Commit 322f0755 authored by Maverick Chardet's avatar Maverick Chardet
Inventory
parent 1a63a204
...@@ -31,6 +31,11 @@ class G5kReservation: ...@@ -31,6 +31,11 @@ class G5kReservation:
raise Exception("'g5k' key missing in configuration!") raise Exception("'g5k' key missing in configuration!")
self._g5k_deploy(config['g5k'], force_deploy=force_deployment, discover=discover_networks) self._g5k_deploy(config['g5k'], force_deploy=force_deployment, discover=discover_networks)
def generate_inventory(self, path):
from enoslib.api import generate_inventory as el_generate_inventory
el_generate_inventory(self._roles, self._networks, path)
self._inventory_path = path
@staticmethod @staticmethod
def _get_ip(g5k_address): def _get_ip(g5k_address):
from subprocess import run, PIPE from subprocess import run, PIPE
...@@ -41,7 +46,7 @@ class G5kReservation: ...@@ -41,7 +46,7 @@ class G5kReservation:
def _get_host_dict(g5k_address): def _get_host_dict(g5k_address):
return {"address": g5k_address, "ip": G5kReservation._get_ip(g5k_address)} return {"address": g5k_address, "ip": G5kReservation._get_ip(g5k_address)}
def __init__(self, conf, force_deployment=True, destroy=False, discover_networks=True): def __init__(self, conf, force_deployment=True, destroy=False, discover_networks=True, inventory_path=None):
self._config = None self._config = None
self._g5k_job = None self._g5k_job = None
self._roles = None self._roles = None
...@@ -49,6 +54,7 @@ class G5kReservation: ...@@ -49,6 +54,7 @@ class G5kReservation:
self._destroy = destroy self._destroy = destroy
self._allocate(conf, force_deployment, discover_networks) self._allocate(conf, force_deployment, discover_networks)
self._alive = True self._alive = True
self._inventory_path = inventory_path
def get_roles(self): def get_roles(self):
if not self._alive: if not self._alive:
...@@ -79,13 +85,14 @@ class G5kReservation: ...@@ -79,13 +85,14 @@ class G5kReservation:
def run_ansible( def run_ansible(
self, self,
playbooks, playbooks,
inventory_path=None, inventory_path_override=None,
extra_vars=None, extra_vars=None,
tags=None, tags=None,
on_error_continue=False, on_error_continue=False,
basedir="." basedir="."
from enoslib.api import run_ansible as enoslib_run_ansible from enoslib.api import run_ansible as enoslib_run_ansible
inventory_path = inventory_path_override if inventory_path_override else self._inventory_path
enoslib_run_ansible( enoslib_run_ansible(
inventory_path=inventory_path, inventory_path=inventory_path,
