GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
AGULLO Emmanuel
Chameleon
1fdc9fe3
1fdc9fe3
COJEAN Terry
Explain the restriction proposition for getrf_nopiv
dcee2671
timing/time_zgetrf_nopiv_tile.c
1fdc9fe3
@@ -47,6 +47,12 @@ RunTest(int *iparam, double *dparam, morse_time_t *t_)
MORSE_zlacpy_Tile
MorseUpperLower
descA
descAC
* Consider this optimization on some heterogenous platforms and matrix sizes.
* Often, TRSM kernel on GPU yields significantly less performance rate than GEMM,
* while performances are similar on CPU. On this algorithm it is therefore
* recommended to execute all TRSMs (~low amount) on CPU to increase GPU efficiency.
//RUNTIME_zlocality_onerestrict( MORSE_TRSM, STARPU_CPU );
START_TIMING
