Commit 83666980 authored by GILLES Sebastien's avatar GILLES Sebastien
#1457 Increase many timeouts: finally tests may vary wildly in execution time...
#1457 Increase many timeouts: finally tests may vary wildly in execution time and being conservative is actually a good idea...
parent 139d6c4f
...@@ -180,4 +180,4 @@ add_test(ElasticityCheckResults ...@@ -180,4 +180,4 @@ add_test(ElasticityCheckResults
${MOREFEM_TEST_OUTPUT_DIR} ${MOREFEM_TEST_OUTPUT_DIR}
set_tests_properties(ElasticityCheckResults PROPERTIES TIMEOUT 2) set_tests_properties(ElasticityCheckResults PROPERTIES TIMEOUT 5)
...@@ -41,7 +41,7 @@ add_test(HeatModel2D ...@@ -41,7 +41,7 @@ add_test(HeatModel2D
-i ${MOREFEM_ROOT}/Sources/ModelInstances/Heat/demo_input_heat.lua -i ${MOREFEM_ROOT}/Sources/ModelInstances/Heat/demo_input_heat.lua
-e MOREFEM_RESULT_DIR=${MOREFEM_TEST_OUTPUT_DIR}/Seq) -e MOREFEM_RESULT_DIR=${MOREFEM_TEST_OUTPUT_DIR}/Seq)
set_tests_properties(HeatModel2D PROPERTIES TIMEOUT 4) set_tests_properties(HeatModel2D PROPERTIES TIMEOUT 10)
add_test(HeatModel2DEnsightOutput add_test(HeatModel2DEnsightOutput
MoReFEM4HeatEnsightOutput MoReFEM4HeatEnsightOutput
...@@ -49,7 +49,7 @@ add_test(HeatModel2DEnsightOutput ...@@ -49,7 +49,7 @@ add_test(HeatModel2DEnsightOutput
-i ${MOREFEM_TEST_OUTPUT_DIR}/Seq/Heat/2D/input_data.lua -i ${MOREFEM_TEST_OUTPUT_DIR}/Seq/Heat/2D/input_data.lua
set_tests_properties(HeatModel2DEnsightOutput PROPERTIES TIMEOUT 2) set_tests_properties(HeatModel2DEnsightOutput PROPERTIES TIMEOUT 10)
add_test(HeatModel2D-mpi add_test(HeatModel2D-mpi
${OPEN_MPI_INCL_DIR}/../bin/mpirun ${OPEN_MPI_INCL_DIR}/../bin/mpirun
...@@ -59,7 +59,7 @@ add_test(HeatModel2D-mpi ...@@ -59,7 +59,7 @@ add_test(HeatModel2D-mpi
-e MOREFEM_RESULT_DIR=${MOREFEM_TEST_OUTPUT_DIR}/Mpi4) -e MOREFEM_RESULT_DIR=${MOREFEM_TEST_OUTPUT_DIR}/Mpi4)
set_tests_properties(HeatModel2D-mpi PROPERTIES TIMEOUT 2) set_tests_properties(HeatModel2D-mpi PROPERTIES TIMEOUT 10)
add_test(HeatModel2DEnsightOutput-mpi add_test(HeatModel2DEnsightOutput-mpi
...@@ -67,7 +67,7 @@ add_test(HeatModel2DEnsightOutput-mpi ...@@ -67,7 +67,7 @@ add_test(HeatModel2DEnsightOutput-mpi
-i ${MOREFEM_TEST_OUTPUT_DIR}/Mpi4/Heat/2D/input_data.lua -i ${MOREFEM_TEST_OUTPUT_DIR}/Mpi4/Heat/2D/input_data.lua
set_tests_properties(HeatModel2DEnsightOutput-mpi PROPERTIES TIMEOUT 2) set_tests_properties(HeatModel2DEnsightOutput-mpi PROPERTIES TIMEOUT 10)
add_test(HeatModel1D add_test(HeatModel1D
MoReFEM4Heat MoReFEM4Heat
...@@ -83,7 +83,7 @@ add_test(HeatModel1DEnsightOutput ...@@ -83,7 +83,7 @@ add_test(HeatModel1DEnsightOutput
-i ${MOREFEM_TEST_OUTPUT_DIR}/Seq/Heat/1D/input_data.lua -i ${MOREFEM_TEST_OUTPUT_DIR}/Seq/Heat/1D/input_data.lua
set_tests_properties(HeatModel1DEnsightOutput PROPERTIES TIMEOUT 2) set_tests_properties(HeatModel1DEnsightOutput PROPERTIES TIMEOUT 10)
add_test(HeatModel1D-mpi add_test(HeatModel1D-mpi
...@@ -93,7 +93,7 @@ add_test(HeatModel1D-mpi ...@@ -93,7 +93,7 @@ add_test(HeatModel1D-mpi
-i ${MOREFEM_ROOT}/Sources/ModelInstances/Heat/demo_input_heat_1d.lua -i ${MOREFEM_ROOT}/Sources/ModelInstances/Heat/demo_input_heat_1d.lua
set_tests_properties(HeatModel1D-mpi PROPERTIES TIMEOUT 2) set_tests_properties(HeatModel1D-mpi PROPERTIES TIMEOUT 10)
add_test(HeatModel1DEnsightOutput-mpi add_test(HeatModel1DEnsightOutput-mpi
...@@ -101,7 +101,7 @@ add_test(HeatModel1DEnsightOutput-mpi ...@@ -101,7 +101,7 @@ add_test(HeatModel1DEnsightOutput-mpi
-i ${MOREFEM_TEST_OUTPUT_DIR}/Mpi4/Heat/1D/input_data.lua -i ${MOREFEM_TEST_OUTPUT_DIR}/Mpi4/Heat/1D/input_data.lua
set_tests_properties(HeatModel1DEnsightOutput-mpi PROPERTIES TIMEOUT 2) set_tests_properties(HeatModel1DEnsightOutput-mpi PROPERTIES TIMEOUT 10)
add_test(HeatCheckResults add_test(HeatCheckResults
MoReFEM4HeatCheckResults MoReFEM4HeatCheckResults
...@@ -110,6 +110,6 @@ add_test(HeatCheckResults ...@@ -110,6 +110,6 @@ add_test(HeatCheckResults
set_tests_properties(HeatCheckResults PROPERTIES TIMEOUT 2) set_tests_properties(HeatCheckResults PROPERTIES TIMEOUT 10)
...@@ -58,7 +58,7 @@ add_test(HyperelasticityModelEnsightOutput ...@@ -58,7 +58,7 @@ add_test(HyperelasticityModelEnsightOutput
-i ${MOREFEM_TEST_OUTPUT_DIR}/Seq/MidpointHyperelasticity/input_data.lua -i ${MOREFEM_TEST_OUTPUT_DIR}/Seq/MidpointHyperelasticity/input_data.lua
set_tests_properties(HyperelasticityModelEnsightOutput PROPERTIES TIMEOUT 2) set_tests_properties(HyperelasticityModelEnsightOutput PROPERTIES TIMEOUT 5)
add_test(HyperelasticityModelEnsightOutput-mpi add_test(HyperelasticityModelEnsightOutput-mpi
MoReFEM4HyperelasticityEnsightOutput MoReFEM4HyperelasticityEnsightOutput
...@@ -66,7 +66,7 @@ add_test(HyperelasticityModelEnsightOutput-mpi ...@@ -66,7 +66,7 @@ add_test(HyperelasticityModelEnsightOutput-mpi
-i ${MOREFEM_TEST_OUTPUT_DIR}/Mpi4/MidpointHyperelasticity/input_data.lua -i ${MOREFEM_TEST_OUTPUT_DIR}/Mpi4/MidpointHyperelasticity/input_data.lua
set_tests_properties(HyperelasticityModelEnsightOutput-mpi PROPERTIES TIMEOUT 2) set_tests_properties(HyperelasticityModelEnsightOutput-mpi PROPERTIES TIMEOUT 5)
add_test(HyperelasticityCheckResults add_test(HyperelasticityCheckResults
MoReFEM4HyperelasticityCheckResults MoReFEM4HyperelasticityCheckResults
...@@ -75,4 +75,4 @@ add_test(HyperelasticityCheckResults ...@@ -75,4 +75,4 @@ add_test(HyperelasticityCheckResults
set_tests_properties(HyperelasticityCheckResults PROPERTIES TIMEOUT 2) set_tests_properties(HyperelasticityCheckResults PROPERTIES TIMEOUT 5)
...@@ -51,7 +51,7 @@ add_test(StokesModelEnsightOutput ...@@ -51,7 +51,7 @@ add_test(StokesModelEnsightOutput
-i ${MOREFEM_TEST_OUTPUT_DIR}/Seq/Stokes/input_data.lua -i ${MOREFEM_TEST_OUTPUT_DIR}/Seq/Stokes/input_data.lua
set_tests_properties(StokesModelEnsightOutput PROPERTIES TIMEOUT 5) set_tests_properties(StokesModelEnsightOutput PROPERTIES TIMEOUT 10)
add_test(StokesModelEnsightOutput-mpi add_test(StokesModelEnsightOutput-mpi
MoReFEM4StokesEnsightOutput MoReFEM4StokesEnsightOutput
...@@ -59,13 +59,13 @@ add_test(StokesModelEnsightOutput-mpi ...@@ -59,13 +59,13 @@ add_test(StokesModelEnsightOutput-mpi
-i ${MOREFEM_TEST_OUTPUT_DIR}/Mpi4/Stokes/input_data.lua -i ${MOREFEM_TEST_OUTPUT_DIR}/Mpi4/Stokes/input_data.lua
set_tests_properties(StokesModelEnsightOutput-mpi PROPERTIES TIMEOUT 5) set_tests_properties(StokesModelEnsightOutput-mpi PROPERTIES TIMEOUT 10)
add_executable(MoReFEM4StokesCheckResults ${CMAKE_CURRENT_LIST_DIR}/test_results.cpp) add_executable(MoReFEM4StokesCheckResults ${CMAKE_CURRENT_LIST_DIR}/test_results.cpp)
target_link_libraries(MoReFEM4StokesCheckResults target_link_libraries(MoReFEM4StokesCheckResults
${MOREFEM_TEST_TOOLS}) ${MOREFEM_TEST_TOOLS})
add_test(StokesCheckResults add_test(StokesCheckResults
MoReFEM4StokesCheckResults MoReFEM4StokesCheckResults
...@@ -74,7 +74,7 @@ add_test(StokesCheckResults ...@@ -74,7 +74,7 @@ add_test(StokesCheckResults
set_tests_properties(StokesCheckResults PROPERTIES TIMEOUT 5) set_tests_properties(StokesCheckResults PROPERTIES TIMEOUT 10)
include(${CMAKE_CURRENT_LIST_DIR}/TwoOperators.cmake) include(${CMAKE_CURRENT_LIST_DIR}/TwoOperators.cmake)
...@@ -11,4 +11,4 @@ add_test(MoReFEMDataCommandLineOptions ...@@ -11,4 +11,4 @@ add_test(MoReFEMDataCommandLineOptions
${MOREFEM_ROOT} ${MOREFEM_ROOT}
${MOREFEM_TEST_OUTPUT_DIR}) ${MOREFEM_TEST_OUTPUT_DIR})
set_tests_properties(MoReFEMDataCommandLineOptions PROPERTIES TIMEOUT 2) set_tests_properties(MoReFEMDataCommandLineOptions PROPERTIES TIMEOUT 10)
...@@ -11,4 +11,4 @@ add_test(MoReFEMDataInitialCondition ...@@ -11,4 +11,4 @@ add_test(MoReFEMDataInitialCondition
set_tests_properties(MoReFEMDataInitialCondition PROPERTIES TIMEOUT 2) set_tests_properties(MoReFEMDataInitialCondition PROPERTIES TIMEOUT 5)
...@@ -11,4 +11,4 @@ add_test(MoReFEMDataInputData ...@@ -11,4 +11,4 @@ add_test(MoReFEMDataInputData
set_tests_properties(MoReFEMDataInputData PROPERTIES TIMEOUT 2) set_tests_properties(MoReFEMDataInputData PROPERTIES TIMEOUT 10)
...@@ -13,4 +13,4 @@ add_test(VariableTimeStep ...@@ -13,4 +13,4 @@ add_test(VariableTimeStep
set_tests_properties(VariableTimeStep PROPERTIES TIMEOUT 2) set_tests_properties(VariableTimeStep PROPERTIES TIMEOUT 5)
...@@ -16,7 +16,7 @@ add_test(DomainListInCoords ...@@ -16,7 +16,7 @@ add_test(DomainListInCoords
set_tests_properties(DomainListInCoords PROPERTIES TIMEOUT 2) set_tests_properties(DomainListInCoords PROPERTIES TIMEOUT 5)
add_test(DomainListInCoords-mpi add_test(DomainListInCoords-mpi
...@@ -26,4 +26,4 @@ add_test(DomainListInCoords-mpi ...@@ -26,4 +26,4 @@ add_test(DomainListInCoords-mpi
set_tests_properties(DomainListInCoords-mpi PROPERTIES TIMEOUT 2) set_tests_properties(DomainListInCoords-mpi PROPERTIES TIMEOUT 5)
...@@ -12,4 +12,4 @@ add_test(EnsightMeditMesh ...@@ -12,4 +12,4 @@ add_test(EnsightMeditMesh
${MOREFEM_TEST_OUTPUT_DIR}/Geometry/EnsightMeditMesh) ${MOREFEM_TEST_OUTPUT_DIR}/Geometry/EnsightMeditMesh)
set_tests_properties(EnsightMeditMesh PROPERTIES TIMEOUT 2) set_tests_properties(EnsightMeditMesh PROPERTIES TIMEOUT 10)
...@@ -19,4 +19,4 @@ add_test(LoadPrepartitionedMesh ...@@ -19,4 +19,4 @@ add_test(LoadPrepartitionedMesh
set_tests_properties(LoadPrepartitionedMesh PROPERTIES TIMEOUT 10) set_tests_properties(LoadPrepartitionedMesh PROPERTIES TIMEOUT 20)
...@@ -34,7 +34,7 @@ add_test(OperatorGradGrad3D ...@@ -34,7 +34,7 @@ add_test(OperatorGradGrad3D
set_tests_properties(OperatorGradGrad3D PROPERTIES TIMEOUT 2) set_tests_properties(OperatorGradGrad3D PROPERTIES TIMEOUT 5)
add_test(OperatorGradGrad2D add_test(OperatorGradGrad2D
MoReFEMTestOperatorGradGrad2D MoReFEMTestOperatorGradGrad2D
...@@ -42,7 +42,7 @@ add_test(OperatorGradGrad2D ...@@ -42,7 +42,7 @@ add_test(OperatorGradGrad2D
set_tests_properties(OperatorGradGrad2D PROPERTIES TIMEOUT 2) set_tests_properties(OperatorGradGrad2D PROPERTIES TIMEOUT 5)
add_test(OperatorGradGrad1D add_test(OperatorGradGrad1D
MoReFEMTestOperatorGradGrad1D MoReFEMTestOperatorGradGrad1D
...@@ -50,4 +50,4 @@ add_test(OperatorGradGrad1D ...@@ -50,4 +50,4 @@ add_test(OperatorGradGrad1D
set_tests_properties(OperatorGradGrad1D PROPERTIES TIMEOUT 2) set_tests_properties(OperatorGradGrad1D PROPERTIES TIMEOUT 5)
...@@ -34,7 +34,7 @@ add_test(OperatorMass3D ...@@ -34,7 +34,7 @@ add_test(OperatorMass3D
set_tests_properties(OperatorMass3D PROPERTIES TIMEOUT 2) set_tests_properties(OperatorMass3D PROPERTIES TIMEOUT 5)
add_test(OperatorMass2D add_test(OperatorMass2D
MoReFEMTestOperatorMass2D MoReFEMTestOperatorMass2D
...@@ -42,7 +42,7 @@ add_test(OperatorMass2D ...@@ -42,7 +42,7 @@ add_test(OperatorMass2D
set_tests_properties(OperatorMass2D PROPERTIES TIMEOUT 2) set_tests_properties(OperatorMass2D PROPERTIES TIMEOUT 5)
add_test(OperatorMass1D add_test(OperatorMass1D
MoReFEMTestOperatorMass1D MoReFEMTestOperatorMass1D
...@@ -50,4 +50,4 @@ add_test(OperatorMass1D ...@@ -50,4 +50,4 @@ add_test(OperatorMass1D
set_tests_properties(OperatorMass1D PROPERTIES TIMEOUT 2) set_tests_properties(OperatorMass1D PROPERTIES TIMEOUT 5)
...@@ -27,4 +27,4 @@ add_test(NonLinearMembrane MoReFEMTestNonLinearMembrane ...@@ -27,4 +27,4 @@ add_test(NonLinearMembrane MoReFEMTestNonLinearMembrane
set_tests_properties(NonLinearMembrane PROPERTIES TIMEOUT 2) set_tests_properties(NonLinearMembrane PROPERTIES TIMEOUT 5)
...@@ -22,4 +22,4 @@ add_test(HyperelasticOperator MoReFEMTestHyperelasticOperator ...@@ -22,4 +22,4 @@ add_test(HyperelasticOperator MoReFEMTestHyperelasticOperator
set_tests_properties(HyperelasticOperator PROPERTIES TIMEOUT 2) set_tests_properties(HyperelasticOperator PROPERTIES TIMEOUT 5)
...@@ -28,7 +28,7 @@ add_test(SolidAllDefined ...@@ -28,7 +28,7 @@ add_test(SolidAllDefined
set_tests_properties(SolidAllDefined PROPERTIES TIMEOUT 2) set_tests_properties(SolidAllDefined PROPERTIES TIMEOUT 5)
add_test(SolidLameIgnored add_test(SolidLameIgnored
MoReFEMTestSolidLameIgnored MoReFEMTestSolidLameIgnored
...@@ -36,7 +36,7 @@ add_test(SolidLameIgnored ...@@ -36,7 +36,7 @@ add_test(SolidLameIgnored
set_tests_properties(SolidLameIgnored PROPERTIES TIMEOUT 2) set_tests_properties(SolidLameIgnored PROPERTIES TIMEOUT 5)
add_test(SolidNoKappaMuC add_test(SolidNoKappaMuC
MoReFEMTestSolidNoKappaMuC MoReFEMTestSolidNoKappaMuC
...@@ -44,7 +44,7 @@ add_test(SolidNoKappaMuC ...@@ -44,7 +44,7 @@ add_test(SolidNoKappaMuC
set_tests_properties(SolidNoKappaMuC PROPERTIES TIMEOUT 2) set_tests_properties(SolidNoKappaMuC PROPERTIES TIMEOUT 5)
add_test(SolidPoissonWithoutYoung add_test(SolidPoissonWithoutYoung
MoReFEMTestSolidPoissonWithoutYoung MoReFEMTestSolidPoissonWithoutYoung
...@@ -52,5 +52,5 @@ add_test(SolidPoissonWithoutYoung ...@@ -52,5 +52,5 @@ add_test(SolidPoissonWithoutYoung
set_tests_properties(SolidPoissonWithoutYoung PROPERTIES TIMEOUT 2) set_tests_properties(SolidPoissonWithoutYoung PROPERTIES TIMEOUT 5)
...@@ -16,7 +16,7 @@ add_test(PetscVectorIO ...@@ -16,7 +16,7 @@ add_test(PetscVectorIO
${MOREFEM_TEST_OUTPUT_DIR}/Seq) ${MOREFEM_TEST_OUTPUT_DIR}/Seq)
set_tests_properties(PetscVectorIO PROPERTIES TIMEOUT 4) set_tests_properties(PetscVectorIO PROPERTIES TIMEOUT 10)
add_test(PetscVectorIO-mpi add_test(PetscVectorIO-mpi
...@@ -27,4 +27,4 @@ add_test(PetscVectorIO-mpi ...@@ -27,4 +27,4 @@ add_test(PetscVectorIO-mpi
${MOREFEM_TEST_OUTPUT_DIR}/Mpi4) ${MOREFEM_TEST_OUTPUT_DIR}/Mpi4)
set_tests_properties(PetscVectorIO-mpi PROPERTIES TIMEOUT 4) set_tests_properties(PetscVectorIO-mpi PROPERTIES TIMEOUT 10)
