Commit a5be0396 authored by PRUVOST Florent's avatar PRUVOST Florent
fix path for coverage
parent 01eac3c6
Pipeline #23428 passed with stages
in 7 minutes and 15 seconds
...@@ -33,8 +33,9 @@ test_pampa: ...@@ -33,8 +33,9 @@ test_pampa:
script: script:
- cd build - cd build
- make test - make test
- lcov --directory . --capture --output-file pampa.lcov - cd ..
- lcov_cobertura.py pampa.lcov --output ../pampa-coverage.xml - lcov --directory build --capture --output-file pampa.lcov
- lcov_cobertura.py pampa.lcov --output pampa-coverage.xml
only: only:
- branches - branches
- master@PaMPA/PaMPA-p - master@PaMPA/PaMPA-p
