GitLab
Explore
Primary navigation
Search or go to…
L
LF
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Container registry
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
LightFieldCodingLibrary
LF
f47d6b98
f47d6b98
5 years ago
DIB Elian
Downloads
Patches
Accommodated function to recent changes
240eed09
codec.m
+15
-8
15 additions, 8 deletions
codec.m
15 additions
8 deletions
codec.m
15
8
f47d6b98
@@ -65,24 +65,31 @@ end
% Do padding
% Do padding
LFSize
size
LFRef
LFSize
size
LFRef
LFSizePad
ceil
LFSize
LFParams
padding
LFParams
padding
LFSize
padSize
ceil
LFSize
LFParams
padding
LFParams
padding
LFSize
LFSizePad
3
padSize
3
LFRef
padarray
LFRef
LFSizePad
'replicate'
'post'
LFSizePad
LFSize
padSize
imgSizePad
LFSizePad
3
imgResPad
LFSizePad
4
imgResPad
2
LFRef
padarray
LFRef
padSize
'replicate'
'post'
% Convert inputs for HEVC
LFHEVCParams
LF
LFtoHEVC
imgSizePad
imgResPad
LFParams
HEVCParams
LFParams
refFilename
LFHEVCParams
InputFile
LFParams
recFilename
LFHEVCParams
ReconFile
% Write input yuv file
if
LFParams
encode
if
LFParams
encode
imgSizePad
imgRes
LF
write
LFRef
LFParams
'filename'
LFParams
refFilename
LF
write
LFRef
'filename'
LFParams
refFilename
'addInfo'
false
LFHEVCParams
LF
LFtoHEVC
imgSizePad
imgRes
LFParams
HEVCParams
% Encode frames using HEVC
nbBits
peaksnr
HEVC
codec
LFHEVCParams
HEVCParams
nbBits
peaksnr
HEVC
codec
LFHEVCParams
HEVCParams
% Read output yuv file
if
LFParams
decode
if
LFParams
decode
LFRec
LF
read
imgSizePad
imgRes
LFParams
'filename'
LFParams
recFilename
LFRec
LF
read
'filename'
LFParams
recFilename
% Undo padding
% Undo padding
This diff is collapsed.
Loading
Save comment
