Commit 96d8f25d authored by WILLIAMS Harvey's avatar WILLIAMS Harvey
Moved to iterator
parent ed9f2131
...@@ -82,11 +82,12 @@ impl Actor { ...@@ -82,11 +82,12 @@ impl Actor {
DispatchMessage::SendMessage { to, message} => { DispatchMessage::SendMessage { to, message} => {
// Look for senders to dispatch message to // Look for senders to dispatch message to
if let Some(senders) = self.senders.get_mut(&to) { if let Some(senders) = self.senders.get_mut(&to) {
for sender in senders.iter_mut() { senders
sender.try_send((to.clone(), message.clone())).expect("Expected sender channel to be closed and not full.") .iter_mut()
} .try_for_each(|sender| sender.try_send((to.clone(), message.clone())))
.expect("Expected sender channel to be open and not full");
} else { } else {
panic!("No sender with address {} to dispatch message to.", to); eprintln!("No sender with address {} to dispatch - Message dropped.", to);
DispatchMessage::RegisterHandler { address, respond_to } => { DispatchMessage::RegisterHandler { address, respond_to } => {
