameleon"><img alt="Coverity Scan Build Status"src="https://scan.coverity.com/projects/10590/badge.svg"/></a>
# # Coverity badge
# #+HTML:<a href="https://scan.coverity.com/projects/chameleon"><img alt="Coverity Scan Build Status"src="https://scan.coverity.com/projects/10590/badge.svg"/></a>
Chameleon is a C library providing parallel algorithms to perform
BLAS/LAPACK operations exploiting fully modern architectures.
......@@ -60,14 +60,14 @@ developers must follow and that should be read by contributors.
Chameleon library started as an extension of the PLASMA library so
that code naming and writting conventions should follow [[https://bitbucket.org/icl/plasma][PLASMA]] ones.
* Packaging
* Releasing
A Chameleon's release is a source package, of the form
chameleon-major.minor.patch.tar.gz, which:
1) has been properly tested,
2) contains a generated documentation corresponding to the released version,
3) has an up-to-date ChangeLog file,
4) is published on internet.
2) has an up-to-date ChangeLog file,
3) is published on internet as a GitLab release plus an associated
git tag.
** Test Chameleon before packaging
......@@ -76,29 +76,29 @@ developers must follow and that should be read by contributors.
org-mode file) to be used on PlaFRIM plus some specific ctest
tests.
** Source tarball generation
This step requires to generate the [[sec:doc][documentation]].
#+begin_src sh
export CHAMELEON_ROOT=/path/to/chameleon/sources/to/be/released
cmake $CHAMELEON_ROOT -DCHAMELEON_ENABLE_DOC=ON
make doc
cp doc/orgmode/users_guide.pdf $CHAMELEON_ROOT
make package_source
A tarball chameleon-major.minor.patch.tar.gz should be generated
and contains the users_guide documentation.
** Publish the release on internet
A git tag must be first created, for example
#+begin_src sh
git tag -a v1.0.0 -m 'Version 1.0.0'
git push --tags
Then in the Chameleon *Tags* tab,
https://gitlab.inria.fr/solverstack/chameleon/tags, edit the
release notes and attach the tarball previously generated.
** Release generation and publication
Releases are published on GitLab automatically through the gitlab-ci
job /release/.
To create a release the workflow is:
1) ensure chameleon is ready for this release, /i.e./
- all required features are well integrated
- all tests succeed
- the ChangeLog file is up-to-date
- the version number is up-to-date in all source files
2) create and push a branch /release-major.minor.patch/,
major.minor.patch being the version number for the release
3) the gitlab-ci job should produce a new release and tag according
to the version number
- releases: https://gitlab.inria.fr/solverstack/chameleon/releases
- tags: https://gitlab.inria.fr/solverstack/chameleon/tags
4) delete the branch
* CDash tests dashboard
To see details about the tests performed during the [[https://gitlab.inria.fr/solverstack/chameleon/pipelines][pipelines]] visit
[[https://my.cdash.org/index.php?project=Chameleon][CDash]].
* Static and dynamic analysis
To see details about the analysis job performed during the
[[https://gitlab.inria.fr/solverstack/chameleon/pipelines][pipelines]] visit [[https://sonarqube.bordeaux.inria.fr/sonarqube/dashboard?id=hiepacs%3Achameleon%3Agitlab%3Asolverstack%3Amaster][Sonarqube]].
......@@ -17,7 +17,7 @@
# @version 1.0.0
# @version 0.9.2
# @version 1.0.0
# @version 0.9.2
# @date 2014-11-10
Subproject commit 376ef84365284898e734d4d8e17359981cae8b7f
Subproject commit 33a182878f9049c47af1fce3e86e72b9a10e7f7a
......@@ -17,11 +17,11 @@
# @version 1.0.0
# @version 0.9.2
# @date 2012-07-13
# @date 2014-11-16
......@@ -2,14 +2,14 @@
* @file map.c
* @copyright 2018-2018 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
* @copyright 2018-2019 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
* Univ. Bordeaux. All rights reserved.
* @brief Chameleon map wrappers
* @version 1.0.0
* @version 0.9.2
* @author Mathieu Faverge
* @date 2018-09-24
* @file pmap.c
* @brief Chameleon map parallel algorithm
* @version 1.0.0
* @version 0.9.2
* @date 2018-09-24
......@@ -4,21 +4,21 @@
* @copyright 2009-2014 The University of Tennessee and The University of
* Tennessee Research Foundation. All rights reserved.
* @copyright 2012-2018 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
* @copyright 2012-2019 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
* @brief Chameleon zbuild parallel algorithm
* @version 1.0.0
* @version 0.9.2
* @comment This file has been automatically generated
* from Plasma 2.5.0 for CHAMELEON 1.0.0
* from Plasma 2.5.0 for CHAMELEON 0.9.2
* @author Emmanuel Agullo
* @author Cedric Castagnede
* @author Guillaume Sylvand
* @date 2016-09-05
* @date 2016-09-08
* @precisions normal z -> s d c
......@@ -4,17 +4,17 @@
* @brief Chameleon zgebrd_ge2gb parallel algorithm
* @version 1.0.0
* @version 0.9.2
* @author Hatem Ltaief
* @author Azzam Haidar
* @date 2010-11-15
* @date 2016-12-09
......@@ -4,22 +4,22 @@
* @brief Chameleon zgelqf parallel algorithm
* @version 1.0.0
* @version 0.9.2
* @author Jakub Kurzak
* @date 2018-11-08
* @date 2014-11-16
* @brief Chameleon zgelqf_param parallel algorithm
* @version 1.0.0
* @version 0.9.2
* @author Raphael Boucherie
* @date 2018-11-09
* @date 2017-05-12
......@@ -4,23 +4,23 @@
