Commit cbd8f4b6 authored by POGODALLA Sylvain's avatar POGODALLA Sylvain
generate documentation for all modules
parent a311623c
...@@ -112,7 +112,7 @@ sig ...@@ -112,7 +112,7 @@ sig
val add_e_facts : program -> (ASRule.rule list*Datalog_AbstractSyntax.ConstGen.Table.table*IdGenerator.IntIdGen.t) -> program val add_e_facts : program -> (ASRule.rule list*Datalog_AbstractSyntax.ConstGen.Table.table*IdGenerator.IntIdGen.t) -> program
(** [add_rule i r p] adds a [ASRule.rule] to a [Datalog.Program] (** [add_rule i r p] adds a [ASRule.rule] to a [Datalog.Program]
with the assumption that it will not change the {em nature} of with the assumption that it will not change the {e nature} of
any predicate (that is making it change from extensional to any predicate (that is making it change from extensional to
intensional). If [i] is set to true, then the rule concerns an intensional). If [i] is set to true, then the rule concerns an
intensional predicate. If it is set to [false] then it intensional predicate. If it is set to [false] then it
...@@ -89,4 +89,4 @@ ...@@ -89,4 +89,4 @@
(documentation (package acgtk)) (documentation (package acgtkLib))
