Commit 10b6f434 authored by POGODALLA Sylvain's avatar POGODALLA Sylvain
No commit message
No commit message
parent 30d86b4b
...@@ -60,6 +60,29 @@ then on the prompt type ...@@ -60,6 +60,29 @@ then on the prompt type
Example files are given in the ./examples directory. Read the Example files are given in the ./examples directory. Read the
./examples/README file ./examples/README file
** ACG emacs mode **
There is an ACG emacs mode (acg.el) in the emacs directory.
Look at the INSTALL file to see how to install it.
It's main feature is to be loaded when editing an acg data file (with
signatures and lexicons). It is automatically loaded for files with a
.acg extension
It basically contains compilation directives and next-error
searching.
1. First load an acg file
2. then run "M-x compile" (or C-cC-c) to call the compiler (acgc or
acgc.opt)
3. then run "M-x next-error" (or C-x`) to search for the next error
(if any) and highlights it
