Commit dd3fc86f authored by GILLES Sebastien's avatar GILLES Sebastien
#1427 Remove libmesh6, and link with external libmesh 7 instead. Not fully...
#1427 Remove libmesh6, and link with external libmesh 7 instead. Not fully working at the moment: many tests fails...
parent 24b087af
...@@ -59,7 +59,8 @@ include_directories(${CMAKE_CURRENT_SOURCE_DIR}/Sources / ...@@ -59,7 +59,8 @@ include_directories(${CMAKE_CURRENT_SOURCE_DIR}/Sources /
${PETSC_INCL_DIR} / ${PETSC_INCL_DIR} /
${PARMETIS_INCL_DIR} / ${PARMETIS_INCL_DIR} /
${LUA_INCL_DIR} / ${LUA_INCL_DIR} /
${BOOST_INCL_DIR} ${BOOST_INCL_DIR} /
${LIBMESH_INCL_DIR}
...@@ -70,6 +71,8 @@ morefem_find_library(LIB_PETSC "petsc" ${PETSC_LIB_DIR} "Petsc") ...@@ -70,6 +71,8 @@ morefem_find_library(LIB_PETSC "petsc" ${PETSC_LIB_DIR} "Petsc")
morefem_find_library(LIB_PARMETIS "parmetis" ${PARMETIS_LIB_DIR} "Parmetis") morefem_find_library(LIB_PARMETIS "parmetis" ${PARMETIS_LIB_DIR} "Parmetis")
morefem_find_library(LIB_METIS "metis" ${PARMETIS_LIB_DIR} "Metis") morefem_find_library(LIB_METIS "metis" ${PARMETIS_LIB_DIR} "Metis")
morefem_find_library(LIB_LUA "lua" ${LUA_LIB_DIR} "Lua") morefem_find_library(LIB_LUA "lua" ${LUA_LIB_DIR} "Lua")
morefem_find_library(LIB_LIBMESH "Meshb" ${LIBMESH_LIB_DIR} "Libmeshb")
morefem_find_library(LIB_BOOST_FILESYSTEM "boost_filesystem" ${BOOST_LIB_DIR} "Boost filesystem") morefem_find_library(LIB_BOOST_FILESYSTEM "boost_filesystem" ${BOOST_LIB_DIR} "Boost filesystem")
morefem_find_library(LIB_BOOST_SYSTEM "boost_system" ${BOOST_LIB_DIR} "Boost system") morefem_find_library(LIB_BOOST_SYSTEM "boost_system" ${BOOST_LIB_DIR} "Boost system")
...@@ -98,6 +101,7 @@ set(MOREFEM_COMMON_DEP ...@@ -98,6 +101,7 @@ set(MOREFEM_COMMON_DEP
${LIB_BOOST_SYSTEM} ${LIB_BOOST_SYSTEM}
${LIB_BLAS} ${LIB_BLAS}
${LIB_LUA} ${LIB_LUA}
${LIB_LIBMESH}
...@@ -493,8 +493,6 @@ ...@@ -493,8 +493,6 @@
BE2CD36E1CCFA8790040CA19 /* MatrixInfo.cpp in Sources */ = {isa = PBXBuildFile; fileRef = BE2CD36B1CCFA8790040CA19 /* MatrixInfo.cpp */; }; BE2CD36E1CCFA8790040CA19 /* MatrixInfo.cpp in Sources */ = {isa = PBXBuildFile; fileRef = BE2CD36B1CCFA8790040CA19 /* MatrixInfo.cpp */; };
BE2CD36F1CCFA8790040CA19 /* MatrixInfo.hpp in Headers */ = {isa = PBXBuildFile; fileRef = BE2CD36C1CCFA8790040CA19 /* MatrixInfo.hpp */; }; BE2CD36F1CCFA8790040CA19 /* MatrixInfo.hpp in Headers */ = {isa = PBXBuildFile; fileRef = BE2CD36C1CCFA8790040CA19 /* MatrixInfo.hpp */; };
BE2CD3701CCFA8790040CA19 /* MatrixInfo.hxx in Headers */ = {isa = PBXBuildFile; fileRef = BE2CD36D1CCFA8790040CA19 /* MatrixInfo.hxx */; }; BE2CD3701CCFA8790040CA19 /* MatrixInfo.hxx in Headers */ = {isa = PBXBuildFile; fileRef = BE2CD36D1CCFA8790040CA19 /* MatrixInfo.hxx */; };
BE2DCB521C7477430070090E /* libmesh6.c in Sources */ = {isa = PBXBuildFile; fileRef = BE2DCB431C7477420070090E /* libmesh6.c */; settings = {COMPILER_FLAGS = "-w"; }; };
BE2DCB531C7477430070090E /* libmesh6.h in Headers */ = {isa = PBXBuildFile; fileRef = BE2DCB441C7477420070090E /* libmesh6.h */; };
BE2ED6A91CB3DD7C00D00CBF /* Comp1.cpp in Sources */ = {isa = PBXBuildFile; fileRef = BE510D721CB3D44900E953FE /* Comp1.cpp */; }; BE2ED6A91CB3DD7C00D00CBF /* Comp1.cpp in Sources */ = {isa = PBXBuildFile; fileRef = BE510D721CB3D44900E953FE /* Comp1.cpp */; };
BE2ED6AA1CB3DD7C00D00CBF /* Comp12.cpp in Sources */ = {isa = PBXBuildFile; fileRef = BE510D741CB3D44900E953FE /* Comp12.cpp */; }; BE2ED6AA1CB3DD7C00D00CBF /* Comp12.cpp in Sources */ = {isa = PBXBuildFile; fileRef = BE510D741CB3D44900E953FE /* Comp12.cpp */; };
BE2ED6AB1CB3DD7C00D00CBF /* Comp123.cpp in Sources */ = {isa = PBXBuildFile; fileRef = BE510D761CB3D44900E953FE /* Comp123.cpp */; }; BE2ED6AB1CB3DD7C00D00CBF /* Comp123.cpp in Sources */ = {isa = PBXBuildFile; fileRef = BE510D761CB3D44900E953FE /* Comp123.cpp */; };
...@@ -3371,8 +3369,6 @@ ...@@ -3371,8 +3369,6 @@
BE2D0C7118E08622005E8E51 /* Interface.hpp */ = {isa = PBXFileReference; lastKnownFileType = sourcecode.cpp.h; path = Interface.hpp; sourceTree = "<group>"; }; BE2D0C7118E08622005E8E51 /* Interface.hpp */ = {isa = PBXFileReference; lastKnownFileType = sourcecode.cpp.h; path = Interface.hpp; sourceTree = "<group>"; };
BE2D51D219A736CC00F6D10B /* TimeKeep.cpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.cpp; path = TimeKeep.cpp; sourceTree = "<group>"; }; BE2D51D219A736CC00F6D10B /* TimeKeep.cpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.cpp; path = TimeKeep.cpp; sourceTree = "<group>"; };
BE2D51D319A736CC00F6D10B /* TimeKeep.hpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.h; path = TimeKeep.hpp; sourceTree = "<group>"; }; BE2D51D319A736CC00F6D10B /* TimeKeep.hpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.h; path = TimeKeep.hpp; sourceTree = "<group>"; };
BE2DCB431C7477420070090E /* libmesh6.c */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.c.c; path = libmesh6.c; sourceTree = "<group>"; };
BE2DCB441C7477420070090E /* libmesh6.h */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.c.h; path = libmesh6.h; sourceTree = "<group>"; };
BE2ED6B91CB3E15600D00CBF /* DofStorage.cpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.cpp; name = DofStorage.cpp; path = Internal/DofStorage.cpp; sourceTree = "<group>"; }; BE2ED6B91CB3E15600D00CBF /* DofStorage.cpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.cpp; name = DofStorage.cpp; path = Internal/DofStorage.cpp; sourceTree = "<group>"; };
BE2ED6BA1CB3E15600D00CBF /* DofStorage.hpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.h; name = DofStorage.hpp; path = Internal/DofStorage.hpp; sourceTree = "<group>"; }; BE2ED6BA1CB3E15600D00CBF /* DofStorage.hpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.h; name = DofStorage.hpp; path = Internal/DofStorage.hpp; sourceTree = "<group>"; };
BE2ED6BB1CB3E15600D00CBF /* DofStorage.hxx */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.h; name = DofStorage.hxx; path = Internal/DofStorage.hxx; sourceTree = "<group>"; }; BE2ED6BB1CB3E15600D00CBF /* DofStorage.hxx */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.h; name = DofStorage.hxx; path = Internal/DofStorage.hxx; sourceTree = "<group>"; };
...@@ -4692,6 +4688,7 @@ ...@@ -4692,6 +4688,7 @@
BEEABA4B1A49BC8700A875C6 /* Ensight6.cpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.cpp; path = Ensight6.cpp; sourceTree = "<group>"; }; BEEABA4B1A49BC8700A875C6 /* Ensight6.cpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.cpp; path = Ensight6.cpp; sourceTree = "<group>"; };
BEEABA4C1A49BC8700A875C6 /* Ensight6.hpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.h; path = Ensight6.hpp; sourceTree = "<group>"; }; BEEABA4C1A49BC8700A875C6 /* Ensight6.hpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.h; path = Ensight6.hpp; sourceTree = "<group>"; };
BEEABA4D1A49BC8700A875C6 /* Ensight6.hxx */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.h; path = Ensight6.hxx; sourceTree = "<group>"; }; BEEABA4D1A49BC8700A875C6 /* Ensight6.hxx */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.h; path = Ensight6.hxx; sourceTree = "<group>"; };
BEEBEAD722A7C03800D56393 /* CMakeLists.txt */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = text; path = CMakeLists.txt; sourceTree = "<group>"; };
BEEF00D81CE4D021002EF0C6 /* GeometricEltList.cpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.cpp; path = GeometricEltList.cpp; sourceTree = "<group>"; }; BEEF00D81CE4D021002EF0C6 /* GeometricEltList.cpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.cpp; path = GeometricEltList.cpp; sourceTree = "<group>"; };
BEEF00D91CE4D021002EF0C6 /* GeometricEltList.hpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.h; path = GeometricEltList.hpp; sourceTree = "<group>"; }; BEEF00D91CE4D021002EF0C6 /* GeometricEltList.hpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.h; path = GeometricEltList.hpp; sourceTree = "<group>"; };
BEEFEF72196ECCC000C80FF1 /* Matrix.cpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.cpp; path = Matrix.cpp; sourceTree = "<group>"; }; BEEFEF72196ECCC000C80FF1 /* Matrix.cpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.cpp; path = Matrix.cpp; sourceTree = "<group>"; };
...@@ -6639,15 +6636,6 @@ ...@@ -6639,15 +6636,6 @@
path = TimeKeep; path = TimeKeep;
sourceTree = "<group>"; sourceTree = "<group>";
BE2DCB401C7477420070090E /* Lm6 */ = {
isa = PBXGroup;
children = (
BE2DCB431C7477420070090E /* libmesh6.c */,
BE2DCB441C7477420070090E /* libmesh6.h */,
path = Lm6;
BE2EEA3E1DB4B7CB00AF0D62 /* Advanced */ = { BE2EEA3E1DB4B7CB00AF0D62 /* Advanced */ = {
isa = PBXGroup; isa = PBXGroup;
children = ( children = (
...@@ -9503,8 +9491,8 @@ ...@@ -9503,8 +9491,8 @@
BEB9663B1A1E131000674EB7 /* Source */ = { BEB9663B1A1E131000674EB7 /* Source */ = {
BEEBEAD722A7C03800D56393 /* CMakeLists.txt */,
BE1457F21E54BC47000A2BF5 /* Tclap */, BE1457F21E54BC47000A2BF5 /* Tclap */,
BE2DCB401C7477420070090E /* Lm6 */,
path = Source; path = Source;
...@@ -11086,7 +11074,6 @@ ...@@ -11086,7 +11074,6 @@
BE5657411D3CD7470091F063 /* Array.hpp in Headers */, BE5657411D3CD7470091F063 /* Array.hpp in Headers */,
BE90E1C41A2492AA00CCAFDE /* SubVector.hxx in Headers */, BE90E1C41A2492AA00CCAFDE /* SubVector.hxx in Headers */,
BE41A8C61A24AA30004E4312 /* Parmetis.hpp in Headers */, BE41A8C61A24AA30004E4312 /* Parmetis.hpp in Headers */,
BE2DCB531C7477430070090E /* libmesh6.h in Headers */,
BE1459FF1E54BC49000A2BF5 /* CmdLine.h in Headers */, BE1459FF1E54BC49000A2BF5 /* CmdLine.h in Headers */,
BE90E17B1A24926E00CCAFDE /* Singleton.hpp in Headers */, BE90E17B1A24926E00CCAFDE /* Singleton.hpp in Headers */,
BE145A121E54BC49000A2BF5 /* XorHandler.h in Headers */, BE145A121E54BC49000A2BF5 /* XorHandler.h in Headers */,
...@@ -12577,7 +12564,6 @@ ...@@ -12577,7 +12564,6 @@
BE110EA31E11514200D2D2C8 /* VectorHelper.cpp in Sources */, BE110EA31E11514200D2D2C8 /* VectorHelper.cpp in Sources */,
BE90E1711A24926E00CCAFDE /* String.cpp in Sources */, BE90E1711A24926E00CCAFDE /* String.cpp in Sources */,
BEDEB9281C3C073100B1C71B /* Umfpack.cpp in Sources */, BEDEB9281C3C073100B1C71B /* Umfpack.cpp in Sources */,
BE2DCB521C7477430070090E /* libmesh6.c in Sources */,
BE8ADFAC1F05668100DB6762 /* BaseMatrix.cpp in Sources */, BE8ADFAC1F05668100DB6762 /* BaseMatrix.cpp in Sources */,
BE3D12C21D9B1FFB00F900F5 /* SnesConvergenceReason.cpp in Sources */, BE3D12C21D9B1FFB00F900F5 /* SnesConvergenceReason.cpp in Sources */,
BE90E1941A24929A00CCAFDE /* TimeKeep.cpp in Sources */, BE90E1941A24929A00CCAFDE /* TimeKeep.cpp in Sources */,
include(${CMAKE_CURRENT_LIST_DIR}/Lm6/CMakeLists.txt) include(${CMAKE_CURRENT_LIST_DIR}/Seldon/CMakeLists.txt)
\ No newline at end of file
# Neutralize warning for this source file.
set_source_files_properties(
${CMAKE_CURRENT_LIST_DIR}//libmesh6.c PROPERTIES COMPILE_FLAGS "-w"
target_sources(${MOREFEM_UTILITIES}
PRIVATE
${CMAKE_CURRENT_LIST_DIR}/libmesh6.c
#PUBLIC
${CMAKE_CURRENT_LIST_DIR}/libmesh6.h
GNU LESSER GENERAL PUBLIC LICENSE
Version 3, 29 June 2007
Copyright (C) 2007 Free Software Foundation, Inc. <http://fsf.org/>
Everyone is permitted to copy and distribute verbatim copies
of this license document, but changing it is not allowed.
This version of the GNU Lesser General Public License incorporates
the terms and conditions of version 3 of the GNU General Public
License, supplemented by the additional permissions listed below.
0. Additional Definitions.
As used herein, "this License" refers to version 3 of the GNU Lesser
General Public License, and the "GNU GPL" refers to version 3 of the GNU
General Public License.
"The Library" refers to a covered work governed by this License,
other than an Application or a Combined Work as defined below.
An "Application" is any work that makes use of an interface provided
by the Library, but which is not otherwise based on the Library.
Defining a subclass of a class defined by the Library is deemed a mode
of using an interface provided by the Library.
A "Combined Work" is a work produced by combining or linking an
Application with the Library. The particular version of the Library
with which the Combined Work was made is also called the "Linked
Version".
The "Minimal Corresponding Source" for a Combined Work means the
Corresponding Source for the Combined Work, excluding any source code
for portions of the Combined Work that, considered in isolation, are
based on the Application, and not on the Linked Version.
The "Corresponding Application Code" for a Combined Work means the
object code and/or source code for the Application, including any data
and utility programs needed for reproducing the Combined Work from the
Application, but excluding the System Libraries of the Combined Work.
1. Exception to Section 3 of the GNU GPL.
You may convey a covered work under sections 3 and 4 of this License
without being bound by section 3 of the GNU GPL.
2. Conveying Modified Versions.
If you modify a copy of the Library, and, in your modifications, a
facility refers to a function or data to be supplied by an Application
that uses the facility (other than as an argument passed when the
facility is invoked), then you may convey a copy of the modified
version:
a) under this License, provided that you make a good faith effort to
ensure that, in the event an Application does not supply the
function or data, the facility still operates, and performs
whatever part of its purpose remains meaningful, or
b) under the GNU GPL, with none of the additional permissions of
this License applicable to that copy.
3. Object Code Incorporating Material from Library Header Files.
The object code form of an Application may incorporate material from
a header file that is part of the Library. You may convey such object
code under terms of your choice, provided that, if the incorporated
material is not limited to numerical parameters, data structure
layouts and accessors, or small macros, inline functions and templates
(ten or fewer lines in length), you do both of the following:
a) Give prominent notice with each copy of the object code that the
Library is used in it and that the Library and its use are
covered by this License.
b) Accompany the object code with a copy of the GNU GPL and this license
document.
4. Combined Works.
You may convey a Combined Work under terms of your choice that,
taken together, effectively do not restrict modification of the
portions of the Library contained in the Combined Work and reverse
engineering for debugging such modifications, if you also do each of
the following:
a) Give prominent notice with each copy of the Combined Work that
the Library is used in it and that the Library and its use are
b) Accompany the Combined Work with a copy of the GNU GPL and this license
document.
c) For a Combined Work that displays copyright notices during
execution, include the copyright notice for the Library among
these notices, as well as a reference directing the user to the
copies of the GNU GPL and this license document.
d) Do one of the following:
0) Convey the Minimal Corresponding Source under the terms of this
License, and the Corresponding Application Code in a form
suitable for, and under terms that permit, the user to
recombine or relink the Application with a modified version of
the Linked Version to produce a modified Combined Work, in the
manner specified by section 6 of the GNU GPL for conveying
Corresponding Source.
1) Use a suitable shared library mechanism for linking with the
Library. A suitable mechanism is one that (a) uses at run time
a copy of the Library already present on the user's computer
system, and (b) will operate properly with a modified version
of the Library that is interface-compatible with the Linked
Version.
e) Provide Installation Information, but only if you would otherwise
be required to provide such information under section 6 of the
GNU GPL, and only to the extent that such information is
necessary to install and execute a modified version of the
Combined Work produced by recombining or relinking the
Application with a modified version of the Linked Version. (If
you use option 4d0, the Installation Information must accompany
the Minimal Corresponding Source and Corresponding Application
Code. If you use option 4d1, you must provide the Installation
Information in the manner specified by section 6 of the GNU GPL
for conveying Corresponding Source.)
5. Combined Libraries.
You may place library facilities that are a work based on the
Library side by side in a single library together with other library
facilities that are not Applications and are not covered by this
License, and convey such a combined library under terms of your
choice, if you do both of the following:
a) Accompany the combined library with a copy of the same work based
on the Library, uncombined with any other library facilities,
conveyed under the terms of this License.
b) Give prominent notice with the combined library that part of it
is a work based on the Library, and explaining where to find the
accompanying uncombined form of the same work.
6. Revised Versions of the GNU Lesser General Public License.
The Free Software Foundation may publish revised and/or new versions
of the GNU Lesser General Public License from time to time. Such new
versions will be similar in spirit to the present version, but may
differ in detail to address new problems or concerns.
Each version is given a distinguishing version number. If the
Library as you received it specifies that a certain numbered version
of the GNU Lesser General Public License "or any later version"
applies to it, you have the option of following the terms and
conditions either of that published version or of any later version
published by the Free Software Foundation. If the Library as you
received it does not specify a version number of the GNU Lesser
General Public License, you may choose any version of the GNU Lesser
General Public License ever published by the Free Software Foundation.
If the Library as you received it specifies that a proxy can decide
whether future versions of the GNU Lesser General Public License shall
apply, that proxy's public statement of acceptance of any version is
permanent authorization for you to choose that version for the
Library.
This diff is collapsed.
/* BB2SOL */
/* Description: convert a .bb or .BB file in .sol */
/* Author: Loic MARECHAL */
/* Creation date: mar 8 2004 */
/* Last modification: feb 26 2007 */
/* Includes */
#include <libmesh5.h>
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
/* Local defines */
#define bb 1
#define BB 2
/* Check args and copy each fields from infile to outfile */
main(int ArgCnt, char **ArgVec)
int i, j, NmbLin, NmbTyp, TypTab[ GmfMaxTyp ], InpTyp, SolEleTyp, SolSiz=0, dim, idx=0, SolIdx, BBIter;
float buf[ GmfMaxTyp ], BBTime;
char *InpNam, *OutNam, *TypStr;
FILE *hdl;
/* Parse command-line arguments */
switch(ArgCnt)
case 1 :
printf("\nBB2SOL v1.2, feb 26 2007, written by Loic MARECHAL\n");
printf(" Usage : bb2sol source_name.bb destination_name.solb support_element\n");
printf(" where support_element is : ver | edg | qad | tet | pen | hex\n\n");
return(0);
}break;
case 2 : case 3 :
fprintf(stderr,"Wrong number of arguments.\n");
return(1);
}break;
case 4 :
InpNam = *++ArgVec;
OutNam = *++ArgVec;
TypStr = *++ArgVec;
if(strstr(TypStr, "ver"))
SolEleTyp = GmfSolAtVertices;
else if(strstr(TypStr, "edg"))
SolEleTyp = GmfSolAtEdges;
else if(strstr(TypStr, "tri"))
SolEleTyp = GmfSolAtTriangles;
else if(strstr(TypStr, "qad"))
SolEleTyp = GmfSolAtQuadrilaterals;
else if(strstr(TypStr, "tet"))
SolEleTyp = GmfSolAtTetrahedra;
else if(strstr(TypStr, "pen"))
SolEleTyp = GmfSolAtPentahedra;
else if(strstr(TypStr, "hex"))
SolEleTyp = GmfSolAtHexahedra;
else
fprintf(stderr,"Wrong type of element : %s\n", TypStr);
return(1);
}break;
/* Open the .bb or .BB file for reading */
if(strstr(InpNam, ".bb"))
InpTyp = bb;
else if(strstr(InpNam, ".BB"))
InpTyp = BB;
else
fprintf(stderr,"Source of error : BB2SOL / OPEN_BB\n");
fprintf(stderr,"%s is not a .bb nor a .BB file\n", InpNam);
return(1);
if(!(hdl = fopen(InpNam, "r")))
fprintf(stderr,"Cannot open %s\n", InpNam);
return(1);
/* Read and check the dimension */
fscanf(hdl, "%d", &dim);
if( (dim != 3) && (dim != 2) )
fprintf(stderr,"Source of error : BB2SOL / READ_BB\n");
fprintf(stderr,"Wrong dimension : %d\n", dim);
return(1);
/* Create a .sol file */
if(!(SolIdx = GmfOpenMesh(OutNam, GmfWrite, GmfFloat, dim)))
fprintf(stderr,"Source of error : BB2SOL / OPEN_MESH\n");
fprintf(stderr,"Cannot open %s\n", OutNam);
return(1);
/* bb case */
if(InpTyp == bb)
NmbTyp = 1;
fscanf(hdl, "%d", &InpTyp);
if(InpTyp == 1)
TypTab[0] = GmfSca;
else if(InpTyp == dim)
TypTab[0] = GmfVec;
else if(InpTyp == (dim * (dim + 1)) / 2)
TypTab[0] = GmfSymMat;
else if(InpTyp == dim * dim)
TypTab[0] = GmfMat;
else
fprintf(stderr,"Wrong solution size : %d\n", InpTyp);
return(1);
else /* BB case */
/* Read and check the number of types */
fscanf(hdl, "%d", &NmbTyp);
if( (NmbTyp < 1) || (NmbTyp > GmfMaxTyp) )
fprintf(stderr,"Wrong number of types : %d\n", NmbTyp);
return(1);
/* Read each types, store them in the sol header */
for(i=0;i<NmbTyp;i++)
fscanf(hdl, "%d", &j);
if(j == 1)
TypTab[i] = GmfSca;
else if( (j == 2) && (dim == 2) )
TypTab[i] = GmfVec;
else if( (j == 3) && (dim == 2) )
TypTab[i] = GmfSymMat;
else if( (j == 3) && (dim == 3) )
TypTab[i] = GmfVec;
else if( (j == 4) && (dim == 2) )
TypTab[i] = GmfMat;
else if( (j == 6) && (dim == 3) )
else if( (j == 9) && (dim == 3) )
TypTab[i] = GmfMat;
else
fprintf(stderr,"Wrong solution type : %d\n", j);
return(1);
/* Read and check the number of solutions */
fscanf(hdl, "%d", &NmbLin);
if(NmbLin < 1)
fprintf(stderr,"Wrong number of solutions : %d\n", NmbLin);
return(1);
/* Jump over the solution's reference element */
fscanf(hdl, "%d", &i);
/* Compute the solution's size */
switch(TypTab[i])
case GmfSca : SolSiz++;break;
case GmfVec : SolSiz += dim;break;
case GmfSymMat : SolSiz += (dim * (dim+1)) / 2;break;
case GmfMat : SolSiz += dim * dim;break;
/* Start reading the solutions */
GmfSetKwd(SolIdx, SolEleTyp, NmbLin, NmbTyp, TypTab);
for(i=1;i<=NmbLin;i++)
for(j=0;j<SolSiz;j++)
fscanf(hdl, "%f", &buf[j]);
GmfSetLin(SolIdx, SolEleTyp, buf);
/* read the optional time and iter ending information */
if(fscanf(hdl, "%d %f", &BBIter, &BBTime) == 2)
GmfSetKwd(SolIdx, GmfIterations);
GmfSetLin(SolIdx, GmfIterations, BBIter);
GmfSetKwd(SolIdx, GmfTime);
GmfSetLin(SolIdx, GmfTime, BBTime);
/* Close both files */
fclose(hdl);
if(!GmfCloseMesh(SolIdx))
return(1);
return(0);
All LM6 code is Copyright 2001 - by Loïc Maréchal, Inria.
This program is a free software.
You can redistribute it and/or modify it under the terms of the GNU Lesser General Public License
as published by the Free Software Foundation; either version 3 of the License, or (at your option) any later version.
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY;
without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public License along with this program as the file LICENSE_lgpl.txt; if not, please see :
http://www.gnu.org/licenses/lgpl.txt
/* LIBMESH V 6.02 */
/* Description: handle .meshb file format I/O */
/* Creation date: feb 16 2007 */
/* Last modification: apr 01 2014 */
/* Defines */
// Libmesh 6 hasn't been modified except this include guard added.
#ifndef MOREFEM_THIRD_PARTY_SOURCE_LIBMESH6_H_
# define MOREFEM_THIRD_PARTY_SOURCE_LIBMESH6_H_
#define GmfStrSiz 1024
#define GmfMaxTyp 1000
#define GmfMaxKwd GmfLastKeyword - 1
#define GmfMshVer 1
#define GmfRead 1
#define GmfWrite 2
#define GmfSca 1
#define GmfVec 2
#define GmfSymMat 3
#define GmfMat 4
#define GmfFloat 1
#define GmfDouble 2
#define GmfInt 3
#define GmfLong 4
enum GmfKwdCod
GmfReserved1, \
GmfVersionFormatted, \
GmfReserved2, \
GmfDimension, \
GmfVertices, \
GmfEdges, \
GmfTriangles, \
GmfQuadrilaterals, \
GmfTetrahedra, \
GmfPrisms, \
GmfHexahedra, \
GmfIterationsAll, \
GmfTimesAll, \
GmfCorners, \
GmfRidges, \
GmfRequiredVertices, \
GmfRequiredEdges, \
GmfRequiredTriangles, \
GmfRequiredQuadrilaterals, \
GmfTangentAtEdgeVertices, \
GmfNormalAtVertices, \
GmfNormalAtTriangleVertices, \
GmfNormalAtQuadrilateralVertices, \
GmfAngleOfCornerBound, \
GmfTrianglesP2, \
GmfEdgesP2, \
GmfSolAtPyramids, \
GmfQuadrilateralsQ2, \
GmfISolAtPyramids, \
GmfSubDomainFromGeom, \
GmfTetrahedraP2, \
GmfFault_NearTri, \
GmfFault_Inter, \
GmfHexahedraQ2, \
GmfExtraVerticesAtEdges, \
GmfExtraVerticesAtTriangles, \
GmfExtraVerticesAtQuadrilaterals, \
GmfExtraVerticesAtTetrahedra, \
GmfExtraVerticesAtPrisms, \
GmfExtraVerticesAtHexahedra, \
GmfVerticesOnGeometricVertices, \
GmfVerticesOnGeometricEdges, \
GmfVerticesOnGeometricTriangles, \
GmfVerticesOnGeometricQuadrilaterals, \
GmfEdgesOnGeometricEdges, \
GmfFault_FreeEdge, \
GmfPolyhedra, \
GmfPolygons, \
GmfFault_Overlap, \
GmfPyramids, \
GmfBoundingBox, \
GmfBody, \
GmfPrivateTable, \
GmfFault_BadShape, \
GmfEnd, \
GmfTrianglesOnGeometricTriangles, \
GmfTrianglesOnGeometricQuadrilaterals, \
GmfQuadrilateralsOnGeometricTriangles, \
GmfQuadrilateralsOnGeometricQuadrilaterals, \
GmfTangents, \
GmfNormals, \
GmfTangentAtVertices, \
GmfSolAtVertices, \
GmfSolAtEdges, \
GmfSolAtTriangles, \
GmfSolAtQuadrilaterals, \
GmfSolAtTetrahedra, \
GmfSolAtPrisms, \
GmfSolAtHexahedra, \
GmfDSolAtVertices, \
GmfISolAtVertices, \
GmfISolAtEdges, \
GmfISolAtTriangles, \
GmfISolAtQuadrilaterals, \
GmfISolAtTetrahedra, \
GmfISolAtPrisms, \
GmfISolAtHexahedra, \
GmfIterations, \
GmfTime, \
GmfFault_SmallTri, \
GmfCoarseHexahedra, \
GmfComments, \
GmfLastKeyword
/* External procedures */
extern int GmfOpenMesh(char *, int, ...);
extern int GmfCloseMesh(int);
extern long GmfStatKwd(int, int, ...);
extern int GmfGotoKwd(int, int);
extern long GmfSetKwd(int, int, ...);
extern int GmfGetLin(int, int, ...);
extern void GmfSetLin(int, int, ...);
extern int GmfGetBlock(int, int, ...);
extern int GmfSetBlock(int, int, ...);
