Commit eb6ff34f authored by Charles Deltel's avatar Charles Deltel
Migration gitlab doc
parent 7ba4a103
...@@ -10,11 +10,12 @@ if (DOXYGEN_FOUND) ...@@ -10,11 +10,12 @@ if (DOXYGEN_FOUND)
ADD_CUSTOM_TARGET (doc ADD_CUSTOM_TARGET (doc
${DOXYGEN_EXECUTABLE} ${CMAKE_CURRENT_BINARY_DIR}/Doxyfile ${DOXYGEN_EXECUTABLE} ${CMAKE_CURRENT_BINARY_DIR}/Doxyfile
ADD_CUSTOM_TARGET (deploy-doc ADD_CUSTOM_TARGET (tgz-doc
COMMAND tar -zcf ${CMAKE_BINARY_DIR}/doc/doc.tgz -C ${CMAKE_BINARY_DIR}/doc/html . COMMAND tar -zcf ${CMAKE_BINARY_DIR}/doc/doc.tgz -C ${CMAKE_BINARY_DIR}/doc/html .
COMMAND scp ${CMAKE_BINARY_DIR}/doc/doc.tgz ${gatb-doc-user-login}@scm.gforge.inria.fr:/home/groups/gatb-core/ #doc.tgz is kept by Jenkins as a job artifact
COMMAND ssh ${gatb-doc-user-login}@scm.gforge.inria.fr "rm -rf /home/groups/gatb-core/htdocs/doc/api/*" #COMMAND scp ${CMAKE_BINARY_DIR}/doc/doc.tgz ${gatb-doc-user-login}@scm.gforge.inria.fr:/home/groups/gatb-core/
COMMAND ssh ${gatb-doc-user-login}@scm.gforge.inria.fr "tar -xf /home/groups/gatb-core/doc.tgz --no-overwrite-dir -C /home/groups/gatb-core/htdocs/doc/api" #COMMAND ssh ${gatb-doc-user-login}@scm.gforge.inria.fr "rm -rf /home/groups/gatb-core/htdocs/doc/api/*"
#COMMAND ssh ${gatb-doc-user-login}@scm.gforge.inria.fr "tar -xf /home/groups/gatb-core/doc.tgz --no-overwrite-dir -C /home/groups/gatb-core/htdocs/doc/api"
INSTALL (CODE "execute_process(COMMAND ${CMAKE_BUILD_TOOL} doc)") INSTALL (CODE "execute_process(COMMAND ${CMAKE_BUILD_TOOL} doc)")
...@@ -84,14 +84,14 @@ cmake -Wno-dev -DJENKINS_TAG=${BRANCH_TO_BUILD} -DJENKINS_GFORGE_USER=${INRIA_FO ...@@ -84,14 +84,14 @@ cmake -Wno-dev -DJENKINS_TAG=${BRANCH_TO_BUILD} -DJENKINS_GFORGE_USER=${INRIA_FO
make -j 2 doc || error_code make -j 2 doc || error_code
make deploy-doc || error_code make tgz-doc || error_code
########################################################################### mv doc/doc.tgz $GIT_DIR/.. # move to Jenkins workspace, to be kept as a job artifact
# TODO_migration_gitlab (ChD, 2021-07-15) :
# - this used to move the GATB doc to gforge.inria.ssh using scp and ssh # Trigger gitlab-ci job to deploy doc.tgz on gitlabpages
# (not possible any more) curl -X POST \
# - move this doc elsewhere (gitlabpages?) -F token=$GITLAB_CI_TRIGGER_TO_PUBLISH_API_DOC \
########################################################################### -F ref=deploy-api-doc \
https://gitlab.inria.fr/api/v4/projects/30845/trigger/pipeline
# END # # END #
