Commit 0df52460 authored by Mathieu Faverge's avatar Mathieu Faverge
Factorize the macro for the naming fo codelets, so we could also disable it for performance reasons
parent 1e6a1b7d
...@@ -123,7 +123,7 @@ void MORSE_TASK_zgeqrt(const MORSE_option_t *options, ...@@ -123,7 +123,7 @@ void MORSE_TASK_zgeqrt(const MORSE_option_t *options,
STARPU_VALUE, &h_work, sizeof(MORSE_starpu_ws_t *), STARPU_VALUE, &h_work, sizeof(MORSE_starpu_ws_t *),
STARPU_PRIORITY, options->priority, STARPU_PRIORITY, options->priority,
STARPU_CALLBACK, callback, STARPU_CALLBACK, callback,
#if (STARPU_MAJOR_VERSION > 1) || ((STARPU_MAJOR_VERSION == 1) && (STARPU_MINOR_VERSION > 1)) #if defined(CHAMELEON_CODELETS_HAVE_NAME)
STARPU_NAME, "zgeqrt", STARPU_NAME, "zgeqrt",
#endif #endif
0); 0);
...@@ -53,7 +53,7 @@ void MORSE_TASK_zhe2ge(const MORSE_option_t *options, ...@@ -53,7 +53,7 @@ void MORSE_TASK_zhe2ge(const MORSE_option_t *options,
STARPU_VALUE, &ldb, sizeof(int), STARPU_VALUE, &ldb, sizeof(int),
STARPU_NAME, "zhe2ge", STARPU_NAME, "zhe2ge",
#endif #endif
0); 0);
...@@ -61,7 +61,7 @@ void MORSE_TASK_zherfb(const MORSE_option_t *options, ...@@ -61,7 +61,7 @@ void MORSE_TASK_zherfb(const MORSE_option_t *options,
STARPU_VALUE, &nb, sizeof(int), STARPU_VALUE, &nb, sizeof(int),
STARPU_NAME, "zherfb", STARPU_NAME, "zherfb",
#endif #endif
0); 0);
...@@ -62,7 +62,7 @@ void MORSE_TASK_zlatro(const MORSE_option_t *options, ...@@ -62,7 +62,7 @@ void MORSE_TASK_zlatro(const MORSE_option_t *options,
STARPU_NAME, "zlatro", STARPU_NAME, "zlatro",
#endif #endif
0); 0);
...@@ -199,7 +199,7 @@ void MORSE_TASK_ztsmqr(const MORSE_option_t *options, ...@@ -199,7 +199,7 @@ void MORSE_TASK_ztsmqr(const MORSE_option_t *options,
STARPU_VALUE, &ldwork, sizeof(int), STARPU_VALUE, &ldwork, sizeof(int),
STARPU_NAME, "ztsmqr", STARPU_NAME, "ztsmqr",
#endif #endif
#if defined(CHAMELEON_USE_MPI) #if defined(CHAMELEON_USE_MPI)
...@@ -73,7 +73,7 @@ void MORSE_TASK_ztsmqr_hetra1(const MORSE_option_t *options, ...@@ -73,7 +73,7 @@ void MORSE_TASK_ztsmqr_hetra1(const MORSE_option_t *options,
STARPU_NAME, "ztsmqr_hetra1", STARPU_NAME, "ztsmqr_hetra1",
#endif #endif
0); 0);
...@@ -129,7 +129,7 @@ void MORSE_TASK_ztsqrt(const MORSE_option_t *options, ...@@ -129,7 +129,7 @@ void MORSE_TASK_ztsqrt(const MORSE_option_t *options,
STARPU_NAME, "ztsqrt", STARPU_NAME, "ztsqrt",
#endif #endif
STARPU_EXECUTE_ON_NODE, A2->get_rankof(A2, A2m, A2n), STARPU_EXECUTE_ON_NODE, A2->get_rankof(A2, A2m, A2n),
...@@ -150,7 +150,7 @@ void MORSE_TASK_zunmlq(const MORSE_option_t *options, ...@@ -150,7 +150,7 @@ void MORSE_TASK_zunmlq(const MORSE_option_t *options,
STARPU_NAME, "zunmlq", STARPU_NAME, "zunmlq",
#endif #endif
0); 0);
...@@ -172,7 +172,7 @@ void MORSE_TASK_zunmqr(const MORSE_option_t *options, ...@@ -172,7 +172,7 @@ void MORSE_TASK_zunmqr(const MORSE_option_t *options,
STARPU_NAME, "zunmqr", STARPU_NAME, "zunmqr",
#endif #endif
...@@ -64,6 +64,13 @@ typedef struct starpu_conf starpu_conf_t; ...@@ -64,6 +64,13 @@ typedef struct starpu_conf starpu_conf_t;
#endif #endif
* Enable codelets names
#define CHAMELEON_CODELETS_HAVE_NAME
#endif
* Access to block pointer and leading dimension * Access to block pointer and leading dimension
#define RTBLKADDR( desc, type, m, n ) ( (starpu_data_handle_t)RUNTIME_desc_getaddr( desc, m, n ) ) #define RTBLKADDR( desc, type, m, n ) ( (starpu_data_handle_t)RUNTIME_desc_getaddr( desc, m, n ) )
