Commit 63660deb authored by GILLES Sebastien's avatar GILLES Sebastien
#1443 Adjust the quadrangle case to make it manageable for a test.
parent d041d2ef
...@@ -50,4 +50,4 @@ add_test(LoadPrepartitionedGodOfDof_quadrangles ...@@ -50,4 +50,4 @@ add_test(LoadPrepartitionedGodOfDof_quadrangles
set_tests_properties(LoadPrepartitionedGodOfDof_triangles PROPERTIES TIMEOUT 20) set_tests_properties(LoadPrepartitionedGodOfDof_triangles PROPERTIES TIMEOUT 20)
set_tests_properties(LoadPrepartitionedGodOfDof_quadrangles PROPERTIES TIMEOUT 20) set_tests_properties(LoadPrepartitionedGodOfDof_quadrangles PROPERTIES TIMEOUT 100)
...@@ -233,7 +233,7 @@ FiniteElementSpace1 = { ...@@ -233,7 +233,7 @@ FiniteElementSpace1 = {
-- List of the shape function to use for each unknown; -- List of the shape function to use for each unknown;
-- Expected format: {"VALUE1", "VALUE2", ...} -- Expected format: {"VALUE1", "VALUE2", ...}
shape_function_list = { "Q2", "Q1" }, shape_function_list = { "Q3", "Q1" },
-- List of the numbering subset to use for each unknown; -- List of the numbering subset to use for each unknown;
...@@ -264,7 +264,7 @@ FiniteElementSpace2 = { ...@@ -264,7 +264,7 @@ FiniteElementSpace2 = {
