Commit fd077537 authored by GILLES Sebastien's avatar GILLES Sebastien
#859 Script create accessor: foresee the case of template template parameter...
#859 Script create accessor: foresee the case of template template parameter for class template argument.
parent 905edcf0
...@@ -83,8 +83,9 @@ class CreateAccessors: ...@@ -83,8 +83,9 @@ class CreateAccessors:
for item in self._template_args: for item in self._template_args:
item = item.strip() item = item.strip()
splitted = item.split(' ') splitted = item.split(' ')
assert(len(splitted) == 2) assert(len(splitted) > 1)
args.append(splitted[1]) # assert(len(splitted) == 2) Might be more for template template parameters!
args.append(splitted[-1])
self._class_name = "{raw}<{args}>".format(raw = class_name, args = ", ".join(args)) self._class_name = "{raw}<{args}>".format(raw = class_name, args = ", ".join(args))
Supports Markdown
