Commit 1d9ea4a7 authored by PRUVOST Florent's avatar PRUVOST Florent
save the exit status of kernels when possible
parent 9b9aea35
...@@ -35,12 +35,9 @@ void CORE_zlag2c_quark(Quark *quark) ...@@ -35,12 +35,9 @@ void CORE_zlag2c_quark(Quark *quark)
int ldb; int ldb;
RUNTIME_sequence_t *sequence; RUNTIME_sequence_t *sequence;
RUNTIME_request_t *request; RUNTIME_request_t *request;
int info;
quark_unpack_args_8(quark, m, n, A, lda, B, ldb, sequence, request); quark_unpack_args_8(quark, m, n, A, lda, B, ldb, sequence, request);
CORE_zlag2c( m, n, A, lda, B, ldb); CORE_zlag2c( m, n, A, lda, B, ldb);
if (sequence->status == CHAMELEON_SUCCESS && info != 0)
RUNTIME_sequence_flush(quark, sequence, request, info);
void INSERT_TASK_zlag2c(const RUNTIME_option_t *options, void INSERT_TASK_zlag2c(const RUNTIME_option_t *options,
...@@ -47,6 +47,8 @@ void INSERT_TASK_zgetrf( const RUNTIME_option_t *options, ...@@ -47,6 +47,8 @@ void INSERT_TASK_zgetrf( const RUNTIME_option_t *options,
STARPU_VALUE, &IPIV, sizeof(int*), STARPU_VALUE, &IPIV, sizeof(int*),
STARPU_VALUE, &check_info, sizeof(cham_bool_t), STARPU_VALUE, &check_info, sizeof(cham_bool_t),
STARPU_VALUE, &iinfo, sizeof(int), STARPU_VALUE, &iinfo, sizeof(int),
STARPU_VALUE, &(options->sequence), sizeof(RUNTIME_sequence_t*),
STARPU_VALUE, &(options->request), sizeof(RUNTIME_request_t*),
STARPU_PRIORITY, options->priority, STARPU_PRIORITY, options->priority,
STARPU_CALLBACK, callback, STARPU_CALLBACK, callback,
#if defined(CHAMELEON_CODELETS_HAVE_NAME) #if defined(CHAMELEON_CODELETS_HAVE_NAME)
...@@ -66,11 +68,18 @@ static void cl_zgetrf_cpu_func(void *descr[], void *cl_arg) ...@@ -66,11 +68,18 @@ static void cl_zgetrf_cpu_func(void *descr[], void *cl_arg)
int *IPIV; int *IPIV;
cham_bool_t check_info; cham_bool_t check_info;
int iinfo; int iinfo;
int info = 0; int info = 0;
A = (CHAMELEON_Complex64_t *)STARPU_MATRIX_GET_PTR(descr[0]); A = (CHAMELEON_Complex64_t *)STARPU_MATRIX_GET_PTR(descr[0]);
starpu_codelet_unpack_args(cl_arg, &m, &n, &lda, &IPIV, &check_info, &iinfo);
starpu_codelet_unpack_args(cl_arg, &m, &n, &lda, &IPIV, &check_info, &iinfo, &sequence, &request);
CORE_zgetrf( m, n, A, lda, IPIV, &info ); CORE_zgetrf( m, n, A, lda, IPIV, &info );
if ( (sequence->status == CHAMELEON_SUCCESS) && (info != 0) ) {
RUNTIME_sequence_flush( NULL, sequence, request, iinfo+info );
#endif /* !defined(CHAMELEON_SIMULATION) */ #endif /* !defined(CHAMELEON_SIMULATION) */
...@@ -113,6 +113,8 @@ void INSERT_TASK_zgetrf_incpiv(const RUNTIME_option_t *options, ...@@ -113,6 +113,8 @@ void INSERT_TASK_zgetrf_incpiv(const RUNTIME_option_t *options,
STARPU_SCRATCH, options->ws_worker, STARPU_SCRATCH, options->ws_worker,
STARPU_VALUE, &h_work, sizeof(CHAMELEON_starpu_ws_t *), STARPU_VALUE, &h_work, sizeof(CHAMELEON_starpu_ws_t *),
...@@ -134,13 +136,18 @@ static void cl_zgetrf_incpiv_cpu_func(void *descr[], void *cl_arg) ...@@ -134,13 +136,18 @@ static void cl_zgetrf_incpiv_cpu_func(void *descr[], void *cl_arg)
starpu_codelet_unpack_args(cl_arg, &m, &n, &ib, &lda, &ldl, &IPIV, &check_info, &iinfo, &h_work); starpu_codelet_unpack_args(cl_arg, &m, &n, &ib, &lda, &ldl, &IPIV, &check_info, &iinfo, &h_work, &sequence, &request);
CORE_zgetrf_incpiv(m, n, ib, A, lda, IPIV, &info); CORE_zgetrf_incpiv(m, n, ib, A, lda, IPIV, &info);
...@@ -92,6 +92,8 @@ void INSERT_TASK_zgetrf_nopiv(const RUNTIME_option_t *options, ...@@ -92,6 +92,8 @@ void INSERT_TASK_zgetrf_nopiv(const RUNTIME_option_t *options,
STARPU_RW, RTBLKADDR(A, CHAMELEON_Complex64_t, Am, An), STARPU_RW, RTBLKADDR(A, CHAMELEON_Complex64_t, Am, An),
STARPU_VALUE, &lda, sizeof(int), STARPU_VALUE, &lda, sizeof(int),
...@@ -112,11 +114,18 @@ static void cl_zgetrf_nopiv_cpu_func(void *descr[], void *cl_arg) ...@@ -112,11 +114,18 @@ static void cl_zgetrf_nopiv_cpu_func(void *descr[], void *cl_arg)
CHAMELEON_Complex64_t *A; CHAMELEON_Complex64_t *A;
int lda; int lda;
starpu_codelet_unpack_args(cl_arg, &m, &n, &ib, &lda, &iinfo);
starpu_codelet_unpack_args(cl_arg, &m, &n, &ib, &lda, &iinfo, &sequence, &request);
CORE_zgetrf_nopiv(m, n, ib, A, lda, &info); CORE_zgetrf_nopiv(m, n, ib, A, lda, &info);
...@@ -51,6 +51,8 @@ void INSERT_TASK_zpotrf(const RUNTIME_option_t *options, ...@@ -51,6 +51,8 @@ void INSERT_TASK_zpotrf(const RUNTIME_option_t *options,
/* STARPU_SCRATCH, options->ws_worker, */ /* STARPU_SCRATCH, options->ws_worker, */
...@@ -69,12 +71,18 @@ static void cl_zpotrf_cpu_func(void *descr[], void *cl_arg) ...@@ -69,12 +71,18 @@ static void cl_zpotrf_cpu_func(void *descr[], void *cl_arg)
int lda; int lda;
starpu_codelet_unpack_args(cl_arg, &uplo, &n, &lda, &iinfo); starpu_codelet_unpack_args(cl_arg, &uplo, &n, &lda, &iinfo, &sequence, &request);
CORE_zpotrf(uplo, n, A, lda, &info); CORE_zpotrf(uplo, n, A, lda, &info);
...@@ -53,6 +53,8 @@ void INSERT_TASK_ztrtri(const RUNTIME_option_t *options, ...@@ -53,6 +53,8 @@ void INSERT_TASK_ztrtri(const RUNTIME_option_t *options,
...@@ -71,12 +73,18 @@ static void cl_ztrtri_cpu_func(void *descr[], void *cl_arg) ...@@ -71,12 +73,18 @@ static void cl_ztrtri_cpu_func(void *descr[], void *cl_arg)
int LDA; int LDA;
starpu_codelet_unpack_args(cl_arg, &uplo, &diag, &N, &LDA, &iinfo);
starpu_codelet_unpack_args(cl_arg, &uplo, &diag, &N, &LDA, &iinfo, &sequence, &request);
CORE_ztrtri(uplo, diag, N, A, LDA, &info); CORE_ztrtri(uplo, diag, N, A, LDA, &info);
...@@ -130,6 +130,8 @@ void INSERT_TASK_ztstrf(const RUNTIME_option_t *options, ...@@ -130,6 +130,8 @@ void INSERT_TASK_ztstrf(const RUNTIME_option_t *options,
STARPU_VALUE, &nb, sizeof(int), STARPU_VALUE, &nb, sizeof(int),
...@@ -158,7 +160,8 @@ static void cl_ztstrf_cpu_func(void *descr[], void *cl_arg) ...@@ -158,7 +160,8 @@ static void cl_ztstrf_cpu_func(void *descr[], void *cl_arg)
int ldwork; int ldwork;
U = (CHAMELEON_Complex64_t *)STARPU_MATRIX_GET_PTR(descr[0]); U = (CHAMELEON_Complex64_t *)STARPU_MATRIX_GET_PTR(descr[0]);
...@@ -166,9 +169,15 @@ static void cl_ztstrf_cpu_func(void *descr[], void *cl_arg) ...@@ -166,9 +169,15 @@ static void cl_ztstrf_cpu_func(void *descr[], void *cl_arg)
L = (CHAMELEON_Complex64_t *)STARPU_MATRIX_GET_PTR(descr[2]); L = (CHAMELEON_Complex64_t *)STARPU_MATRIX_GET_PTR(descr[2]);
WORK = (CHAMELEON_Complex64_t *)STARPU_MATRIX_GET_PTR(descr[3]); WORK = (CHAMELEON_Complex64_t *)STARPU_MATRIX_GET_PTR(descr[3]);
starpu_codelet_unpack_args(cl_arg, &m, &n, &ib, &nb, &ldu, &lda, &ldl, &IPIV, &d_work, &ldwork, &check_info, &iinfo); starpu_codelet_unpack_args(cl_arg, &m, &n, &ib, &nb, &ldu, &lda, &ldl,
&IPIV, &d_work, &ldwork, &check_info, &iinfo,
CORE_ztstrf(m, n, ib, nb, U, ldu, A, lda, L, ldl, IPIV, WORK, ldwork, &info); CORE_ztstrf(m, n, ib, nb, U, ldu, A, lda, L, ldl, IPIV, WORK, ldwork, &info);
