Commit 5d418359 authored by PRUVOST Florent's avatar PRUVOST Florent
update morse cmake modules
parent 76783e20
Pipeline #23384 failed with stages
in 1 minute and 1 second
# @copyright (c) 2018 Inria. All rights reserved.
# @file FindCommon.cmake
# @project MORSE
# MORSE is a software package provided by:
# Inria Bordeaux - Sud-Ouest,
# Univ. of Tennessee,
# King Abdullah Univesity of Science and Technology
# Univ. of California Berkeley,
# Univ. of Colorado Denver.
# @version 1.0.0
# @author Florent Pruvost
# @date 13-04-2018
# clean these variables before using them in CMAKE_REQUIRED_* variables in
# check_function_exists
macro(finds_remove_duplicates)
if (REQUIRED_DEFINITIONS)
list(REMOVE_DUPLICATES REQUIRED_DEFINITIONS)
endif()
if (REQUIRED_INCDIRS)
list(REMOVE_DUPLICATES REQUIRED_INCDIRS)
endif()
if (REQUIRED_FLAGS)
list(REMOVE_DUPLICATES REQUIRED_FLAGS)
endif()
if (REQUIRED_LDFLAGS)
list(REMOVE_DUPLICATES REQUIRED_LDFLAGS)
endif()
if (REQUIRED_LIBS)
list(REVERSE REQUIRED_LIBS)
list(REMOVE_DUPLICATES REQUIRED_LIBS)
endif()
endmacro()
## @end file FindCommon
# @copyright (c) 2009-2014 The University of Tennessee and The University
# of Tennessee Research Foundation.
# All rights reserved.
# @copyright (c) 2012-2014 Inria. All rights reserved.
# @copyright (c) 2012-2014 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
# @file FindHeadersAndLibs.cmake
# @project MORSE
# @version 0.9.0
# @author Cedric Castagnede
# @author Emmanuel Agullo
# @author Mathieu Faverge
# @date 13-07-2012
# Some macros to print status when search for headers and libs
include(PrintFindStatus)
function(FindHeader _libname _header_to_find)
# save _libname upper and lower case
string(TOUPPER ${_libname} LIBNAME)
string(TOLOWER ${_libname} libname)
# Looking for include
# Add system include paths to search include
unset(_inc_env)
if(WIN32)
string(REPLACE ":" ";" _inc_env "$ENV{INCLUDE}")
else()
string(REPLACE ":" ";" _path_env "$ENV{INCLUDE}")
list(APPEND _inc_env "${_path_env}")
string(REPLACE ":" ";" _path_env "$ENV{C_INCLUDE_PATH}")
string(REPLACE ":" ";" _path_env "$ENV{CPATH}")
string(REPLACE ":" ";" _path_env "$ENV{INCLUDE_PATH}")
endif()
list(APPEND _inc_env "${CMAKE_C_IMPLICIT_INCLUDE_DIRECTORIES}")
list(REMOVE_DUPLICATES _inc_env)
# Try to find the _header_to_find in the given paths
# call cmake macro to find the header path
if(${LIBNAME}_INCDIR)
set(${LIBNAME}_${_header_to_find}_DIRS "${LIBNAME}_${_header_to_find}_DIRS-NOTFOUND")
find_path(${LIBNAME}_${_header_to_find}_DIRS
NAMES ${_header_to_find}
HINTS ${${LIBNAME}_INCDIR})
elseif(${LIBNAME}_DIR)
HINTS ${${LIBNAME}_DIR}
PATH_SUFFIXES include)
else()
HINTS ${_inc_env})
endif()
mark_as_advanced(${LIBNAME}_${_header_to_find}_DIRS)
# Print status if not found
if (NOT ${LIBNAME}_${_header_to_find}_DIRS)
Print_Find_Header_Status(${libname} ${_header_to_find})
endif ()
endfunction(FindHeader)
## @end file FindHeadersAndLibs.cmake
# @file FindInit.cmake
# @project MORSE
# @version 1.0.0
# @date 24-04-2018
# This include is required to check symbols of libs
include(CheckFunctionExists)
# This include is required to check defines in headers
include(CheckIncludeFiles)
# Factorize some piece of code
include(FindCommon)
# To find headers and libs
include(FindHeadersAndLibs)
# To transform relative path into absolute for a list of libraries
include(LibrariesAbsolutePath)
include(FindPkgconfigLibrariesAbsolutePath)
## @end file FindInit.cmake
......@@ -62,6 +62,9 @@
# (To distribute this file outside of Morse, substitute the full
# License text for the above reference.)
# Common macros to use in finds
include(FindInit)
if (NOT PTSCOTCH_FOUND)
set(PTSCOTCH_DIR "" CACHE PATH "Installation directory of PTSCOTCH library")
if (NOT PTSCOTCH_FIND_QUIETLY)
......@@ -333,6 +336,7 @@ if(PTSCOTCH_LIBRARIES)
list(APPEND REQUIRED_FLAGS "${_flag}")
endforeach()
endif()
finds_remove_duplicates()
set(CMAKE_REQUIRED_DEFINITIONS "${REQUIRED_DEFINITIONS}")
set(CMAKE_REQUIRED_FLAGS "${REQUIRED_FLAGS}")
set(CMAKE_REQUIRED_LIBRARIES)
......@@ -353,9 +357,6 @@ if(PTSCOTCH_LIBRARIES)
set(PTSCOTCH_INCLUDE_DIRS_DEP "${REQUIRED_INCDIRS}")
set(PTSCOTCH_CFLAGS_OTHER_DEP "${REQUIRED_FLAGS}")
set(PTSCOTCH_LDFLAGS_OTHER_DEP "${REQUIRED_LDFLAGS}")
list(REMOVE_DUPLICATES PTSCOTCH_LIBRARY_DIRS_DEP)
list(REMOVE_DUPLICATES PTSCOTCH_CFLAGS_OTHER_DEP)
list(REMOVE_DUPLICATES PTSCOTCH_LDFLAGS_OTHER_DEP)
else()
if(NOT PTSCOTCH_FIND_QUIETLY)
message(STATUS "Looking for PTSCOTCH : test of SCOTCH_dgraphInit with PTSCOTCH library fails")
# @file FindPkgconfigLibrariesAbsolutePath.cmake
# @project MORSE
# @version 1.0.0
# @date 06-04-2018
# Transform relative path into absolute path for libraries found with the
# pkg_search_module cmake macro
# _prefix: the name of the CMake variable used when pkg_search_module was called
# e.g. for pkg_search_module(BLAS blas) _prefix would be BLAS
macro(FIND_PKGCONFIG_LIBRARIES_ABSOLUTE_PATH _prefix)
if(WIN32)
string(REPLACE ":" ";" _lib_env "$ENV{LIB}")
elseif(APPLE)
string(REPLACE ":" ";" _lib_env "$ENV{DYLD_LIBRARY_PATH}")
else()
string(REPLACE ":" ";" _lib_env "$ENV{LD_LIBRARY_PATH}")
endif()
list(APPEND _lib_env "${CMAKE_C_IMPLICIT_LINK_DIRECTORIES}")
# non static case
set(${_prefix}_LIBRARIES_COPY "${${_prefix}_LIBRARIES}")
set(${_prefix}_LIBRARIES "")
foreach(_library ${${_prefix}_LIBRARIES_COPY})
if(EXISTS "${_library}")
list(APPEND ${_prefix}_LIBRARIES ${_library})
else()
get_filename_component(_ext "${_library}" EXT)
set(_lib_extensions ".so" ".a" ".dyld" ".dll")
list(FIND _lib_extensions "${_ext}" _index)
if (${_index} GREATER -1)
get_filename_component(_library "${_library}" NAME_WE)
endif()
find_library(_library_path NAMES ${_library}
HINTS ${${_prefix}_LIBDIR} ${${_prefix}_LIBRARY_DIRS} ${_lib_env})
if (_library_path)
list(APPEND ${_prefix}_LIBRARIES ${_library_path})
else()
message(FATAL_ERROR "Dependency of ${_prefix} '${_library}' NOT FOUND")
endif()
unset(_library_path CACHE)
endif()
endforeach()
set (${_prefix}_LIBRARIES "${${_prefix}_LIBRARIES}" CACHE INTERNAL "" FORCE)
## static case
#set(${_prefix}_STATIC_LIBRARIES_COPY "${${_prefix}_STATIC_LIBRARIES}")
#set(${_prefix}_STATIC_LIBRARIES "")
#foreach(_library ${${_prefix}_STATIC_LIBRARIES_COPY})
# if(EXISTS "${_library}")
# list(APPEND ${_prefix}_STATIC_LIBRARIES ${_library})
# else()
# get_filename_component(_ext "${_library}" EXT)
# set(_lib_extensions ".so" ".a" ".dyld" ".dll")
# list(FIND _lib_extensions "${_ext}" _index)
# if (${_index} GREATER -1)
# get_filename_component(_library "${_library}" NAME_WE)
# endif()
# # try static first
# set (default_find_library_suffixes ${CMAKE_FIND_LIBRARY_SUFFIXES})
# set (CMAKE_FIND_LIBRARY_SUFFIXES ${CMAKE_STATIC_LIBRARY_SUFFIX})
# find_library(_library_path NAMES ${_library}
# HINTS ${${_prefix}_STATIC_LIBDIR} ${${_prefix}_STATIC_LIBRARY_DIRS} ${_lib_env})
# set (CMAKE_FIND_LIBRARY_SUFFIXES ${default_find_library_suffixes})
# # if not found try dynamic
# if (NOT _library_path)
# endif()
# if (_library_path)
# list(APPEND ${_prefix}_STATIC_LIBRARIES ${_library_path})
# else()
# message(FATAL_ERROR "Dependency of ${_prefix} '${_library}' NOT FOUND")
# endif()
# unset(_library_path CACHE)
# endif()
#endforeach()
#set (${_prefix}_STATIC_LIBRARIES "${${_prefix}_STATIC_LIBRARIES}" CACHE INTERNAL "" FORCE)
endmacro()
## @end file FindPkgconfigLibrariesAbsolutePath.cmake
......@@ -51,6 +51,9 @@
include(FindInit)
if (NOT SCOTCH_FOUND)
set(SCOTCH_DIR "" CACHE PATH "Installation directory of SCOTCH library")
if (NOT SCOTCH_FIND_QUIETLY)
......@@ -270,7 +273,7 @@ if(SCOTCH_LIBRARIES)
if(RT_LIBRARY)
list(APPEND REQUIRED_LIBS "${RT_LIBRARY}")
endif()
# set required libraries for link
set(CMAKE_REQUIRED_INCLUDES "${REQUIRED_INCDIRS}")
# - Some macros to print status when search for headers and libs
# Main parameters of macros
# _libname: name of the lib you seek, foo for example
# _header_to_find: name of the header you seek, foo.h for example
# _lib_to_find: name of the library you seek, libfoo for example
# _pc_to_find: name of the pkg-config file zyou seek, foo.pc for example
# Copyright 2012-2013 Inria
# Copyright 2012-2013 Emmanuel Agullo
# Copyright 2012-2013 Mathieu Faverge
# Copyright 2012 Cedric Castagnede
# Copyright 2013 Florent Pruvost
# Distributed under the OSI-approved BSD License (the "License");
# see accompanying file MORSE-Copyright.txt for details.
# This software is distributed WITHOUT ANY WARRANTY; without even the
# implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
# See the License for more information.
# Set some colors
#if(NOT WIN32)
# string(ASCII 27 Esc)
# set(ColourReset "${Esc}[m")
# set(ColourBold "${Esc}[1m")
# set(Red "${Esc}[31m")
# set(Green "${Esc}[32m")
# set(Yellow "${Esc}[33m")
# set(Blue "${Esc}[34m")
# set(Magenta "${Esc}[35m")
# set(Cyan "${Esc}[36m")
# set(White "${Esc}[37m")
# set(BoldRed "${Esc}[1;31m")
# set(BoldGreen "${Esc}[1;32m")
# set(BoldYellow "${Esc}[1;33m")
# set(BoldBlue "${Esc}[1;34m")
# set(BoldMagenta "${Esc}[1;35m")
# set(BoldCyan "${Esc}[1;36m")
# set(BoldWhite "${Esc}[1;37m")
#endif()
# This macro informs why the _header_to_find file has not been found
macro(Print_Find_Header_Status _libname _header_to_find)
# print status
#message(" ")
message("${Blue}${LIBNAME}_INCDIR is defined but ${_header_to_find}"
"has not been found in ${${LIBNAME}_INCDIR}${ColourReset}")
else()
if(${LIBNAME}_DIR)
message("${Blue}${LIBNAME}_DIR is defined but"
"${_header_to_find} has not been found in"
"${${LIBNAME}_DIR}/include${ColourReset}")
else()
message("${Blue}${_header_to_find} not found."
"Nor ${LIBNAME}_DIR neither ${LIBNAME}_INCDIR"
"are defined so that we looked for ${_header_to_find} in"
"system paths (INCLUDE, CPATH, C_INCLUDE_PATH,"
"INCLUDE_PATH, CMAKE_C_IMPLICIT_INCLUDE_DIRECTORIES)${ColourReset}")
if(_inc_env)
message("${Blue}${_header_to_find} has not been found in"
"${_inc_env}${ColourReset}")
endif()
endif()
endif()
message("${BoldBlue}Please indicate where to find ${_header_to_find}. You have three options:\n"
"- Option 1: Provide the root directory of the library with cmake option: -D${LIBNAME}_DIR=your/path/to/${libname}/\n"
"- Option 2: Provide the directory where to find the headers with cmake option: -D${LIBNAME}_INCDIR=your/path/to/${libname}/include/\n"
"- Option 3: Update your environment variable (INCLUDE or CPATH)\n"
"- Option 4: If your library provides a PkgConfig file, make sure pkg-config finds your library${ColourReset}")
#message(" ")
endmacro()
# This macro informs why the _lib_to_find file has not been found
macro(Print_Find_Library_Status _libname _lib_to_find)
# save _libname upper/lower case
# print status
#message(" ")
if(${LIBNAME}_LIBDIR)
message("${Yellow}${LIBNAME}_LIBDIR is defined but ${_lib_to_find}"
"has not been found in ${${LIBNAME}_LIBDIR}${ColourReset}")
else()
if(${LIBNAME}_DIR)
message("${Yellow}${LIBNAME}_DIR is defined but ${_lib_to_find}"
"has not been found in ${${LIBNAME}_DIR}/lib(or /lib32 or"
"/lib64)${ColourReset}")
else()
message("${Yellow}${_lib_to_find} not found."
"Nor ${LIBNAME}_DIR neither ${LIBNAME}_LIBDIR"
"are defined so that we looked for ${_lib_to_find} in"
"system paths (Linux: LD_LIBRARY_PATH, Windows: LIB,"
"Mac: DYLD_LIBRARY_PATH,"
"CMAKE_C_IMPLICIT_LINK_DIRECTORIES)${ColourReset}")
if(_lib_env)
message("${Yellow}${_lib_to_find} has not been found in"
"${_lib_env}${ColourReset}")
endif()
endif()
endif()
message("${BoldYellow}Please indicate where to find ${_lib_to_find}. You have three options:\n"
"- Option 2: Provide the directory where to find the library with cmake option: -D${LIBNAME}_LIBDIR=your/path/to/${libname}/lib/\n"
"- Option 3: Update your environment variable (Linux: LD_LIBRARY_PATH, Windows: LIB, Mac: DYLD_LIBRARY_PATH)\n"
endmacro()
macro(Print_Find_Library_Blas_Status _libname _lib_to_find)
# print status
#message(" ")
"has not been found in ${ARGN}${ColourReset}")
else()
if(${LIBNAME}_DIR)
else()
"are defined so that we look for ${_lib_to_find} in"
if(_lib_env)
endif()
endif()
endif()
endmacro()
macro(Print_Find_Library_Blas_CheckFunc_Status _name)
string(TOUPPER ${_name} FUNCNAME)
string(TOLOWER ${_name} funcname)
# print status
#message(" ")
message("${Red}Libs have been found but check of symbol ${_name} failed "
"with following libraries ${ARGN}${ColourReset}")
message("${BoldRed}Please open your error file CMakeFiles/CMakeError.log"
"to figure out why it fails${ColourReset}")
#message(" ")
endmacro()
# This macro informs that _pc_to_find file has not been found in the list
# path you give as last argument (read in ${ARGN})
# ex: Print_Find_Pkgconfig_Status(foo foo.pc ${PATHLIST}
macro(Print_Find_Pkgconfig_Status _libname _pc_to_find)
# save _libname lower case
# print status
#message(" ")
message("${Magenta}${_pc_to_find} has not been found in"
"${ARGN}${ColourReset}")
message("${BoldMagenta}If you really want to use the pkg-config file of"
"${libname}, please update your PKG_CONFIG_PATH with the path"
"where ${_pc_to_find} states${ColourReset}")
#message(" ")
endmacro()
