Commit c4e3fe6b authored by Alexandre HONORAT's avatar Alexandre HONORAT
Update VM link (which does not include LANG fix)
parent efcc9d4c
...@@ -70,7 +70,7 @@ Other scripts are present in order to generate experiment artefacts. ...@@ -70,7 +70,7 @@ Other scripts are present in order to generate experiment artefacts.
ADFG can inter-operate with [Cheddar](http://beru.univ-brest.fr/cheddar/) - an open-source scheduling analyzer - by exporting the computed results in a xml format that can be read by Cheddar. ADFG can inter-operate with [Cheddar](http://beru.univ-brest.fr/cheddar/) - an open-source scheduling analyzer - by exporting the computed results in a xml format that can be read by Cheddar.
Scheduling simulation is used to verify the schedules synthesized by ADFG and provide additional information such as numbers of preemptions and max/min/average buffer utilizations over a simulation interval. Scheduling simulation is used to verify the schedules synthesized by ADFG and provide additional information such as numbers of preemptions and max/min/average buffer utilizations over a simulation interval.
A simple method to test the tool-chain is to use this [virtual machine](https://phobos.univ-brest.fr/vm/CHEDDAR_ADFG_2.vdi) with ADFG and Cheddar pre-installed. A simple method to test the tool-chain is to use this [virtual machine](https://phobos.univ-brest.fr/vm/CHEDDAR_ADFG_3.vdi) with ADFG and Cheddar pre-installed.
The virtual machine is also configured with tools to compile ADFG and Cheddar from their source code. The virtual machine is also configured with tools to compile ADFG and Cheddar from their source code.
The default username and password are cheddaradfg. The default username and password are cheddaradfg.
