update the CMakeLists of chameleon to be more verbose about options set,...
update the CMakeLists of chameleon to be more verbose about options set, remove set of cache for package dir (done inside Finds), remove some required non empty lists in find_package_handle_standard_args because it can be not defined in some case (without BLASEXT/LAPACKEXT)
