Commit cbd36d06 authored by GILLES Sebastien's avatar GILLES Sebastien
#859 CMake / PreCache: renove a now unused variable.
parent 0e20a5de
......@@ -26,8 +26,6 @@ set(BLAS_CUSTOM_LINKER False CACHE BOOL "If BLAS_CUSTOM_LINKER is true, BLAS_LIB
set(BLAS_LIB_DIR ${MOREFEM_THIRD_PARTY_LIBRARIES_DIR}/Openblas/lib CACHE STRING "None or path to the lib directory of Blas (see BLAS_CUSTOM_LINKER).")
set(BLAS_LIB openblas CACHE STRING "Name of the Blas lib (e.g. openblas) or command to pass if custom linker is used; see BLAS_CUSTOM_LINKER." )
set(PETSC_GENERAL_INCL_DIR ${MOREFEM_THIRD_PARTY_LIBRARIES_DIR}/Petsc/include CACHE PATH "Include directory of Petsc library common to any build.")
set(PETSC_DEBUG_INCL_DIR ${MOREFEM_THIRD_PARTY_LIBRARIES_DIR}/Petsc/debug/include CACHE PATH "Include directory of Petsc library specific to debug configuration.")
set(PETSC_RELEASE_INCL_DIR ${MOREFEM_THIRD_PARTY_LIBRARIES_DIR}/Petsc/release/include CACHE PATH "Include directory of Petsc library specific to release configuration.")
