Commit 2685d4df authored by PRUVOST Florent's avatar PRUVOST Florent
simplify
parent 5e36b9b9
......@@ -270,16 +270,14 @@ endif ()
# Add math library to the list of extra
# it normally exists on all common systems provided with a C compiler
set(M_LIBRARIES "")
if(UNIX OR WIN32)
find_library(
M_m_LIBRARY
M_LIBRARY
NAMES m
mark_as_advanced(M_m_LIBRARY)
if (M_m_LIBRARY)
list(APPEND M_LIBRARIES "${M_m_LIBRARY}")
list(APPEND EXTRA_LIBRARIES "${M_m_LIBRARY}")
mark_as_advanced(M_LIBRARY)
if (M_LIBRARY)
list(APPEND EXTRA_LIBRARIES "${M_LIBRARY}")
else()
message(FATAL_ERROR "Could NOT find libm on your system."
" Are you sure to a have a C compiler installed?")
......@@ -288,16 +286,14 @@ endif()
# Try to find librt (libposix4 - POSIX.1b Realtime Extensions library)
# on Unix systems except Apple ones because it does not exist on it
set(RT_LIBRARIES "")
if(UNIX AND NOT APPLE)
find_library(
RT_rt_LIBRARY
RT_LIBRARY
NAMES rt
mark_as_advanced(RT_rt_LIBRARY)
if (RT_rt_LIBRARY)
list(APPEND RT_LIBRARIES "${RT_rt_LIBRARY}")
list(APPEND EXTRA_LIBRARIES "${RT_rt_LIBRARY}")
mark_as_advanced(RT_LIBRARY)
if (RT_LIBRARY)
list(APPEND EXTRA_LIBRARIES "${RT_LIBRARY}")
else()
message(FATAL_ERROR "Could NOT find librt on your system")
endif()
