Commit 1768bd25 authored by Mathieu Faverge's avatar Mathieu Faverge
Update .gitignore to include a larger list of files
parent d1031567
...@@ -2,3 +2,84 @@ ...@@ -2,3 +2,84 @@
*.pyc *.pyc
.cproject .cproject
.project .project
*.o
*.a
*.pyc
_CPack_Packages
install_manifest.txt
TAGS
build*/
# https://github.com/github/gitignore/blob/master/C.gitignore
# Prerequisites
*.d
# Object files
*.o
*.ko
*.obj
*.elf
# Linker output
*.ilk
*.map
*.exp
# Precompiled Headers
*.gch
*.pch
# Libraries
*.lib
*.a
*.la
*.lo
# Shared objects (inc. Windows DLLs)
*.dll
*.so
*.so.*
*.dylib
# Executables
*.exe
*.out
*.app
*.i*86
*.x86_64
*.hex
# Debug files
*.dSYM/
*.su
*.idb
*.pdb
# Kernel Module Compile Results
*.mod*
*.cmd
.tmp_versions/
modules.order
Module.symvers
Mkfile.old
dkms.conf
# https://github.com/github/gitignore/blob/master/CMake.gitignore
CMakeCache.txt
CMakeFiles
CMakeScripts
Testing
Makefile
cmake_install.cmake
compile_commands.json
CTestTestfile.cmake
