Commit c6e81db1 authored by GILLES Sebastien's avatar GILLES Sebastien
#1459 Move the introduction talks in a [separate...
#1459 Move the introduction talks in a [separate project](https://gitlab.inria.fr/MoReFEM/CoreLibrary/introductiontalks.git).
parent 016a7a1f
Too many changes to show.
To preserve performance only 1000 of 1000+ files are displayed.
...@@ -3,6 +3,12 @@ means week 46 of year 2013. Should a second tag be given the same week, an index ...@@ -3,6 +3,12 @@ means week 46 of year 2013. Should a second tag be given the same week, an index
Starting from v18.47, the ticket numbers in bold are those that might break compatibility in models. Starting from v18.47, the ticket numbers in bold are those that might break compatibility in models.
# Development
## Documentation
- Documentation #1459: Move the introduction talks in a [separate project](https://gitlab.inria.fr/MoReFEM/CoreLibrary/introductiontalks.git).
# v19.29 # v19.29
## Outputs ## Outputs
{"assets":{"2A509FE393636F2B07B23F2DF73A48D9":{"type":"texture","index":0,"assetRequest":{"type":"slide","state":"outgoing","slide":"04BB703A-711B-4900-8EDE-A675C829A28D"},"url":{"web":"assets/04BB703A-711B-4900-8EDE-A675C829A28D.svgmap"},"width":1024,"height":768},"B3F9F39F05CF6A256620CB9E3BE069B8":{"type":"texture","index":1,"assetRequest":{"type":"slide","state":"incoming","slide":"3C7DBD33-989A-4949-9ED0-27ACD57FECA3"},"url":{"web":"assets/04BB703A-711B-4900-8EDE-A675C829A28D.svgmap"},"width":1024,"height":768}},"events":[{"effects":[{"beginTime":0,"baseLayer":{"animations":[],"initialState":{"affineTransform":[1,0,0,1,0,0],"masksToBounds":false,"rotation":0,"scale":1,"position":{"pointX":512,"pointY":384},"width":1024,"sublayerTransform":[1,0,0,0,0,1,0,0,0,0,1,0,0,0,0,1],"contentsRect":{"y":0,"x":0,"width":1,"height":1},"opacity":1,"edgeAntialiasingMask":251658240,"height":768,"hidden":false,"anchorPoint":{"pointX":0.5,"pointY":0.5}},"objectID":"0","layers":[{"animations":[],"initialState":{"affineTransform":[1,0,0,1,0,0],"masksToBounds":false,"rotation":0,"scale":1,"position":{"pointX":512,"pointY":384},"width":1024,"sublayerTransform":[1,0,0,0,0,1,0,0,0,0,1,-0.0004922987690640373,0,0,0,1],"contentsRect":{"y":0,"x":0,"width":1,"height":1},"opacity":1,"edgeAntialiasingMask":251658240,"height":768,"hidden":false,"anchorPoint":{"pointX":0.5,"pointY":0.5}},"layers":[{"animations":[],"layers":[],"texturedRectangle":{"isBackgroundTexture":false,"singleTextureOpacity":1,"textureType":0,"textBaseline":0,"textXHeight":0,"isVerticalText":false},"initialState":{"affineTransform":[1,0,0,1,0,0],"masksToBounds":false,"rotation":0,"scale":1,"position":{"pointX":512,"pointY":384},"width":1024,"sublayerTransform":[1,0,0,0,0,1,0,0,0,0,1,0,0,0,0,1],"contentsRect":{"y":0,"x":0,"width":1,"height":1},"opacity":1,"edgeAntialiasingMask":0,"height":768,"hidden":false,"anchorPoint":{"pointX":0.5,"pointY":0.5}},"texture":"B3F9F39F05CF6A256620CB9E3BE069B8"},{"animations":[{"timeOffset":0,"from":{"scalar":false},"beginTime":0,"repeatCount":0,"fillMode":"both","property":"hidden","autoreverses":false,"duration":0.01,"to":{"scalar":true}}],"layers":[],"texturedRectangle":{"isBackgroundTexture":false,"singleTextureOpacity":1,"textureType":0,"textBaseline":0,"textXHeight":0,"isVerticalText":false},"initialState":{"affineTransform":[1,0,0,1,0,0],"masksToBounds":false,"rotation":0,"scale":1,"position":{"pointX":512,"pointY":384},"width":1024,"sublayerTransform":[1,0,0,0,0,1,0,0,0,0,1,0,0,0,0,1],"contentsRect":{"y":0,"x":0,"width":1,"height":1},"opacity":1,"edgeAntialiasingMask":0,"height":768,"hidden":false,"anchorPoint":{"pointX":0.5,"pointY":0.5}},"texture":"2A509FE393636F2B07B23F2DF73A48D9"}]}]},"effects":[],"duration":0.01,"type":"transition","name":"none","objectID":"0"}],"automaticPlay":false,"hyperlinks":[],"accessibility":[{"text":"Gautier BUREAU","targetRectangle":{"y":731.5111083984375,"x":152.1110992431641,"width":148.1572265625,"height":21}},{"text":"M3DISIM Seminar - 2017/01/30","targetRectangle":{"y":732.5111083984375,"x":759.4397583007812,"width":203.8046875,"height":19}},{"text":"InputParameterList.hpp ","targetRectangle":{"y":133.4741058349609,"x":66.55111181735992,"width":353.5546875,"height":42.00000166893005}},{"text":"Lua","targetRectangle":{"y":259.4741108417511,"x":66.55111181735992,"width":52.880859375,"height":42.00000166893005}},{"text":"Even if you want to initialise a scalar unknown it creates x, y and z and in this case juste give the function in the x coordinate and return 0. in the others like in the example above.","targetRectangle":{"y":553.4741225242615,"x":66.55111181735992,"width":883.0224609375,"height":168.0000066757202}},{"text":"droppedImage.pdf","targetRectangle":{"y":717.9727172851562,"x":29.26572799682617,"width":109,"height":31.99999809265137}},{"text":"droppedImage.pdf","targetRectangle":{"y":703.9727172851562,"x":25.85802459716797,"width":113,"height":79}},{"text":"bandeau_texte_rouge.jpg","targetRectangle":{"y":647,"x":0,"width":1024,"height":121.0000076293945}},{"text":"InitialCondition1 = {","targetRectangle":{"y":296.0863704681396,"x":305.5986328125,"width":151.716796875,"height":14}},{"text":" ","targetRectangle":{"y":310.0863704681396,"x":305.5986328125,"width":28.8984375,"height":14}},{"text":" nature = { \"lua_function\", \"constant\", \"constant\" },","targetRectangle":{"y":324.0863704681396,"x":305.5986328125,"width":404.578125,"height":14}},{"text":" scalar_value = { 0. , 0., 0.},","targetRectangle":{"y":338.0863704681396,"x":305.5986328125,"width":245.63671875,"height":14}},{"text":" lua_function_x = function(x, y, z)","targetRectangle":{"y":366.0863704681396,"x":305.5986328125,"width":274.53515625,"height":14}},{"text":" return 10*math.exp(-(x-0.5-10/2)^2);","targetRectangle":{"y":380.0863704681396,"x":305.5986328125,"width":317.8828125,"height":14}},{"text":" end,","targetRectangle":{"y":394.0863704681396,"x":305.5986328125,"width":57.796875,"height":14}},{"text":" lua_function_y = function(x, y, z)","targetRectangle":{"y":422.0863704681396,"x":305.5986328125,"width":274.53515625,"height":14}},{"text":" return 0.;","targetRectangle":{"y":436.0863704681396,"x":305.5986328125,"width":130.04296875,"height":14}},{"text":" end,","targetRectangle":{"y":450.0863704681396,"x":305.5986328125,"width":57.796875,"height":14}},{"text":" lua_function_z = function(x, y, z)","targetRectangle":{"y":478.0863704681396,"x":305.5986328125,"width":274.53515625,"height":14}},{"text":" return 0.;","targetRectangle":{"y":492.0863704681396,"x":305.5986328125,"width":130.04296875,"height":14}},{"text":" end","targetRectangle":{"y":506.0863704681396,"x":305.5986328125,"width":50.572265625,"height":14}},{"text":" ","targetRectangle":{"y":520.0863704681396,"x":305.5986328125,"width":28.8984375,"height":14}},{"text":"} -- InitialCondition1","targetRectangle":{"y":534.0863704681396,"x":305.5986328125,"width":158.94140625,"height":14}},{"text":"InputParameter::InitialCondition<EnumUnderlyingType(InitialConditionIndex::temperature_initial_condition)>,","targetRectangle":{"y":208.1663511991501,"x":55.24024200439453,"width":912.51953125,"height":21.37841796875}},{"text":"","targetRectangle":{"y":730.5111083984375,"x":501.9999994791579,"width":20,"height":23}},{"text":"InitialCondition","targetRectangle":{"y":35.19999885559082,"x":151.3334045410156,"width":334.08203125,"height":51}}],"baseLayer":{"animations":[],"initialState":{"affineTransform":[1,0,0,1,0,0],"masksToBounds":false,"rotation":0,"scale":1,"position":{"pointX":512,"pointY":384},"width":1024,"sublayerTransform":[1,0,0,0,0,1,0,0,0,0,1,0,0,0,0,1],"contentsRect":{"y":0,"x":0,"width":1,"height":1},"opacity":1,"edgeAntialiasingMask":251658240,"height":768,"hidden":false,"anchorPoint":{"pointX":0.5,"pointY":0.5}},"objectID":"0","layers":[{"animations":[],"initialState":{"affineTransform":[1,0,0,1,0,0],"masksToBounds":false,"rotation":0,"scale":1,"position":{"pointX":512,"pointY":384},"width":1024,"sublayerTransform":[1,0,0,0,0,1,0,0,0,0,1,-0.0004922987690640373,0,0,0,1],"contentsRect":{"y":0,"x":0,"width":1,"height":1},"opacity":1,"edgeAntialiasingMask":251658240,"height":768,"hidden":false,"anchorPoint":{"pointX":0.5,"pointY":0.5}},"layers":[{"animations":[],"layers":[],"texturedRectangle":{"isBackgroundTexture":false,"singleTextureOpacity":1,"textureType":0,"textBaseline":0,"textXHeight":0,"isVerticalText":false},"initialState":{"affineTransform":[1,0,0,1,0,0],"masksToBounds":false,"rotation":0,"scale":1,"position":{"pointX":512,"pointY":384},"width":1024,"sublayerTransform":[1,0,0,0,0,1,0,0,0,0,1,0,0,0,0,1],"contentsRect":{"y":0,"x":0,"width":1,"height":1},"opacity":1,"edgeAntialiasingMask":0,"height":768,"hidden":false,"anchorPoint":{"pointX":0.5,"pointY":0.5}},"texture":"2A509FE393636F2B07B23F2DF73A48D9"}]}]}}]}
\ No newline at end of file
local_slide( {"name":"04BB703A-711B-4900-8EDE-A675C829A28D","json":{"assets":{"2A509FE393636F2B07B23F2DF73A48D9":{"type":"texture","index":0,"assetRequest":{"type":"slide","state":"outgoing","slide":"04BB703A-711B-4900-8EDE-A675C829A28D"},"url":{"web":"assets/04BB703A-711B-4900-8EDE-A675C829A28D.svgmap"},"width":1024,"height":768},"B3F9F39F05CF6A256620CB9E3BE069B8":{"type":"texture","index":1,"assetRequest":{"type":"slide","state":"incoming","slide":"3C7DBD33-989A-4949-9ED0-27ACD57FECA3"},"url":{"web":"assets/04BB703A-711B-4900-8EDE-A675C829A28D.svgmap"},"width":1024,"height":768}},"events":[{"effects":[{"beginTime":0,"baseLayer":{"animations":[],"initialState":{"affineTransform":[1,0,0,1,0,0],"masksToBounds":false,"rotation":0,"scale":1,"position":{"pointX":512,"pointY":384},"width":1024,"sublayerTransform":[1,0,0,0,0,1,0,0,0,0,1,0,0,0,0,1],"contentsRect":{"y":0,"x":0,"width":1,"height":1},"opacity":1,"edgeAntialiasingMask":251658240,"height":768,"hidden":false,"anchorPoint":{"pointX":0.5,"pointY":0.5}},"objectID":"0","layers":[{"animations":[],"initialState":{"affineTransform":[1,0,0,1,0,0],"masksToBounds":false,"rotation":0,"scale":1,"position":{"pointX":512,"pointY":384},"width":1024,"sublayerTransform":[1,0,0,0,0,1,0,0,0,0,1,-0.0004922987690640373,0,0,0,1],"contentsRect":{"y":0,"x":0,"width":1,"height":1},"opacity":1,"edgeAntialiasingMask":251658240,"height":768,"hidden":false,"anchorPoint":{"pointX":0.5,"pointY":0.5}},"layers":[{"animations":[],"layers":[],"texturedRectangle":{"isBackgroundTexture":false,"singleTextureOpacity":1,"textureType":0,"textBaseline":0,"textXHeight":0,"isVerticalText":false},"initialState":{"affineTransform":[1,0,0,1,0,0],"masksToBounds":false,"rotation":0,"scale":1,"position":{"pointX":512,"pointY":384},"width":1024,"sublayerTransform":[1,0,0,0,0,1,0,0,0,0,1,0,0,0,0,1],"contentsRect":{"y":0,"x":0,"width":1,"height":1},"opacity":1,"edgeAntialiasingMask":0,"height":768,"hidden":false,"anchorPoint":{"pointX":0.5,"pointY":0.5}},"texture":"B3F9F39F05CF6A256620CB9E3BE069B8"},{"animations":[{"timeOffset":0,"from":{"scalar":false},"beginTime":0,"repeatCount":0,"fillMode":"both","property":"hidden","autoreverses":false,"duration":0.01,"to":{"scalar":true}}],"layers":[],"texturedRectangle":{"isBackgroundTexture":false,"singleTextureOpacity":1,"textureType":0,"textBaseline":0,"textXHeight":0,"isVerticalText":false},"initialState":{"affineTransform":[1,0,0,1,0,0],"masksToBounds":false,"rotation":0,"scale":1,"position":{"pointX":512,"pointY":384},"width":1024,"sublayerTransform":[1,0,0,0,0,1,0,0,0,0,1,0,0,0,0,1],"contentsRect":{"y":0,"x":0,"width":1,"height":1},"opacity":1,"edgeAntialiasingMask":0,"height":768,"hidden":false,"anchorPoint":{"pointX":0.5,"pointY":0.5}},"texture":"2A509FE393636F2B07B23F2DF73A48D9"}]}]},"effects":[],"duration":0.01,"type":"transition","name":"none","objectID":"0"}],"automaticPlay":false,"hyperlinks":[],"accessibility":[{"text":"Gautier BUREAU","targetRectangle":{"y":731.5111083984375,"x":152.1110992431641,"width":148.1572265625,"height":21}},{"text":"M3DISIM Seminar - 2017/01/30","targetRectangle":{"y":732.5111083984375,"x":759.4397583007812,"width":203.8046875,"height":19}},{"text":"InputParameterList.hpp ","targetRectangle":{"y":133.4741058349609,"x":66.55111181735992,"width":353.5546875,"height":42.00000166893005}},{"text":"Lua","targetRectangle":{"y":259.4741108417511,"x":66.55111181735992,"width":52.880859375,"height":42.00000166893005}},{"text":"Even if you want to initialise a scalar unknown it creates x, y and z and in this case juste give the function in the x coordinate and return 0. in the others like in the example above.","targetRectangle":{"y":553.4741225242615,"x":66.55111181735992,"width":883.0224609375,"height":168.0000066757202}},{"text":"droppedImage.pdf","targetRectangle":{"y":717.9727172851562,"x":29.26572799682617,"width":109,"height":31.99999809265137}},{"text":"droppedImage.pdf","targetRectangle":{"y":703.9727172851562,"x":25.85802459716797,"width":113,"height":79}},{"text":"bandeau_texte_rouge.jpg","targetRectangle":{"y":647,"x":0,"width":1024,"height":121.0000076293945}},{"text":"InitialCondition1 = {","targetRectangle":{"y":296.0863704681396,"x":305.5986328125,"width":151.716796875,"height":14}},{"text":" ","targetRectangle":{"y":310.0863704681396,"x":305.5986328125,"width":28.8984375,"height":14}},{"text":" nature = { \"lua_function\", \"constant\", \"constant\" },","targetRectangle":{"y":324.0863704681396,"x":305.5986328125,"width":404.578125,"height":14}},{"text":" scalar_value = { 0. , 0., 0.},","targetRectangle":{"y":338.0863704681396,"x":305.5986328125,"width":245.63671875,"height":14}},{"text":" lua_function_x = function(x, y, z)","targetRectangle":{"y":366.0863704681396,"x":305.5986328125,"width":274.53515625,"height":14}},{"text":" return 10*math.exp(-(x-0.5-10/2)^2);","targetRectangle":{"y":380.0863704681396,"x":305.5986328125,"width":317.8828125,"height":14}},{"text":" end,","targetRectangle":{"y":394.0863704681396,"x":305.5986328125,"width":57.796875,"height":14}},{"text":" lua_function_y = function(x, y, z)","targetRectangle":{"y":422.0863704681396,"x":305.5986328125,"width":274.53515625,"height":14}},{"text":" return 0.;","targetRectangle":{"y":436.0863704681396,"x":305.5986328125,"width":130.04296875,"height":14}},{"text":" end,","targetRectangle":{"y":450.0863704681396,"x":305.5986328125,"width":57.796875,"height":14}},{"text":" lua_function_z = function(x, y, z)","targetRectangle":{"y":478.0863704681396,"x":305.5986328125,"width":274.53515625,"height":14}},{"text":" return 0.;","targetRectangle":{"y":492.0863704681396,"x":305.5986328125,"width":130.04296875,"height":14}},{"text":" end","targetRectangle":{"y":506.0863704681396,"x":305.5986328125,"width":50.572265625,"height":14}},{"text":" ","targetRectangle":{"y":520.0863704681396,"x":305.5986328125,"width":28.8984375,"height":14}},{"text":"} -- InitialCondition1","targetRectangle":{"y":534.0863704681396,"x":305.5986328125,"width":158.94140625,"height":14}},{"text":"InputParameter::InitialCondition<EnumUnderlyingType(InitialConditionIndex::temperature_initial_condition)>,","targetRectangle":{"y":208.1663511991501,"x":55.24024200439453,"width":912.51953125,"height":21.37841796875}},{"text":"","targetRectangle":{"y":730.5111083984375,"x":501.9999994791579,"width":20,"height":23}},{"text":"InitialCondition","targetRectangle":{"y":35.19999885559082,"x":151.3334045410156,"width":334.08203125,"height":51}}],"baseLayer":{"animations":[],"initialState":{"affineTransform":[1,0,0,1,0,0],"masksToBounds":false,"rotation":0,"scale":1,"position":{"pointX":512,"pointY":384},"width":1024,"sublayerTransform":[1,0,0,0,0,1,0,0,0,0,1,0,0,0,0,1],"contentsRect":{"y":0,"x":0,"width":1,"height":1},"opacity":1,"edgeAntialiasingMask":251658240,"height":768,"hidden":false,"anchorPoint":{"pointX":0.5,"pointY":0.5}},"objectID":"0","layers":[{"animations":[],"initialState":{"affineTransform":[1,0,0,1,0,0],"masksToBounds":false,"rotation":0,"scale":1,"position":{"pointX":512,"pointY":384},"width":1024,"sublayerTransform":[1,0,0,0,0,1,0,0,0,0,1,-0.0004922987690640373,0,0,0,1],"contentsRect":{"y":0,"x":0,"width":1,"height":1},"opacity":1,"edgeAntialiasingMask":251658240,"height":768,"hidden":false,"anchorPoint":{"pointX":0.5,"pointY":0.5}},"layers":[{"animations":[],"layers":[],"texturedRectangle":{"isBackgroundTexture":false,"singleTextureOpacity":1,"textureType":0,"textBaseline":0,"textXHeight":0,"isVerticalText":false},"initialState":{"affineTransform":[1,0,0,1,0,0],"masksToBounds":false,"rotation":0,"scale":1,"position":{"pointX":512,"pointY":384},"width":1024,"sublayerTransform":[1,0,0,0,0,1,0,0,0,0,1,0,0,0,0,1],"contentsRect":{"y":0,"x":0,"width":1,"height":1},"opacity":1,"edgeAntialiasingMask":0,"height":768,"hidden":false,"anchorPoint":{"pointX":0.5,"pointY":0.5}},"texture":"2A509FE393636F2B07B23F2DF73A48D9"}]}]}}]}} )
{"assets":{"43E216080A3617A0A2C8A22D33EE10D0":{"type":"texture","index":0,"assetRequest":{"type":"slide","state":"outgoing","slide":"05A6F470-C44A-47AD-A3CE-2724CF69AD76"},"url":{"web":"assets/43E216080A3617A0A2C8A22D33EE10D0.png"},"width":<
