Une nouvelle version du portail de gestion des comptes externes sera mise en production lundi 09 août. Elle permettra d'allonger la validité d'un compte externe jusqu'à 3 ans. Pour plus de détails sur cette version consulter : https://doc-si.inria.fr/x/FCeS
Commit 6de432e2 authored by PERTIN Dimitri's avatar PERTIN Dimitri
Fix #1 - Packaging the project
parent 0f08ea50
...@@ -8,3 +8,4 @@ from concerto.transition import Transition ...@@ -8,3 +8,4 @@ from concerto.transition import Transition
from concerto.dependency import * from concerto.dependency import *
from concerto.place import * from concerto.place import *
from concerto.reconfiguration import * from concerto.reconfiguration import *
#!/usr/bin/env python
# encoding: utf-8
import sys
import os
from setuptools import setup, find_packages
if sys.version_info < (3, 6):
sys.exit("requires python 3.6 and up")
here = os.path.dirname(__file__)
pks=find_packages()
setup(name = "concerto",
version = "0.1",
description = "The implementation of the Madeus++ model in Python.",
author = "Maverick Chardet, Hélène Coullon, Christian Perez",
author_email = "maverick.chardet@inria.fr, helene.coullon@imt-atlantique.fr, christian.perez@inria.fr",
maintainer = "Maverick Chardet",
maintainer_email = "maverick.chardet@inria.fr",
license = "GPL3",
url = "https://mad.readthedocs.io",
packages = pks,
platforms = ["POSIX"],
use_2to3 = False,
zip_safe = False,
long_description = open(os.path.join(here, "README.md"), "r").read()
# encoding: utf-8
with open("README.md", "r") as fh:
long_description = fh.read()
setup(
name = "concerto",
version = "0.0.1",
description = "Preliminary implementation in Python 3 of the Concerto reconfiguration model.",
long_description = long_description,
long_description_content_type = "text/markdown",
license = "GPL3",
packages = setuptools.find_packages(),
classifier = [
"Development Status :: 4 - Beta",
"Intended Audience :: System Administrators",
"Intended Audience :: Science/Research",
"License :: OSI Approved :: GNU General Public License v3 (GPLv3)",
"Operating System :: POSIX :: Linux",
"Programming Language :: Python",
"Programming Language :: Python :: 3.6",
"Programming Language :: Python :: 3.7"
python_requires='>=3.6'
