Commit 796c5753 authored by WILLIAMS Harvey's avatar WILLIAMS Harvey
Revert "Little bit of rewording"
This reverts commit 82de5902.
parent 82de5902
...@@ -18,6 +18,6 @@ This repository might be helpful for you! ...@@ -18,6 +18,6 @@ This repository might be helpful for you!
# Prerequisites # Prerequisites
- Some basic understanding of writing async rust code. Although you can still write your application code in a synchronous manner, we opt to use it here to simplify the handling of network events. - Some basic understanding of writing async rust code. Alhough you can opt to write your application code in a synchronous manner, we opt to use it here to handle events.
- A familiarity with the actor model/pattern of writing async code (see [here](https://ryhl.io/blog/actors-with-tokio/) for a good starting point). - A familiarity with the actor model/pattern of writing async code.
\ No newline at end of file \ No newline at end of file
...@@ -8,6 +8,6 @@ pub trait Network { ...@@ -8,6 +8,6 @@ pub trait Network {
/// Send a message to the identifier specified by the 'to' field. /// Send a message to the identifier specified by the 'to' field.
fn send(&mut self, to: &str, message: Vec<u8>); fn send(&mut self, to: &str, message: Vec<u8>);
/// Generate one or more receivers to catch inbound messages. /// Wait for a message to be received
async fn recv(&mut self) -> mpsc::Receiver<(String, Vec<u8>)>; async fn recv(&mut self) -> mpsc::Receiver<(String, Vec<u8>)>;
